Question about Fuji FinePix S3000 Digital Camera
Cannot take pictures anymore and lost my pictures in memory card.
Hi, I try to take pictures and right after I press to capture, "WRITE ERROR" appears in the screen inside a red square
On the top left corner, there is a symbol that I cannot really make out.It looks like a person and a big letter A also in a red square.
It always tells me that there is no image.
What does it mean. I never had problems with the camera and this is troubling me. I am trying to download the instructions.
HELP
Thanks
Claudette
  • 4 more comments
  • clo clo Dec 12, 2007
    After consulting the manual on line, I think that the problem is that my XD Picture Card is write protected.
    I am told to remove the write protection.
    How do I do so?
    Thanks
    Claudette
  • clo clo Jan 13, 2008
    Thank you very much Leo2.
    Claudette Teoli
  • Anonymous Mar 05, 2008
    excatley the same problem write error with a hand sign in corner? not letting me take any pictures at all!
  • Anonymous Aug 25, 2008
    how do you remove card protected?
  • Anonymous Mar 16, 2014
    in left hand corner of screen
  • Anonymous Mar 29, 2014
    There is a red square with a picture of a white camera inside it in the top left of my camera. What does it mean?
    Master:
  • 619 Answers
Hi , the only remedy to remove write proctection is to transfer or download all pictures to computer or rewritetable cd,
Format the sim card and donnot set again to write protection the picture .
Protect are located in play menu ,navigate downward you can see protect .
Posted on Jan 13, 2008
DV-136ZB can't take pictures to my computer.
Are you trying to transfer videos from your camcorder to the computer, or use the camcorder to create pictures directly on the computer ?
Jul 26, 2017 | Global New Beginnings DV-136ZB Camcorder
When i turn on my camera it says the memory card needs formatting i follow the instructions but it doesnt work and keeps saying to format the memory card. this happens over and over and i cannot take...
To understand the photo loss situation, consider a scenario: You format a memory card in Digital Camera, and start to capture some pictures. However, while capturing pictures, your camera shuts down due to low battery. Now, after recharging battery, when you try to access those photograph on the card, you receive the following error message on camera screen:
The Card requires formatting: Additionally, the camera is unable to capture any new photographs.
The main cause for the above error message is corruption of memory card due to conking of battery while a read/write operation was running.
These memory card needs to be formatted before you save any new pictures. It is always a good practice to take backup of card and format it before use. This enables you to fight with any damage done to the memory card and to erase the old data saved on the card. However, the probability of card getting corrupted again (after you have saved new data) still exists.
First try formating with an external SD Card reader connected at PC and test it.
Oct 13, 2011 | Kodak EasyShare C143 Digital Camera
My memory card keeps saying error what is the matter
- First identify the type of card, some memory card has lock or adapter. - Second, check the condition of the card.
  • Locked switch position
  • Visible discolorations or defects such as crack or nick in the card
  • Missing contacts at the end of the card
  • Deep scratches in the card contacts
  • Heat discoloration on the card
- Next, sure that the file format of the picture is supported by your printer - Then, try to save the file on your computer (If the computer can't read the memory card, the card might be causing the problem, you might contact the manufacturer of the card or replace the card) - If you successfully save the file on the computer, try other device like camera etc. - Format the memory card and try to capture an image and check if the file is corrupted or not. - If an error 'Unsupported Image File' appears, the memory is defective. try replacing the card or contact the manufacturer for further troubleshooting. - If the image displays properly, reinsert the memory to the printer. If the same error appears again, try using another memory card. - If the new memory card has the same issue try the steps provided above. And if the same error appears again after doing the steps call HP support to service your printer.
Apr 10, 2011 | HP Photosmart 8450 InkJet Printer
Is San Disk memory card compatible with Digimax 401 ? I inserted one and got the message card errior.
SD Memory Card is compatible with your Digimax 401 camera. You just need to format the card.
Formatting a memory card
** This is used for formatting the memory card. If you run [FORMAT] on the memory card, all
images, including the protected images, will be deleted. Be sure to download important
images to your PC before formatting the memory card.
** If the memory card is not inserted, the internal memory will be formatted.
** Be sure to format the memory card if you are using a newly purchased or non-initialized
memory card, if it contains data that the camera cannot recognize, or if it contains images
captured with a different camera.
