Question about Philips HDD070 MP3 Player
How can I fix my Philips gogear sa32xx?
When I turn it on, i see the Philips logo and after that the player just turns off. When i connect it I see ok to disconnect and my computer can't see the player.
SOURCE:
SOURCE: philips gogear 8 gb mp3 player
My guess is that you all have Vista, or an XP install with Windows Media Player 11.
Revert back to Windows Media Player 10 and fire up the Device Manager that came on the CD (You can also find it at phillips' website, in the product support section.) Click on the tab that says 'Repair' and hit the 'Repair' button. This should fix your problem.
Note that this will remove all of your files from the device.
Posted on Jun 30, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: how should i connect philips gogear mp3 player to the computer
Software is available from Philips website.
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Nov 25, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: MY GOGEAR NOT STARING
The solution to a Code 10 error is to disconnect the mp3 player from your computer, uninstall all of the Philips software that came with the device, restart your computer, reinstall the Philips software, and THEN and only then - connect your mp3 player to the computer.
-Tha Mp3 Doctor
Posted on Mar 07, 2009
SOURCE: gogear says ok to disconnect, but isn't charging, how do i make it charge?
hi , enter to the website of philips and download the software and new firmware select first you exact model, next quit batteries of your mp3/mp4 player and press the button (bent arrow) all the time until it detects and connect to the computer and run software and choose repair
Posted on Jul 15, 2009
SOURCE: philips gogear vibe your player is not connected.
How do I clear data (music, photos, etc.) that have been downloaded to my Phillips Go Gear Vibe MP3 ?
Posted on Dec 26, 2009
Ihave gogear sa32x wh i turn on on screen i see philips logo and
you may need to install the driver for the computer to recognise the mp3 player (go to control panel, swich to classic view if it isnt already and go to add hardware then follow the onscreen instuctions). 'ready to disconnect' is normal it is just telling you that it is safe to remove the player from the computer. 2 possibilities for turning off: the battery needs charging (connect to computer to do this) or the player is locked. refer to the user manual under controls to find out how to unlock it. as far as i know, as i have a gogear sa1922, there is a slider somewhere on the player to unlock it. hope this helps, solver214!
Oct 21, 2009 | Philips GoGear HDD6330 MP3 Player
I have gogear sa32xx but it daes not connect with pc at oll and it con`t work olso
It needs to work through "MusicMatch". Your GoGear should have come with the CD to install the software. You must install the MusicMatch software. Once loaded, you may need to go to their website to see if you have the most current drivers and updates for things to work properly. Read all instructions about how this player works. It does not work in the same way that iPods do. You have to use the wheel differently.
Sep 25, 2009 | Philips GoGear SA3245/37 Digital Media...
File system error when i wnat to turn on
Support for e.g. SA3187:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA3287/02&slg=en&scy=GB
shows up this FAQ [item 5]:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA3287/02&slg=en&scy=GB#
This link tells you to do as next:
  • back up first all your data from the player to the computer !
  • next perform a format of your player [see the online link]
  • at last transfer all data to the player again
Sep 16, 2009 | Philips GoGear SA3125/37 MP3 Player
Goes white when turned on
try turning it on and leaving that way until the battery is fully discharged.
After that, try connecting it again.
Good luck
Jun 21, 2009 | Philips GoGear SA3125/37 MP3 Player
Problem with philips gogear sa 3245
the same thing is happening to me. have you fixed yours yet?
Jun 03, 2009 | Philips GoGear SA3245/37 Digital Media...
My GO Gear not starting
Did you try pressing the reset button on the bottom of the player next to the hold switch?
Mar 06, 2009 | Philips GoGear SA3245/37 Digital Media...
-Tha Mp3 Doctor
My player fails to power on
-Tha Mp3 Doctor
Aug 25, 2008 | Philips HDD1630 MP3 Player
Frozen screen
reset the gogear pres the power and volume + at same time
Apr 19, 2008 | Philips GoGear HDD6330 MP3 Player
Philips HDD070  MP3 Player Logo
433 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
