Question about Projection Televisions
Samsung picture problem.
My samsung sp46l5h lcd rear pro tv displays ok for 15 mins then picture scrambles into a mush of horizontal lines and colours. if i switch off and allow to cool down picture goes back to normal until tv warms up again. i opened it up and found 1 fan not spinning and fixed it. now all three fans work but still this problem. any ideas?
  • 192 Answers
SOURCE: HDTV Rear Projection
The color wheel is the most common problem when it comes to noise from DLP's. To determine if it is a color wheel or fan: Turn on the set. When the noise starts, turn off the set. If the noise goes away within 5 seconds, then the color wheel is bad. If the noise goes away after one to one and a half minutes after the set was shut off, then one of the fans are making the noise.
Posted on Apr 01, 2007
  • 4402 Answers
SOURCE: Mitsubishi VS-50707 - Scrambled picture
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Posted on Dec 15, 2007
  • 8617 Answers
SOURCE: 50" Samsung dlp rear projection hdtv
More than likely its the color wheel there is a bulletin from samsung indicating that a loud buzzing is often related to the color wheel.Let me know if you need to know where to get a color wheel and I will post a link, just include your full model number.
Posted on Apr 14, 2008
  • 1922 Answers
SOURCE: Rolling lines until tv warms up
probably the circuit board needs to expand and you have cold-solder joints on it,after board and joints expand they make connection,just wait though this will go the worser of two evils and get progressively WORSE, take it out and re-solder all joints on the DEFLECTION BOARD SOON
Posted on Sep 27, 2009
Mas Baz
  • 177 Answers
SOURCE: Samsung HL-S5087W (" CHECK FAN # 1") is displayed
hello Harley,
Lamp # 1 is lamp fan, Lamp # 2 is DMD board fan.
Lamp # 1 is located behind the lamp.
Pull assy angine out you will fine fan # 2 , clean it or replace it if not rotate properly.
Fans displayed on screen because fans are dirty or air flow not smoothly.
Good luck.
Posted on Mar 30, 2011
Testimonial: "THANKS "
  • 1030 Answers
SOURCE: When we turn on the
Very common problem. not a common or easy fix though. This is known as a faulty "hypermodule" The hypemodule is a cuircit board that processes the signal. At the shop i have repaired a few a these on average 2 a month. The ideal situation is to replace this cuicit board. However this was such a common occurance these boards became rare. very hard to locate. So toshiba gave service centers another option a way to repair these. It however evolves the replacement of 11 very small micro capacitors. Only the most experence tech's experenced in surface mounted soldering should attempt this repair. You can easly mess this board up and once messed i said you cant find them. My best advice is to find you a qualified shop who has done this repair before. It take an experence tech around 3 to 4 hours with magnifing glass and twezzers. My shop generally charges about 300 for this repair but shops vary based on experence
Posted on Jun 05, 2011
Testimonial: "Sounds very useful, now I just need to find a suitably qualified tech. Thanks for posting a reply so fast."
0 characters
1 Points
Picture is scrambled after power surge. Have a
Check if it has a scrambled image on all sources ie - DVD- VCR - cable/satellite box. Since the PIP is normal it sounds like the signal source is bad.
Post back with more info about your set up (what's hooked to your TV) if you need more info
Nov 28, 2009 | Samsung HL-R4667W Rear Projection...
Horizontal lines in the picture.
Give it time to warm up like another 10 to 15 mins i find put a tv guide channel on the screen stays pretty much the same picture, then leave the TV on" i use a 4 hour rule if i dont view in 4 hours or more i will close tv power
Oct 07, 2009 | Mitsubishi VS-60705 60" Rear Projection...
Picture is compacted vertically in center of screen redgreenblue
your vertical hold is out on the tube. new tube is needed. cheaper to get a new flat panel tv.
Jul 19, 2009 | Samsung HC-P4752W 47" Rear Projection...
Samsung HLP5063W 51 inch DLP is 4 years old. Screen scrambled?
there is a complete section in the tv that translate the different resolutions from the different out side video sources you normally use to the TV native resolution. That area has to be replaced. Is a module repair needed. Don't get scare. now days this kind of repair is normal and has to be included in the repair price to see if is economical to repair.
Mar 19, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
My Samsung LN-83251D is not working properly. Instead projecting a picture, it just displays bars and lines. Is my LCD TV broken?
Jul 06, 2008 | Projection Televisions
White horizontal lines on screen
Replace all electrolitic capacitors on the Proscan pcb.
Dec 11, 2007 | Projection Televisions
Projection Televisions Logo
41 people viewed this question
Top Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you a Projection Television Expert? Answer questions, earn points and help others
