Question about HP Officejet 4215 All-in-One Color Photo Ink Jet Printer
Label Printing Problems
Printing labels on an HP 4215 All-in-One. Label set up is correct, and has printed correctly on previous occasions, but currently the page of labels appears to slip, and print starts above top label margin. Printing to plain paper puts the label contents in the correct location. Any clues? Thanks
  • Anonymous Jan 22, 2008
    Hi
    Have exactly the same problem and have spent hours trying to fix this - any help gratefully received!
  • Anonymous Jan 22, 2009
    I have the same problem. I am using Vista w/ Word 2007 on a C4280 HP All In One Printer.
    I also have the same problem on my XP an another HP All In One Printer.
    Problem Solver:
  • 18 Answers
Your problem seems to be due to worn out of rollers. Try a less glossy paper and you can find the difference.
Posted on Mar 18, 2008
Label printing
you'll need new drivers for vista...get them here
Mar 20, 2008 | HP Officejet 5610 All-In-One InkJet...
Ribbon not printing correctly on new labels have a sato CL412E and we are using the same ink ribbons we always use (premium wax/resin ribbon TRX-55) and we just started using new labels from a new company...
The ribbon / label combination usually doesn't have anything to do with print position of the fields on the label. Is the quality/durability of the print that you are seeing on the new labels the same as before ? With a glossier stock print quality should actually be better. This will at least tell you that the ribbon is correct for the new label stock. Is the new label a different size than previous labels ? That could account for the fields not printing in the correct position if the printer is not calibrating correctly on the new size.
Not sure if this will help but may give some ideas...
Apr 07, 2010 | SATO Cl412e Label Printer
My 2600n is ghosting when printing black and labels are not printing correctly, the ink does not stick to the label, any ideas?
Sounds like a fuser problem.
Check the hp website, there was a firmware upgrade for fixing problems.
This may help, but you may also have a more involved problem...
Check print out on plain paper, and print the configuration page.
Dec 18, 2009 | HP Color LaserJet 2600n Printer
Eltron 2844 prints previous job over and over
Make sure the label size is correct, if the print encounters a gap before it is complete; it will re-print the same label. In MS Word make sure the page size is set to the correct size including any headers and footers and Width etc.
Sep 17, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Epson LQ 590 Label Problems
Make sure the option for bidirectional printing is set correctly.
Try it both ways
Make sure you are not printing too far to the left or the right - the print head can hit the end of its run and lose its place.
Mar 27, 2009 | Epson Dot Matrix LQ-590 Printer
HP Deskjet F2180 Margins incorrect for label printing
I eventually managed to print my labels one sheet at a time by forcing the label top edge down the page. You can insert one or two lines above the label template and adjust the font size to get the right distance. It took a bit of trial & error but got there in the end. Hope it helps you
Dec 08, 2008 | HP DeskJet F380 All-In-One Printer
Labels print out of center
the important thing is if you are using different type labels and sizes before printing see to it that the labels must properly calibrated..to avoid printing incorrectly
Jun 04, 2008 | Zebra Stripe S600 Thermal Label Printer
Paper feed
The feed rollers are slipping on the surface of the label, causing the page to load incorrectly. There is no permanent solution at this time. Try one of the following workarounds to correct this issue. Workarounds Workaround 1 Adjust the top margin using Page Setup.
  1. Click File , then Page Setup in the program being used, (accessing Page Setup may vary from program to program. Refer to the Help file for that program).
  2. Adjust the top margin until printing is correct on the label.
Workaround 2 Manually print one sheet at a time. Place one sheet of labels in the input tray at a time, printing only that page. Repeat for all pages of labels needed.
Nov 20, 2007 | HP PSC 1210 All-In-One InkJet Printer
184 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
