Question about Maytag Washing Machines
Maytag Neptune 5-7 yrs old stopped working, no power going in the machine. Outlet is working with other appliances. Not sure if it is the control panel or the electric cable. Suggestions pls. Thanks
    Top Expert:
  • Maytag Master
  • 10,321 Answers
If voltage to switch inside possible bad transformer check voltage if ok possible bad control board
Posted on Oct 10, 2019
SOURCE:
  • 183 Answers
SOURCE: Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Posted on Dec 27, 2007
jomabug76
  • 1148 Answers
SOURCE: Maytag neptune dryer
Hey white to white, black to black red to the multi colored pole, and the green one is the ground wire,, . I done that before,, lol,, good luck ,, thanks
Posted on Oct 05, 2008
dh1200s
  • 335 Answers
SOURCE: how to get front panel off neptune fav6800aww washing machine
Just a quick search in this forum fot "Front Panel" returned this post which says it better then I could.
http://www.fixya.com/support/t538238-remove_front_panel
Posted on Jan 18, 2009
  • 99 Answers
SOURCE: LEAKING WATER ,LOOKS LIKE THE BOTTOM OF MACHINE
this is joyce
Have you checked to see if the pump may have a small leak, if not then you may just have a hose that is leaking, other than that theirs not to much more to go wrong. maytag is a good brand I have one but I would not put up with a leak of any kind, it will ruin your floor.
if you cant find the leak I can help find you a techn in your area that may can come to check it out for you if you need me to. just let me know.
joyce
Posted on Feb 07, 2009
  • 219 Answers
SOURCE: maytag neptune reading 2E will not work
2e means u have abad motor
Posted on Apr 09, 2009
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune front loader makes loud popping noise, shuts off, and trips circuit breaker. Plus, can't get the door unlocked to get the clothes out.
follow this steps and fix it. God bless you
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control
Jul 10, 2013 | Washing Machines
I HAVE POWER BUT THE CONTROL PANEL HAS NO POWER
see this causes and fix it. God bless you
Check Power
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace the control.
Oct 02, 2012 | Maytag Neptune MAH6500A Front Load Washer
My Maytag Neptune Dryer stopped running & is
as per heatman The most common cause of your appliance giving you the PF error code is a problem with the power coming in from your utility company. Of course if there is an interruption of power, and then the power comes back on you will get the PF code Loose wires going to the circuit board or the control can also be a cause of the error code. If a wire terminal end happens to get corroded or loose, the vibration from the machine can cause slight power problems and this can cause the PF code to be displayed. Finding the cause of this type of problem is like finding a needle in a haystack. Sometimes you can cause it to be displayed by banging on the side of the appliance or slightly moving the wiring harness, to see if you can get the error code to display.
The bottom line about this power failure error code, is that it is power related. Finding the exact cause can be difficult. If you are continually having to reset the appliance then check to see if all of your appliances are giving the same code. This will indicate utility power problems. If only one appliance is giving the PF code then it is probably internal to the appliance.
Jul 12, 2011 | Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag Neptune washing machine. About 5
The Inlet Water Solenoid valve may be stuck open not seating properly.
The Pressure Switch may not be signaling the Control Board to close the water valve on proper fill level.
But let’s start off with the easy test first. If you pull the 120VAC power cord from the service outlet will water flow stop?
If we need to troubleshoot further are you a DIY’er that’s wants to try to DIY the fix?
If not maybe we can point the Service Company in the right direction to bring out parts on the first service call….. Rich
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Jul 10, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Control panel won't function
This could be a Control Board failure. I would try to recycle 120VAC power to the washer. Leave it off of about 20 minutes then re-power up. If that doesn?t clear the issue then I believe your Control Board has failed. Do you have surge protection at the washer 120VAC outlet? Have you had any recent lighting storm activity? The Service Manual can be found on this site. The Control Board is under warranty for 5 yrs from date of purchase.
Aug 28, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My Neptune washer MAH9700
I have a Maytag Neptune MAH 9700. It died one day and the door remained locked. I am guessing the circuit board is fried so it's a good thing I purchased a five year extended warranty. The problem though, is that my 2 year olds BLANKY was in there and she won't go to bed without it. Can't wait 2 weeks for the repair guy. I was able to remove the top and (after I unplugged it of course) get my hand to the bottom of the switch housing. Seems there is a small opening at the bottom. I pressed up with my finger and was able to get the door opened. Whew!!! Hope this helps. ; )
Jan 10, 2008 | Maytag Neptune MAH9700 Front Load Washer
MDE 9700 AYW Maytag neptune dryer
My dyrer just stopped working one day. I've had the heating element checked, both boards and my electrical outlet checked but my dryer still doesn't work. All I get is a troubleshooting code that looks like an upside down F with a 5 behind it. If you have a solution to this problem please let me know Thank You.
Dec 05, 2007 | Maytag MDE9700AYW Neptune 174 Electric...
Washing Machines Logo
47 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
