Question about GE Refrigerators
How to CLEAN ge momogram fridge model # zisb42dya, freezer isn't working, everything defrosted. I watched a repair person clean it one time, but can't remember what they cleaned with the vacuum.
    Top Expert:
  • GE Master
  • 22,408 Answers
Cleaning is the condenser and fan under unit front grill remove and rear panel remove to access also unplug fridge before doing anything
Posted on Oct 07, 2019
SOURCE:
Master_Tech
  • 770 Answers
SOURCE: fridge doesn't get cold enough
you have either a Defrost heater / a defrost timer/ or a defrost bi-metal that is bad. if you post your model # i can look it up and show you how to set it into defrost to see if the heaters are ok
Since you replaced the timer already that leaves two things you need to check set it into defrost if you know how and remove the panel in the back wall of the freezer you should see the heater(s) are on if not check pwr 120vac at the heaters if 0 volts the bi-metal is bad
Posted on Feb 22, 2008
  • 93 Answers
SOURCE: Freezer on GE model 25 GSS25SGMDBS not working
change sensor temp- part number WR55X10025. You can get from searpartdirect. approximate$7.00
Posted on Jul 26, 2008
Benimur
  • 6966 Answers
SOURCE: Fridge not cooling
Your description is quite complete but is rather baffling. Pls bear with me while we process by elimination. A few basic/working ideas:
  • most designs call for a single compressor to cool the freezer;
  • the cold air in the freezer is drawn towards the fridge to cool that area;
  • this is performed by a fan drawing air in the freezer through the evaporator;
  • most would have a vent or air pathway to guide the freezer air;
  • all would have thermostatic control to set the desired temperature;
  • some designs have two thermostatic control , 1 for the freezer, 1 for the fridge.
As applied to your concern:
  • compressor is working since freezer is OK;
  • fan is working as you posted but is the air drawn from the freezer, better still, is the air forced/vented into the fridge?
  • could you please check that the air is strongly blown into the fridge area;
  • a little experiment, open the fridge door, look for and press on the door switch, the light should go out, after a lengthy seconds, the fan should trigger on, not only would it be audible, you would notice the frozen air swirling inside the fridge area. If you hold on long enough to the dorr switch, the compressor should kick in (if it is not already running) since the thermostat of the fridge area (if one is present) would sense that the fan is turning but the fridge area is not cooling.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 02, 2008
  • 116 Answers
SOURCE: Fridge wasn't cooling but freezer was working, now both aren't
Hi,Your husband did good job, after cleaning and vacuuming, did freezer (bottom) have excessive ice?, if there's excessive ice in bottom, after cleaning, you have a defrost problem, but if there're no ice in freezer after cleaning, you got freon (gas leak) , there's a condensate loop, that passes through ref. body, from compressor that naturally develop, freon leak after few years, by rusting, normally it can be by- pass. vacuum and refill with freon, if there's no freezing, but compressor running, you'll need a mechanic, you got a freon leak. good luck.
Posted on Aug 10, 2009
woodchuck789
  • 4070 Answers
SOURCE: I have a GE Model #GSL25JFPABS fridge. My freezer
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Aug 29, 2009
Defroster isn't working on GE Frig model
I'm Leo
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If this was helpful please rate me
Thanks for using fixya
Leo Ponder
imufo2
Thank you for using fixya
Leo Ponder
Please VOTE FOR ME IF THIS WAS HELPFUL.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click for article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Jul 26, 2011 | GE Refrigerators
The refrigerator is not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 26, 2011 | Amana Refrigerators
Frigidaire upright fridge freezer.The drainage hole at back of fridge part of item keeps freezing over blocking drainage from fridge
Yrur model number is missing the last three digits.... I will use FRT21H8CB1 as the example model number.
You need to do a total manual defrost with a catch basin and comprtment drain cleaning.
