Toshiba 50H13 50 in. Rear Projection Television
Problem for Toshiba 50H13 50 in. Rear Projection Television
Hyper Module repair on 50H13
By jcwalz on Sep 16, 2009
I am having the dreaded hyper module problem with my 50H13 TV. Yesterday I replaced the 11 SM caps with 10uf 16v electrolytic capacitors (link below)
http://www.mcmelectronics.com/product/DISTRIBUTED-BY-MCM-16V-10UF-MINI-SM-/31-8210
They were almost identical to the originals. After the repair when I turned the set on, it worked great for about 10 minutes. Then it went back to its old ways. Any suggestions on what might have gone wrong or if those caps are just not up to snuff? I'm thinking about trying some higher voltage/heat rated caps. Any suggestions would be greatly appreciated!
Jake
Solution #1
posted on Sep 16, 2009
Not Rated)
djeletronics
Rank: Guru
Rating: 91%, 72 votes
you need 2 check all the caps on hyper bwd.last one i did had 31 or 32 bad SM caps
change all----22mf---2.2mf---1mf---10mf
carefull not to lift traces
Was this helpful?
Yes
No
Popular Solutions for Toshiba 50H13 50 in. Rear
Questions and Unsolved Problems for Toshiba 50H13 50 in. Rear
Do you recommend Toshiba 50H13 50 in. Rear Projection Television?
Answer
Answer
horz lines flicker on both sides of tv and a little blurry
Answer
i have a sony trinitron tv, model no. KV-28LS36U. it seems that the image on the screen is too big... (More)
Answer
After looking at some signals it appears that Q510, which is a TA1360N (Mod) is bad and running hot.... (More)
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
