Question about SanDisk Sansa e250 MP3 Player
Will not turn on
I have a Sansa E250R. I left my office and it was playing...i came back and the screen was black and it will not turn back on.
    President:
  • 4,402 Answers
Have you tried hold down the power button 15 sec. to reset the Sansa.
Posted on Dec 12, 2007
I have a Sansa E250R MP3 player. I had the unit
some where on the device it should hve a reset button that you have to press with a pin or somthing try that
Jul 13, 2009 | SanDisk Sansa e250 MP3 Player
SANSA e250r ??
my sandisk 250will not change songs it is stuck o #1 icannot move it up or down
May 03, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250r
it might be your token ring router is configured worng try the settings for that
Apr 28, 2008 | SanDisk Sansa e250 MP3 Player
My sansa e250R not working
Hi try this for me and let me know if you can put it in recovery mode if it does go into recovery mode dont do anything just let me know then ill tell you what you need to do next ok
1. with it switched off put key lock on
2. hold down rec button on left hand side
3. whilst still holding rec switch it on still holding down rec
4 it should now say recovery mode
let me know when you get this far ok
Mar 11, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250R firmware
hey yeah i had the same problem with my sansa e250r. when mine does that i
1. turn it off
2. put the hold button on
3. hold down the rec. button
4. turn it back on
that will get you into recovery mode connect your data cable once you have hooked it up to your computer open my computer and you should see a 16mb drive there instead of your normal mp3.
once you see that open it up.
now go to http://www.sandisk.com/Retail/Default.aspx?CatID=1449 scroll down and click on download firmware link
once you have downloaded that file unzip it and copy the file that is inside to the 16mb drive that you opened up in my computer.
once you have done all the above,,
1. take the hold button off
2. disconnect the data cable
3. wait for it to reboot.
if the above dosent work you might wanna take it to the dealer.
hopefully this works for you as well as it did me. good luck
Mar 04, 2008 | SanDisk Sansa e250 MP3 Player
Sansa c140 is not turning on
my brother had the same problem with the e250r after dropping it (do not know if u did) i opened it and fiddled with the wires and it popped to life just fiddle with the guts ans it should come rite back to life if ur looking for a quick fix.
Jan 11, 2008 | SanDisk Sansa c140 MP3 Player
Device not connected
The Sansa Media Converter will only detect the device in MSC mode, or Plays For Sure (e250R) mode.
Change the mode in the Settings>MODE or USB MODE on the device and re-connect.
Best of Luck,
Nov 15, 2007 | SanDisk Sansa e250 MP3 Player
Problem with black screen and white lines
You need to determine if your player is the Rhapsody version or not.
To find this, check the back of the device for the word RHAPSODY, or a letter R after the model number (i.e. - e250R)
The software is different and you should clarify which one it is before we continue.
You can "add to the question" with your answers and ill reply.
Best of Luck.
Oct 31, 2007 | SanDisk Sansa e250 MP3 Player
My Sansa e250R, 2 gigs, froze. Help!
It seems like your E250R is experiencing a temporary system error due to a corrupted song, and needs to be reset. Try to "Soft Reset" your player, press and hold the "Menu" button until the LCD light and scroll wheel light turn off. Since the player was probably left on for more than 7 hours (as you indicated), you would need to re-charge the player before proceeding further. Charge it for at least 2-3 hours. Next, try to format the player to rid of any corruption then re-transfer the songs. If you have subscription songs, then I would suggest to delete the song you last played which caused the error. I hope this helps. There is another solution for the player, but for now this might actually resolve the issue. Let me know the results. :)
Apr 23, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
32 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