- Unplug the unit
- Remove fgreezer contents
- Direct an exteranl fan into the freezer compartment for just over 2 hours to ensure the compartment drain tube has defrosted.
- During the defrost period... open the fiberboard panel on the lower back of the refrigerator and clean out everything, Condensor coils, catch / drip pan (Called pan-defrost for parts), and the END of the compartment drain tube.
Model reference:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5158190&diagram_id=1311449#d1311449
Defrost pan Item 26 of above link needs to be cleaned.
Coils Item 1 need to be cleaned
Fan blade Item 61 needs to be cleaned.
The evaporator trough, drain item 17 also should be clear. Here is what you can do without tearing everything in the back of the freezer apart. Once your sure the comprtment drain tube (no item number / bulk hose) is clean on the end. Use the exhaust of a Vacuum cleaner and the hose to force air UP through the drain hose and float out any debris from the trough drain. Have a 2nd person listen for air flow into the freezer compartment if possible. The biggest problems with freezer compartment drains is the END of the hose at the defrost pan underneath the unit clogs up and then the compartment drain hose just loads up with scum. Then the freezer stops draining and you have the symtom your describing.
After the manual defrost and cleaning return the unit to normal service.
Having said all of that... if the refrigerator then freezer starts warming up in 3 - 4 days... you may have an automatic defrost problem causing the icing. I.e it is not defrosting so the evaporator eventually ices over and forms an ice block in the back and bottom of the freezer compartment. Usually if there is an ice block that forms you wil hear the evaporator fan striking the ice build up.
If this is happening... for sure there is an automatic defrosting problem and your stuck doing a manual defrost ever 3 - 4 days until repairs are complete.
One more note.. if there is NOT any compartment drain tubing visible... your unit may port evaporator tray water down the back of the fresh food compartment to the defrost pan under the unit... just clean everything that serves as a drain function best you can during the manual defrost and cleaning process.
Thanks for choosing FixYa,
Kelly
May 23, 2011 | Frigidaire FRT21H8 Top Freezer...
The temperature is staying constant at 51 degrees - and the freezer won't go below 35. What is preventing it from dropping to 42 & 0 respectively?
Your fridge is probably suffering from a fan failure or defrost circuit failure. One (or possibly more) of the following components has failed: 1) the defrost terminator or sensor, 2) the defrost heating element or 3) the defrost controller / timer. Items 1 & 2 will be found in the freezer compartment - behind the back wall. The 3rd item can often be found in the toe space at the bottom of the fridge - behind a kick plate. The fan I mentioned is located in the freezer - in the cooling coil compartment. It is used to pull air over the coil to cool it and circulate it in the freezer - and direct a portion of it into the fresh food compartment as well. If it has failed, temperatures in both the freezer and fresh food compartment will rise.
Before we go further - check and clean the condenser coils on the bottom of the fridge with a vacuum. They may be clogged with dust and dirt. Listen for the compressor and fan - are they running? Since everything inside the fridge is warm and getting warmer - the compressor should be running to try to cool it. If left to run like this for a long time however, can cause the compressor to fail. This is usually a deal breaker for repair due to cost. If the fan or compressor isn't running - you should probably call a repair person.
If you don't know how to work with electrical meters and tools or are not comfortable working in tight spaces (back wall of the freezer) with live electric parts, you should call a repair person. Also, refrigerants are under pressure and are very dangerous. If allowed to escape from the tubing, coils, etc. there is a very real danger of instant frostbite if it comes in contact with your skin. You can be blinded if it sprays into your eyes. These reasons make me believe that this is a complicated DIY type job and really isn't a good one for a beginner or even an intermediate to attempt. On the plus side, parts are relatively inexpensive, and a qualified person should be able to quickly diagnose the problem. Labor rates and parts markups can bring this repair up into $200 and up range, however.
