Question about Epson Stylus Photo R320 InkJet Printer
I am getting a strong magenta colour cast, despite thorough cleaning - help
My r320 has developed a strong magenta cast, despite cleaning and also installing a drain bottle to release used ink. I'm at a loss, and I'm also very much a technophobe, so any assistance needs to be in words on one syllable please!
I removed both cyan ink cartridges and replaced them with new. The printer worked as expected. I figured one of them was not putting enough ink down.
Later when each of the new cyan (light and dark) ran out, I replaced them with the ones I had removed earlier. I found no problem.
Don't have a clue what was wrong.
Perhaps unrelated, my printer now displays (a month later) and error message to replace internal components. It has been used for several years and is at end of life span, so says the message.
Posted on Jan 29, 2008
My printer prints in green not other colours
Most printers have 4 color inks: Black, magenta, cyan, yellow.
If your magenta ink isn't printing, then your prints will have a green cast.
If your printer has a "nozzle test", I suggest doing that. If it has a "head clean" function, that may help.
Replacing the magenta ink cart may be all that's needed.
Jun 20, 2015 | Office Equipment & Supplies
How do I get it from going into system fault
that looks like a knoica minolta code not a kyocera.
Worn "Y" developer- is the developer at or near end of life?
Worn "Y" developer unit- is the developing unit over life?
Dirty Gamma sensor- take out Colour registration unit and thoroughly clean the gamma sensor.
Oct 02, 2014 | Kyocera Office Equipment & Supplies
Wont print magenta despite deep cleaning and nozzle head cleaning. Its a new cartridge. It wont print sotred docs or photocopy in magenta it comes out yellow/green colour
Hi the bad news is you need a new print head and they cost about £47.00
go to amazon or google Canon PIXMA MP620 print head and you will get a list of suppliers
Very simple to fit
Ian
Mar 11, 2011 | Canon PIXMA MP620 All-In-One InkJet...
How do you remove the outer cover for the epson r320 need to change the waste ink pads and give it a good clean
I strongly suggest that you NOT attempt this unless you are thoroughly familiar with the correct
assembly/disassembly procedure. That means you need a factory service manual.
They are available online.
Believe me, it is NOT a simple case of "take off the cover and pull out the pads". Just to get to
the waste ink pads is MAJOR SURGERY on this printer and will require several hours of your time.
It is not just ONE pad either. I believe there are at least SIX.
Best of luck.
Jan 29, 2011 | Epson Stylus Photo R320 InkJet Printer
Hi, When printing photos, my photos have horizontal light coloured lines across them. When I print the nozzle check pattern all colours match the guide with the exception of the light magenta....
Epsons are notorious for this sort of problem, especially in used infrequently as ink residue dries on the print head; try using a cleaning cartridge, or swab around relevant print head with cotton bud and ethanol/isopropyl alcohol. Here are examples of cleaning carts, there are others http://www.internet-ink.co.uk/epson-cleaning-cartridges/ http://www.icompinkcartridges.co.uk/epson-r200-r300-r220-r320-r340-cleaning-kit.html
Jan 03, 2011 | Epson Stylus Photo R200 InkJet Printer
Colours are faded despite all toners at 25% or
If there is black "dust" all over the developer (behind the image drum assembly ) you need to replace the developer; that is uncoated toner prevenitng transference of colored toner.
Jul 30, 2010 | Dell 5110cn Laser Printer
MAGENTA NOT PRINTING
The other week I had the black print head clog up, requiring daily nozzle deep cleaning [a normal 'ocassional' maintenance function]. Thought I needed a new Print head, so anything worth a try.
I loaded up an old black cartridge [I load all my own......always have] with Isopropyl Alcohol and ran deep clean on that cartridge a couple of times, then repeat printed [6 times] a page full of the number 8 in about half inch character size, to get the alcohol through the nozzles. then Deep cleaned again 3 times, to wash it through the print head.
I reloaded the normal ink filled cartridge and ran the '8' page again till I got good black output. It has now been working without problem, daily, for over a week. Clearly if it's a Magenta only problem, the cleaning as described above would be a bit different, as the magenta is one of 4 colour cartridges.
My printer does quite a lot of work, and was bought at least a couple of years ago, being used daily for alpha numeric and photo printing work. This was the first difficulty I experienced with it.
Hope the above might help.Ken
May 21, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Red cast on all prints
Sounds crazy, but have you got the LM (light magenta) and M (magenta) tanks or inks mixed up?
Also - check the profiles, if you've got a colour profile set up, you may have applied it twice, which would make a magenta cast...
Dec 04, 2008 | Epson Stylus 1400 InkJet Photo Printer
Dell 5100cn
deatech,
I am going to answer this even though there was no reply to my clarification report.
No, it is not a HVPS problem. This is a magenta developer problem. The magenta developer for some reason has the highest failure rate of all the developers, including black. Perhaps because there are more shades of magenta in color prints.
Since you changed the toner, we can assume you are not out of magenta, but it is possible that you did not run a developer cleaning in the maintenance mode on the magenta developer.
If the magenta toner had been allowed to run out all of the way, a developer cleaning would allow the toner auger to move fresh toner from the toner dispenser, through the feed tube, into the developer.
If you have run the developer cleaning, and you can see that there is magena toner on the magenta developer ( for clarification, the developers are located behind the imaging drum. remove the drum to expose the 4 developers ), then the developer itself is defective.
Good luck.
Cory
May 05, 2008 | Dell 5100cn Laser Printer
Magenta colour comes through on all prints right across the page, it is faded but is still clearly there. I can temporarily fix problem by using the printer menu to clean the magenta developer, but it...
We have over 50 of these printers and a few have had the magenta bleeding problem. On everyone of them the problem was corrected by going to the clean developer function under Maintenence from the Menu and choosing to clean the magenta color. Usually have to run it a couple times but it has always corrected the problem so far.
Mar 29, 2008 | Dell 5100cn Laser Printer
Epson Stylus Photo R320 InkJet Printer Logo
184 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
