Question about Kenmore Washing Machines
Kenmore top loading washer wont start. - Kenmore Washing Machines
  • 40 Answers
If it fills with water and will not start agitating or the spin cycle check the safety switch on the lid, they vibrate loose and fall out
Posted on Oct 09, 2019
SOURCE:
  • 525 Answers
SOURCE: washer does not fill
Firstly, check to see that your water temperature is selected properly. Next, check to confirm water supply to the washer is adequate, both HOT and COLD. If confirmed, try replacing the fill valve.
Posted on May 27, 2008
  • 12 Answers
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
Posted on Jan 31, 2009
SOURCE: kenmore front load he3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
Posted on Mar 02, 2009
  • 11 Answers
SOURCE: My Kenmore series 70, top loading, washer has a mold smell.
thaty have this one stuff called affresh its used for frontloaders but you can use it for toploaders too it works great
Posted on Mar 24, 2009
sclarke7
  • 222 Answers
SOURCE: my kenmore top loading washer 70 series wont go into spin cycle
check the lid switch some washers will fill and was with the lid open but will not spin, if the lid is closed manually actuate the lid switch or bypass it electrically, or replace it.
Posted on Apr 07, 2009
I have a washer mashine kenmore oasis top load wont start
check the lid safety switch located under the top thats actuated when the lid is closed if its bad the unit will fill but not operate on any cycles
Aug 02, 2011 | Kenmore Oasis HE 27082 Top Load Washer
My kenmore top loader 80 series wont start. I traced power to a black cylinder next to motor. i get nothing, no water fill or motor action in any cycle.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Also see the following Whirlpool / Kenmore service manual for top load, direct drive washers.
It has troubleshooting and component testing procedures.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Jun 09, 2010 | Kenmore Washing Machines
Washer wont start kenmore 41744052401
if it is a top load washer check make sure there is power to machine , mine would make a humming but not start ,found a wire had fallen off the capacitor.
Feb 14, 2010 | Kenmore Washing Machines
My kenmore top loading washer 70 series wont go into spin cycle
Apr 07, 2009 | Kenmore 22422 Top Load Washer
Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Nov 12, 2008 | Kenmore 22422 Top Load Washer
Kenmore 80 series washer
If the motor is starting? it will be just a belt replacement belts range 15-40ish
Jan 03, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer switch
Sounds like a timmer problem and needs replacing
Oct 05, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
fordexpert
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