Formatting a Memory Card
1. In any mode other than Voice Recording mode, press the MENU button.
2. Press the LEFT/ RIGHT button and select the [SETUP] menu tab.
3. Select the [FORMAT] menu by pressing the UP/ DOWN button and press the RIGHT button.
4. Select a desired sub menu by pressing the UP/ DOWN button and press the OK button.
- If [No] is selected : The memory card will not be formatted.
- If [Yes] is selected : A [PLEASE WAIT!] message appears and the memory card will be formatted. If you ran FORMAT in Play mode, a [NO IMAGE!] message will appear.
Apr 12, 2010 | Samsung Digimax 401 Digital Camera
Memory Card locked
this solution is from a another website about card error... i dunno if this will help fix ur problem but i hope this will give u idea how to fix it... okay.. tell me if this works, coz a lot of people were encountering the same prob as u.. thank God i havent encounter this error...good luck..
Troubleshoot:
Memory card is used by digital camera to store the photos it takes. Popular memory cards include SD card, CF card, xD-Picture card and Memory stick. For some reasons, memory card may get damaged on power shortage, or removal of memory card on picture shooting or viewing, or other various and unknown reasons. Usually, you will see error message like "memory card error", "card locked", "card error", or an error code on your camera screen and the valuable pictures on the memory card could disappear and be lost. Some cases, your camera or Windows may prompt you to re-format the memory card and refuse to take new pictures or view old pictures.
Solution:
Once you have your memory card damaged, it is highly recommended to stop further operations on the memory card (e.g. taking new pictures, or delete, format the memory card). Data recovery software like "CardRecovery" is able to recover the lost pictures in most cases.
First, you need to confirm your memory card can appear as a drive letter in "My Computer", which will allow recovery software to access and recover the lost photos. You may try to connect your digital camera to your computer, if a new drive letter appears in "My Computer", it is OK. Otherwise, you need to prepare a USB card reader. There are many card readers available in market (e.g. SanDisk and Kingston). You can buy one from Amazon or BestBuy.
Then, you may download and install CardRecovery to your computer. Launch it from Start Menu -> Programs -> CardRecovery. You select the drive letter of your memory card, and destination folder for save the recovered files. CardRecovery will scan your memory card and locate the recoverable pictures. The process is quick and easy. Usually it takes less than 15 minutes.
Can I re-use the corrupted memory card?
For data protection, CardRecovery performs read only operation on your memory card and it does not change the data on the memory card, so it does not repair or fix the memory card. If you need, AFTER you have recovered your lost photos from the card, you may try to format the memory card before re-use. It is suggested to perform enough read/write test before using it again to take new pictures. If you are worrying that the memory card is unstable and may cause further data loss, purchase and use a new memory card. Your valuable and irreplaceable photos are more important than memory card. Memory card is very cheap. A new 2GB SD, CF or xD card is less than $10.
credits: www.cardrecovery.com
Sep 13, 2009 | Canon PowerShot A75 Digital Camera
Memory card error
from cardrecovery.com..
alot of people encounters this prob... hope this will help u.. but im not sure if it will fix the problem..
but again 9sure u already did this) check the slide or card rotection of ur card, then check also the slot on the cam where u put the card -- there was a thread about this , like u can pick it with papaer clips blah blah not sure how he did it, it worked for him but i dont advise it bec pis are very sensitive so just dont do it...
here is it... solution from cardrecovery
Troubleshoot:
Solution:
Sep 13, 2009 | Canon PowerShot A620 Digital Camera
Memory card locked
this is from cardrecovery.com... whew a lot of people get this error... hope all of u resolves this..
but before u truobleshoot for recovery of pictures, check first the slide on your memory card (card protection) slide it both ways and check it... someone advices from a thread to use paper clips to pick the slot of the cam where u put the card, it work for him but i think its not a good idea coz it may damage the slot.. okay.. if there is still an error u can bring it to a tech person (canon support service) or just try to recover ur files...
Troubleshoot:
Solution:
Sep 12, 2009 | Canon PowerShot A470 Digital Camera
Whenever i take a picture and press to review it says file error
Hello!!
Try formatting ur memory card once and reload it ...
Apr 20, 2009 | Samsung Digimax S630 Digital Camera
SD cards have a little slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Aug 25, 2008 | Vivitar ViviCam 8300s Digital Camera
Cannot capture image
TRY REPLACING YOUR MEMORY CARD
Sep 17, 2007 | Cameras
Fuji FinePix S3000 Digital Camera Logo
82 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
