Unplug the unit. Remove the lint filter...and look down into the opening where the filter was. You should see a folded sheet metal box about 4 inches square and down about 4 inches inside the filter opening. This box is removed by removing the Phillips screws inside the dryer on the interior front wall. You can feel for them with your hand or with a light inside...stick your head into the dryer opening and look down and back toward your feet.
Removing the screws reveals the 2 operating thermostats. As you remove the screws hold the box so it doesn't fall into the blower area below the filter.
When you are re-assembling be sure none of the thermostat wires touch the cover after it's assembled.
Good luck.
