Question about Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator
Loud banging noise and water leaking
I have (2) issues with my Kenmore ColdSpot w/Ice maker refrigerator, Model # 7286-2100, Serial # EL3716365, manufactured 09/01. Fist of all the fridge makes a very loud banging noise when it shuts off. I've checked the compressor mounts & looked for any lose objects or anything touching the compressor. Can't find anything wrong. From what I've read about this problem I assume my compressor is going bad. The fridge was purchased in 01 and had been making this noise for about (3) years. Shortly after it's warranty expired (go figure). Also, it seem to be getting progressively louder. Any suggestions/fixes short of replacing the compressor and/or the fridge to fix this problem? My other issue is with the freezer drain. About 2 months ago I discovered water on the kitchen floor in front of the unit. When I removed the freezer floor, the entire freezer floor & drain were frozen. I used a hair dryer to thaw-out both the freezer floor & drain. I then took very hot soapy water (with use of flexible tubing left over from my ice maker installation) and poured it directly down the drain & verify it was open (thawed). The water ran into the drip pan. Thus I thought the problem was solved. Now, 2 months later, I have water in the bottom of the fridge again & the freezer drain is once again frozen. I just repeated the above fix & the fridge seems to be working ok. I've read about a Defrost Drain Strap Kit (part# 726493 for Whirlpool's available from ApplianceAid.com) to prevent this problem. Is this something that will work on my Kenmore, I think it's mfg'd by Whirlpool, all the parts listed begin with a 106, thus my fridge is a 106-7286-2100. If it will work, how difficult is it to install? Or should I check & replace the defrost timer (Kenmore part #2193084). I've read in some previous answers that suggest taking a wire & running down the drain tube. I haven't tried this for 2 reasons, 1) after I've thawed the drain plug & ran water thru the drain tune it pours down to the drip pan, thus appears to be clear of any obstruction, 2) it's difficult to get to, the drain tube is internal & clear in the back of the freezer below the evaporator coils. Finally, is it possible that the 2 problems are related & should just purchase a new fridge? If so, who do you recommend? I'm single thus my refrigeration usage is very low or at best moderate. I'll never purchase another Kenmore/Whirlpool so please don't recommend those. Thank You
  • 410 Answers
First of all the noise is the internal compressor motor hitting the steel shell on shut down. in my experience this is annoying and not really a huge concern as far as the compressor dying any time soon. now your drain problem. i would recomend the wire or heat probe that whirlpool recomends. when your freezer defrosts the water that drips off of the coil can and will flash freeze in the drain area causing it to freeze up a peice of 10 or 12 guage solid copper wire run into the drain and wrapped around your def heater will transfer enough heat into the drain hole to prevent it from freezing up.
fwiw: whirlpool in my opinion is probably one of the best appliances on the market..
Posted on Dec 13, 2007
What would cause my Kenmore Coldspot ice dispenser to freeze up where the water enters from the tubing into the ice maker itself?
Small leak in the tubing. remove ice-maker, cut tubing about half an inch back and reconnect ensuring the tubing is completely on the ice-maker.
Jul 05, 2016 | Kenmore Refrigerators
Kenmore coldspot model 105-56532400 ice maker leaking water. How to fix?
The water supply solenoid valve may be malfunctioning or the fill tube to the icemaker may be mis-positioned.
Mar 01, 2015 | Kenmore Refrigerators
Kenmore coldspot model 106 9445781 the icemaker motor makes loud noise. Sounds like its under a heavy load.
Suggest you take the ice maker out and defrost it. You propably have ice crystal buildup and causing it to labor harder.
Jan 16, 2012 | Kenmore Side by Side Refrigerator
Getting water
I have Kenmore Coldspot refreidgerator and am having a problem with water pooling inside the fridge at the bottom underneath the drawers (mostly the left side). Where is the water coming from and it formed a thin ice.
Thanks
Nov 25, 2009 | Kenmore Refrigerators
Kenmore coldspot refrigerator model #106 RUMBLING!!!
Does it have automatic ice cube maker not hooked up to water? If you do make sure thin stainless bar isn't straight down. on the side of ice maker.
Nov 15, 2017 | Kenmore Refrigerators
not much can be done about compressore noise, short of replacing it. but your drain issue is easily fixed, with that whirlpool heat strap you mentioned.it actually wraps around the heater in frezer section and the idea is that when the unit goes into a defrost cycle(3 or 4 times a day) the heater heats the strap(which runs into drain tube) up as well, preventing tube from freeezing up and eventually backing up into your freezer floor
Feb 23, 2008 | Refrigerators
first of all the noise is the internal compressor motor hitting the steel shell on shut down. in my experience this is annoying and not really a huge concern as far as the compressor dying any time soon. now your drain problem. i would recomend the wire or heat probe that whirlpool recomends. when your freezer defrosts the water that drips off of the coil can and will flash2.gif freeze in the drain area causing it to freeze up a peice of 10 or 12 guage solid copper wire run into the drain and wrapped around your def heater will transfer enough heat into the drain hole to prevent it from freezing up.
Dec 16, 2007 | Refrigerators
Kenmore side by side refrigerator
Check the water valve in back of refrig.. u have a double valve... one side for water the other side for your ice maker.. make sure ice maker valve is working.
Sep 11, 2007 | Kenmore 57029 Side by Side Refrigerator
Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator Logo
428 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
