Reset password BAUHN lcd TV0000 does not work how to do a factory reset
The TV works fine but can't tune channels because of unknown pass code Dennis
    Top Expert:
  • Televison & ... Master
  • 10,321 Answers
Go into set up and reset to factory settings
Posted on Oct 05, 2019
SOURCE:
  • 579 Answers
SOURCE: tuning in the tv
Most TV's auto search feature will try both the Cable and the Air frequencies, but perhaps yours doesn't. Go to the menu page for tuner setup and make sure it is set on Air (might be called broadcast) and then run the channel search.
Cable channels and Broadcast channels (above channel 12) are not the same frequencies.
Hope Ya Fix It!
Posted on Jan 10, 2008
  • 3 Answers
SOURCE: Vason 10.4 inch portable tv tuning problem
I returned my original TV/DVD to the suppliers who then sent me a new one.
I experienced exactly the same tuning problem with the new TV.
The only way I could tune it, was by using the fine tune facility to find and store the missing stations. This took a lot of time and continuous button pushing, so patience is essential.
Once found and stored, the previously missing channels are perfect.
It would appear that the DVD player doesn't like DVD- recordings from my home recorder. If they are re-coded they work.
Anything recorded on DVD+ is fine.
In my opinion this is a good unit let down by a couple of niggling faults.
Posted on Mar 23, 2008
SOURCE: How to disable parental lock
Go in and reset the code.
Posted on Oct 06, 2008
stihl_070509
  • 95 Answers
SOURCE: Sony bravia v series 32"
hi,
IT normally happens after factory reset is done. You need to reprogram the channels. Try the auto program (AUTO TUNING) Process.
  1. On your remote commander " Press HOME or MENU button"
  2. Scroll down to " SETTINGS or SET-UP"
  3. Then to "CHANNEL SET-UP"
  4. Select " AUTO PROGRAM " To Auto program your LCD TV and it's done..
Posted on Jan 05, 2011
budmrtn
  • 11361 Answers
SOURCE: I NEED THE 4 DIGIT FACTORY RESET PASS CODE THAT IS
LG back door code are 7,7,7,7.
http://www.fixya.com/support/r5632478-lock_unlock_most_tvs
Hope it helps otherwise you have to contact LG.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Jun 25, 2011
One station only has lost sound but piture is great. All other channels work fine.
Have you tried retuning the TV? You may need to do a Full Factory Reset tuning rather than just a rescan.
Rescan simply looks at the place holders where the old channels were stored and refreshes them. A Factory Reset (A.K.A. Shipping Condition) wipes the channel memories and starts again fresh.
Sep 09, 2014 | Hitachi Televison & Video
One Station only no sound but great picture. The additional digital channels with that station work fine.
Some of the channels have moved. So your TV might be picking them up differently. You need to do a Full Factory Reset tuning rather than just a rescan.
Sep 09, 2014 | Televison & Video
Why can I only tune in one channel
Tuner fault. Check and replace it. Do a reset to this TV first, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Aug 07, 2017 | Televison & Video
LG37LG5020
hi. that:s be reset factory could do. if no you need a technician . good luck!
Sep 07, 2012 | LG 32LG30 32 in. LCD HDTV
Factory reset was reset---now we have a no signal on the screen
Please go to tuning menu and select Auto Scan/ Auto Tuning to tune all available channels to store in tv memory.
Factory reset actually delete all data/ settings in memory chip and set tv as it was in-box.
Thanks.
Jun 13, 2010 | Olevia 237T 37 in. LCD TV
Trying to get local channels through an external antenna I cant get the tv to switch from cable to air. Also, I never programed a parental control password. Is there a factory preset number? I wanted to...
No,must ask Sharp,reset back to factory will not reset password,only setting.Tv should set simple password to easy to remember that the best.Can't switch back to free air,because the password stuck in cable mode.
Jan 10, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I need to reset a Aiko STB255 Standard Definition Set Top Box to factory settings. I have no manual. Could someone with a manual give me the steps to take. It was working fine but I tried to tune it to...
LOAD FACTORY DEFAULT (from owners manual) Reset the STB back to factory settings 1. Enter 'Tools' menu. Highlight 'Load Factory Default' 2. Press the 'OK' button. You will be asked to input the password 3. Input the password using the numeric buttons (default is '0000') 4. A confirmation window is displayed. Highlight 'Yes' to confirm. STB will return back to factory settings and clear all channels 5. Press the 'MENU' button to exit
Dec 26, 2009 | Televison & Video
Sharp LC-52D62U HDTV won't tune-in channel 21.
Sounds like the signal is probably too strong. The TV is not the problem.
Jan 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Samsung LE40R73BD DTV freezing, wont chnage channel
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK (it did for me)
HTH
Oct 24, 2007 | Televison & Video
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
Ekse