If you can't swing that amount of money right now, unplug the fridge, empty the freezer (& fridge if needed) and completely defrost the the freezer. If you access the freezer coil behind the inside back wall, you can greatly accelerate the defrost process by leaving the freezer door open - or even faster still by directing a blow dryer at it. Once all the frost is melted, plug the fridge back in, allow to get cold & reload the freezer. Depending on how humid it is in your kitchen, you can put off the repair at least a month or more. If after defrosting it still fails to cool down, the freezer compartment fan described in the top paragraph has probably failed. Ideal temps for fresh food is about 34-36 degrees and the freezer is about -5 to 0 F.
If / when you do finally call, for service, have the freezer emptied & defrosted already - will save the defrost time by the repair person.
If you are comfortable performing this work, let me know and I'll get you more information. I hope this was helpful and good luck. Please rate my reply - thank you.
May 03, 2011 | Maytag 22 cu. ft. Bottom Freezer...
We have an Amana refrigerator with bottom (frost free) freezer drawer. There is ice build up inside the freezer on the back wall and food is not freezing. The refrigerator is about 6 years old. any...
Your fridge is probably suffering from a defrost circuit failure. One (or possibly more) of the following components has failed: 1) the defrost terminator or sensor, 2) the defrost heating elementor 3) the defrost controller / timer. Items 1 & 2 will be found in the freezer compartment - behind the back wall. The 3rd item can often be found in the toe space at the bottom of the fridge - behind a kick plate.
Before we go further - check and clean the condenser coils on the bottom of the fridge with a vacuum. They may be clogged with dust and dirt. Listen for the compressor and fan - are they running? Since everything inside the fridge is warm and getting warmer - the compressor should be running to try to cool it. If left to run like this for a long time however, can cause the compressor to fail. This is usually a deal breaker for repair due to cost. if the fan or compressor isn't running - you should probably call a repair person.
If you don't know how to work with electrical meters and tools or are not comfortable working in tight spaces (back wall of the freezer) with live electric parts, you should call a repair person. Also, refrigerants are very dangerous. If allowed to escape from the tubing, coils, etc. there is a very real danger of instant frostbite if it comes in contact with your skin. You can be blinded if it contacts your eyes. These reasons make me believe that this is a complicated DIY type job and really isn't a good one for a beginner or intermediate to attempt. On the plus side, parts are relatively inexpensive, and a qualified person should be able to quickly diagnose the problem. Labor rates and parts markups can bring this repair up into $100 - $200 and up range, however.
If you can't swing that amount of money right now, unplug the fridge, empty the freezer (& fridge if needed) and completely defrost the the freezer. If you access the freezer coil behind the inside back wall, you can greatly accelerate the defrost process by leaving the freezer door open - or even faster still by directing a blow dryer at it. Once all the frost is melted, plug the fridge back in, allow to get cold & reload the freezer. Depending on how humidy it is in your kitchen, you can put off the repair at least a month or more.
When you do finally call, for service, have the freezer emptied & defrosted already - will save the defrost time by the repair person.
Mar 11, 2011 | Refrigerators
GE Model # DSS25PFMD WW, lights and fan are working not cooling
Aug 21, 2009 | GE GSS25JEM Side by Side Refrigerator
Refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE GDS18SBPARSS ICE BUILDUP ON THE FAN
did either of the repairmen check the defrost heater, sounds like that may be your issue.
Apr 03, 2008 | GE GBS18KBM Bottom Freezer Refrigerator
GE GSS201EMD CC
A common problem with these refrigerators is a faulty defrost heater. When the defrost heater fails ice will accumulate on the condenser coils located inside the freezer compartment of the refrigerator. Typical symptoms are frost appearing on the back wall of the freezer compartment, little or no ice being made by the ice maker, and above normal temperatures in the freezer compartment. The defrost heater should be replaced by a qualified repair person. The part itself is not particularly expensive.
Aug 04, 2007 | GE GSS20IEM Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Tmik
Tmik
Level 1 Expert
