Clean front panel Contact switches you will have to remove front middle board holding . Use contact cleaner only.You also could have capacitors going bad cp150 cp114 cp120 on deflection board cp150 is 2200uf 16v other 2 are 220uf 35v.
What do you mean that it wont stay on? Does it turn off and on during cooking? Does it just go off and wont come back on? The oven thermostat regulates the heat in the oven and the oven element and the oven indicator light will turn off and on during cooking. If it stayed on constantly on full oven element power everything would burn.
to get it to stay on charge it all up make sure that the on button is slided fully to the on then take out charger it will stay on if you turn it off it wont go back on it has to stay on happens to me
The pump is not supposed to stay on, you should only hear it for a second or two when the ignition is turned on. At least you know the pump is working. There must be a problem in the ignition system, like no spark, do to a bad coil, ignition module, without testing it's hard to say.
did you let the fridge stay in it's new place for 24 hours up right before turning it on?
Try turning it off for at least 24 hours and start it back up again.
If you moved it on its side the compressor oil flows into the lines and must beable to drain back down before using it.
If not you'll seeze the compressor.
not good.
