Question about Brother MFC 240C All-In-One InkJet Printer
Brother MFC-240C init. unable AF error message
I hope someone can help me with this. I bought a Brother MFC-240C inkjet printer opened the box and followed the setup instructions to the letter. I get to where it cleans the ink tube system,the cleaning cycle finishs and it prints a quality check page. All the 4 color blocks look perfect on the printout so the LCD asks is quality ok I hit yes then I get the error message init. unable AF on the LCD. It says to check troubleshooting in manual I do and all it says is the machine has a mechanical problem or theres a foreign object in the machine such as a clip. I open scanner cover and see nothing wrong. I also turned off waited 5 minutes then repowered. When I do I get this grinding sound for about 10 seconds then the same error message. Any help anyone can give me I would be grateful. Sorry for the long winded explanation but I wanted to explain as best I could the problem
  • 1 more comment
  • MikeP21 Dec 14, 2007
    Thanks for trying to help but I did what you suggested and it's still doing the same thing. The flat cable was firmly attached to the circuit board, I made sure of it. Is there any other suggestions you can give me. Thanks again
    If this is helpful I just noticed that when I have the scanner lid picked up and watch the scanner light it moves about 4 inchs across the scanner then goes back and then it starts the grinding sound.
  • MikeP21 Dec 15, 2007
    Sorry to be such a nuisance but before I dismantle the scanner it would help me to know what I am looking at. When I look down thru the scanner glass there is a belt that goes from one side to the other and it is connected. On one side there is 3 gears, I figured out the grinding sound is the 3 gears going really fast when I turn the scanner on. Should I be seeing another belt cause you mentioned a transport belt and a belt drive. Thanks for all your help
    New Friend:
My scanner and printer model MFC-J245 "imposible inicio AF" HELPme please!!!!!
Posted on Apr 13, 2016
  • 832 Answers
Sure. No prob.
Open scanner cover as you would do to check for a paper jammed sheet.
Do open the plastic which runs from middle to the right side (looks like a "Z" turned clockwise). Use a small screw diver for that. beneath you will find th flat cable of the scanner. You have to reconnect the flat cable by simply sticking it into position onto the main circuit board. make sure flat cable is in good position and click the" Z  "onto the channel. Close cover then power up and do what ever you want to do with your mfc ;-)
Posted on Dec 13, 2007
  • Mix-it-up
    Mix-it-up Dec 15, 2007
    This is quite normal, because the scanner moves each time for self adjustment when powering up.
    So if you have checked the flat cable and it is OK, you have to dismantle the scanner and check the transport belt and the belt drive. Sometimes the contact wont come up to give the scanner the stop info.
  • Mix-it-up
    Its the belt you have discribed. And have a look at the gear wheels and dirve engine. There might be cable loose, too.
Brother mfc 240c machine error 40
Unplug the machine from the AC outlet and if possible cool the room where the machine is located.Still having Problem Then follow Us For Brother Printer Support
Mar 22, 2014 | Brother Multi-Function Center MFC-240C...
Unable to Init. AF in brother mfc 64900 cw printer
initial error AF, check the scanner flex cable or any cable, either they are not fix or not intalled properly..
Jan 28, 2014 | Brother MFC-5440CN All-In-One InkJet...
Mfc j691dw unable to init AF what does it mean
I cant get rid of 'unable to init.42' from my new mfc j6910dw. Anybody know what does it mean & how to remove the mssge?
Oct 14, 2012 | Brother Mfc-j6910dw Inkjet Multifunction...
Mfc -240c init unabled 4f please help ,thank!
4F message indicates that the printhead is gone, you will need to replace it to make it work again. Before you replace it though, you may want to try this, see if it will remove the error message: Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3. This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Feb 05, 2011 | Brother MFC 240C All-In-One InkJet Printer
Unable to Init. 46
Your Ink Absorber box is full. The machine cleans its print nozzles by blasting them out with ink; it collects that waste ink and pumps it into a plastic box filled with thick, felt pads. After a certain number of cleaning operations, it decides it's not safe to squirt more ink into the box and gives this Error 46. Replacing the ink absorber box and flushing box and resetting the purge counter is fairly complex. Maybe someone has instructions all typed out, but your best bet is probably to take it to a Brother tech.
Jun 11, 2009 | Brother MFC-465CN InkJet Printer
MFC-240C PRINTER DISPLAYS "INIT UNABLE 4F" WHEN TURN ON
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 26, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother mfc-240c printer error message unit unable 43
http://support.brother.com/g/b/faqend.aspx?c=gb&lang=en&prod=fax2440c_us_eu&faqid=faq00000168_003
Jan 06, 2009 | Brother Multi-Function Center MFC-240C...
MFC-240C
You have to reconnect the scannerflatcable to the main circuit board.
Open the scanner top as when a paperjam had occured. Remove the "Z" lookinglike plastic cover near the middle running to the right side which hides the flatcable. Simply stick the flatcable into the mainboard, close the cover
again and close the scanner top.
Feb 18, 2008 | Brother Multi-Function Center MFC-240C...
Will not initialize
Take it back to the dealer! Better do not fix that problem by opening the printer! If it is a second hand printer, write again here.
Aug 26, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 240C All-In-One InkJet Printer Logo
2,461 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
