Question about Microsoft Optical Desktop 1000 (BV3000003)
Can not get mouse to move and buttons will not work on keyboard. batteries are all good
  • pittyrandj Jan 23, 2009
    nothing works with all combinations,switched off all wireless ADSL, all I get is a light if I press F.lock key, also does`nt work on another computer, also I sent the first set back marked faulty, other wirless desk set (Belkin) works perfectly.OS Win. XP.
  • Anonymous Feb 05, 2009
    same problem here
    President:
  • 8,637 Answers
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Posted on Jan 20, 2009
When I push the reciever button then the button on the mouse and keyboard the flickering lights on reciever go out.I`ve spent hours trying all combinations to no avail, this is the second new set that does`nt work, I might as well scrap the lot and keep the Belkin
Posted on Jan 25, 2009
I have a logitech wireless mouse and keyboard (7 months old)- I recently moved my computer and when I hooked verythign back up it no longer works- I have tried everything from restarting, plugging the...
Underneath the mouse and the keyboard will be buttons labeled "Connect", you will need to resync with the receiver plugged into your computer. Press the connect button on each device in turn and it will attempt to resync.
If this does not work the next thing is to test with fresh batteries, however it is unlikely that both the keyboard and the mouse would run out at the same time.
Finally try with the receiver right next to the keyboard/mouse, sometimes other devices can interfere with wireless signals (WiFi networks, microwaves, vacuum cleaners etc...).
Feb 28, 2011 | Logitech Cordless EX 100 Mouse
My mouse was working fine but then the mouse was not moving like every time I move the mouse the mouse on the screen wont work.
Have you checked the battery for the mouse? Try a new battery and see what happens? Also make sure you find the little button on the mouse and hold it for a few seconds to turn on! If none of these work; the laser is probably damaged.
Good Luck,
kc
Feb 22, 2011 | Microsoft Wireless Notebook Optical Mouse...
Logitech mouse is'nt working
You might try re-syncing the mouse with the wireless sender. Push the button on the sender (plugged into usb port usually) and then push the button on the bottom of the mouse.
Aug 02, 2010 | Logitech Cordless Mouse
My mouse was just working and all of a sudden it stopped, I changed the batteries, reset the small button on the bottom and also pushed the button on the plug in portion. Help Allen
I have a miscrosoft wireless laser mouse 6000, and it also stopped working on my laptop. I changed the battery, still not working. I tested the battery in another device, and it was good. I moved the mouse to another computer, and it did not work. The light on the usb connector was lit. [No changes at all to my laptop.]. It seemed like there was no power to the mouse, and I looked at the contacts inside the mouse. The contact just inside the battery opening appeared to be bent down away from the contact on the battery tray. So, I pulled it up a little so it would connect when the battery drawer closed, and (after tweaking it a couple of times), it finally worked!
Dec 08, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
Wireless keyboard and optical mouse
Thanks! I fixed the problem by installing a USB mouse and using fn+f9. That unlocked the mouse so I could use the pointer leaving just the keyboard problem. I then tried reconnecting the wireless keyboard (by using the button on the receiver and under the keyboard) Hey Presto!!
Feb 02, 2009 | Logitech Wireless Access Duo Optical...
LX 500 Keyboard not working mouse fine
Normal 0 Assuming that you have good batteries installed, turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try to see if it is working. If not try pressing the button on the receiver and then on the keyboard.
Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Dec 29, 2008 | Logitech LX 700 9674180101
Targus AMW15US wireless mouse
First are the batteries good?
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Dec 16, 2008 | Targus AMW15US Mouse
Mouse stopped working, but appears ok, batteries ok, can't determine problem
Is the batteries good. If so try,
Jun 08, 2008 | Logitech Wheel Mouse Optical
My Iogear mouse wont work
In order for you to make the mouse work with your computer, please try the steps below:
1. Make sure that you're using fresh batteries.
2. Make sure that the mouse is turned on.
3. Hold down the connect button on the receiver (the mouse cradle) and hold down the connect button under neath the mouse at the same time for five seconds and then release the buttons.
4. Try moving the mouse around and that should work.
Apr 15, 2008 | IOGear (GKM521R) Keyboard
Microsoft Optical Desktop 1000 (BV3000003) Logo
523 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
