Question about T-Mobile Sidekick® 3 Cellular Phone
Sidekick problem i have a sidekick3 and it wont turn on  i have to hole the charger for it to turn on then turn right back off wats the problem?
    President:
  • 625 Answers
The sidekick 3 has an issue with the charging port. If its under warranty, call t-mobile and get it fixed.
If out of warranty, You can get it fixed but it runs about 100 dollars.
The other option is to get a external battery charger and a spare battery. That way you have a battery charging while on is in use. The total for both is about 40 dollars from ebay.
http://shop.sidekickskin.net/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Posted on Dec 13, 2007
    President:
  • 1,944 Answers
It looks like it's a battery related problem . You should get a new battery. Good luck!
Posted on Dec 12, 2007
My sidekick3 light wont turn on,
it might be something wrong with the sensor.. try to put your finger over it a few times. the sensor is on the screen opposite the T mobile logo
Aug 09, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Tmobile sidekick3 wont charge
It's called the sidekick 3 charging port and they are known to go bad a lot.
You can check out cellulardr for the repair. It runs about 75 dollars or you can get a external battery charger cradel and charge the battery outside the phone.
Feb 17, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick3
Trani-
Your flex cable is too tight. Remove the LCD assembly and turn the it back a bit
Aug 09, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick3
had the same problem before...when i had firsst got the phone.
i just looked around the house for and cables that could plug in the outlets and that fit the sidekick 3 ...charger hole.
i know that a nokia charger that fits the sidekick charges it.
good luckk!! =)
Jun 20, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick3
The sidekick 3 has an issue with thte charging port. If you have a friend with a sidekick 3 or sidekick ID, try one of their batteries. If your unit powers on, the charging port has gone bad.
the repair for a charginf port runs about 80-100 dollars. A cheaper work around is to get a charging cradle that has a spare battery charger slot. They run about 30 dollars on ebay and it will allow you to charge the bettery seperate from the phone.
Check out the following link for cradles.
http://repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Mar 29, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick wont work
It seems your charger port is broken, it hapfens often on cellphones, wear and tear. Check to see if its under warranty, and it can be replaced. Check my profile if you need more help.
Jan 24, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick backlight
Is it the LCD back light? If so, it probably burned out. Did the phone get wet recently? That is usally the main cause.
You can get a replacement screen on ebay for about 40-50 dollars. Look for ones that come with the instructions and screwdriver. You will need a T6 Torx Driver.
Replacement Sidekick LCD Screens
Jan 19, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick 3 wont turn on
my sidekick 3 wont turn on at all,, it charges but when i go to turn it on. nothing.. how can it get fixed or wat kind of profesional help could i get to fix it?
Dec 01, 2007 | T-Mobile Sidekick® 3 Cellular Phone
My problem is with the sidekick III, it wont charge, What should I Do?
dnt drain the batteries of your phones...if that happens pls buy multicharger or battery shock,remove the battery..... charge it for about 5min or shock the battery if ur using battery shock...be sure u positioned it ryt....den put it back on ur phone then charge it or continue the charging on the multicharger until its full !!!!im pretty sure of it....im encountering the same prob as urs before and thats what i did and it work!!!!
Jun 09, 2007 | T-Mobile Sidekick II
A sidekick3 that dont turn on
The sidekick 3 has a known issue with the charging port. If it is under warranty call t-mobile.
If not, you can get it fixed for 90-100 dollars.
The other solution is to get a external battery cradle with spare battery charger and an extra battery. This runs about 40 bucks on ebay.
Mar 20, 2007 | T-Mobile Sidekick II
T-Mobile Sidekick® 3 Cellular Phone Logo
67 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
ismael castillo
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
