Question about Olympus Cameras
Dead olympus ds-2
Batteries new, terminals clean
  • Anonymous Oct 06, 2019
    Burial or cremation ?
    Top Expert:
  • Olympus Master
  • 64,245 Answers
Batteries in the proper direction?
Posted on Oct 06, 2019
SOURCE:
  • 919 Answers
SOURCE: need to download to PC the Olympus DS-2 software
http://www.olympusamerica.com/files/DSSPlayer.zip
After unzipping the file, click on the SETUP.EXE file to begin installation.
License key: 8360 0121 0002 6901 5480
Download update 7.1: http://olympusamerica.com/files/DSSV7UP2EN.zip
Posted on Mar 16, 2009
  • 919 Answers
SOURCE: Olympus D560 - the lens will not extend, the
The problem you are describing is a problem with a sensor in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $87 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Posted on Jun 17, 2009
  • 571 Answers
SOURCE: put new batteries in Konica Minolta Maxxum 70 and
Are the batteries in the right way?
Posted on Aug 18, 2009
SOURCE: Canon SX 100 IS won't go on, at all. Not yet 2
My Canon SX100 IS doesn't power on. I tried using several batteries and also cleaned the metal battery contact but nothing works. Any advice ?
Posted on Mar 21, 2010
asood23
  • 200 Answers
SOURCE: put in new batteries and it still says low
Which batteries you put in it?
Digital camera use a lot of battery and can't run on normal AA batteries. You need rechargable batteries minimum 1000 mah. 2000 mah would be good. Try these batteries and your problem will be solved.
Please rate the answer. Thanks.
Posted on Jun 22, 2010
Why won't my DateXX DS-883 Graphing Calculator work, it has new batteries?
Try a Q-Tip soaked with alcohol and clean the battery terminals. Also, WD-40 works well to. If batteries are left in too long after a total discharge, it can produce acid which will eat away the plating on the terminals. If that's the problem, WD-40 is the best choice to use.
Sep 05, 2014 | DateXX DS-883 Calculator
I need to install my software for my olympus DS 2400 dictaphone to my new laptop and dont have my serial number? how can i get it back?
Serial numbers are usually on the machine...try looking in the battery compartment after removing the batteries.
Nov 18, 2010 | Olympus DS-2 Digital Voice Recorder
Olympus ds-2400 voice recorder is saving files as ds2 - how do we convert them to dss
The DS-2400 were one of the first Olympus DVRs to use the new DSS Pro (.ds2) format.
We later discovered that you will need to update the firmware to in order to have it revert to the standard DSS format (.dss)
You will need the DS-2400_FirmwareUpdate_DssClassic to make this happen. All certified dealers will have access to this firmware update.
Stay classy,
Josh
Jan 29, 2010 | Olympus DS-2 Digital Voice Recorder
The new button on my digital recorder is not working
Olympus will charge a flat rate repair fee for this product. The cost is $96 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
You may want to call Olympus Customer Service to discuss how you send it in to them for repair. Their telephone number is 800-622-6372 option 2 and then option 3.
Mar 17, 2009 | Olympus DS-3000 Digital Voice Recorder
"battery empty" on screen after I disconnected camera from compu
Hi, have olympus fe-280 camera. Battery on screen shows full but shows empty (an inch strip) in middle. I have charged it. Even bought a new battery. Can anyone help. Thank you. ...... I want thinking I may have two faulty batteries and just need to buy another one?!
Jan 25, 2009 | Olympus FE-280 Digital Camera
Power
try using alcohol solution to clean and then let air dry for at least one hour before inserting batteries in
Jul 06, 2008 | Olympus FE-210 Digital Camera
Problems with memory on Olympus DS-2
I've had the same issue. The surefire solution is to go into the Sub Menu and FORMAT. It wipes the entire internal memory clean -- so be sure you've offloaded everything you need. You'll also need to reset the recording quality, if you have a custom setting, because it defaults to the highest quality. But you'll have all your space back.
I believe when files are deleted via computer, the DS-2 doesn't update itself to recognize the space is freed up. That's why data is gone but memory is not freed.  Good luck.
Mar 07, 2008 | Olympus DS-2 Digital Voice Recorder
I lost original CD for DS-2; how to get software?
olympusamerica.com/files/dssplayer.zip is the download link for DSS player but you will have to call Olympus for a replacement key. I have found it works best to SAVE and then install the download. They did not give me a hard time about getting a new key.
Feb 09, 2008 | Olympus DS-2 Digital Voice Recorder
Why my camera wont turn on?
Hello.
When the two led's blink, that is telling you that the batteries are dead. Try replacing the batteries with FRESH ones and that should help.
NJ
Nov 24, 2007 | Olympus FE-115 Digital Camera
Olympus digital camera wont turn on
First: thank you, for suggesting battery terminals. It was failing to power on intermittently for some time; the problem became more-and-more frequent until it would not come on at all. Cleaning the terminals saved my camera! Second: for others, let me suggest plain old pencil erasers as a good way to clean electrical contacts (something I learned from HO model railroads as a kid). A vigorous rub with the brand new eraser on the end of a pencil cleaned the battery contacts inside the camera.
Mar 20, 2006 | Olympus Camedia C-350 Digital Camera
Cameras Logo
22 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
