Question about Kitchen Ranges
Amana Gas easy touch control 800
Bake and convect wont work. Gas does not start. But will start in the broil mode.
3 Suggested Answers
  • 521 Answers
SOURCE: Oven quit, bake not working, replaced thermostat, now broil works, still no bake
Your problem may be the bake relay on the clock or wiring.try changing that
Posted on Aug 12, 2008
  • 750 Answers
SOURCE: electrolux built in wall oven,
Hello stevefer
You said, Your Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
1.What is the Model Number and the year of your wall oven?
2.Did the oven light up and display with any error codes?
3. Did you try to turn the breaker off for 5 minutes to see if this will reset the system?
Perhaps the heating element is failing and may need to be replaced.
I will be able to better assist you when you reply with this information.
Waiting your response.
Posted on Oct 16, 2008
SOURCE: Gas stove Thermadore 36 inch Model PGR366 PL Oven wont bake but will broil
this may seem like a silly question if you've already tried it but have you checked the over temp breaker? If you have no idea what I'm saying there is a breaker on the back side of your machine. Of course Thermador is so kind to place it convenietly behind the back panel so you'll have to remove that. There should be a little red button in there somewhere toward the top middle half of the machine I should say. If you press that button it may work.
Posted on Nov 11, 2008
0 characters
1 Points
Amana AGR5735QDS. Bake/Broil don't work, Clean/burners do work
Hello- Most problems with todays ranges start after 'self clean', or as most techs call it- 'self destruct'. If control functions normally, the temp can be run up manually by holding button down until it reaches 500deg., then holding it down until it stops and reads 0 or +/- 5,10, etc. This is a temp adj. mode. If it won't adj. or work at all, control is bad. If it works, then twin ignitor failures are not unheard of. Resistance across either ignitor should be above 4 ohms., if not, they have failed. Avoid 'self clean'. Tears electronics up and wastes energy. Use drip pans and try to forsee boil overs. Grandma figured it out a long time ago. Hope this helps. Thanks- ED
Mar 01, 2010 | Amana AGR5735QDS Gas Kitchen Range
Aug 12, 2008 | Viking VDSC307-4B Dual Fuel (Electric and...
Oven will not heat; convection fan runs when in convection mode, but elements won't heat for convection bake, pure convection, bake, or broil; it comes on as if it's going to work but the temp gauge never...
Heating elements are protected by a fusable link that is a one time fuse that is meant to protect the stove from overheating. It sounds like the elements need to be replaced
Jan 19, 2010 | Dacor Preference RSD30 Gas Kitchen Range
I have an Amana acf3325a gas range. the oven will
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Should be 3 - 3.6A. If less than 3A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace. Part number is 74008064.
Keep in mind, ignitors are fragile.
Dec 28, 2009 | Amana ACF3325 Gas Kitchen Range
The oven function (broil, bake, etc) knob does not light
Open high limit or bad relay most likely.
The relays are located on the back side.
The limit I am not sure where it is stashed.
Sep 08, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Maytag Gas Oven top burner does not turn on when in bake mode
That is the way it works. If you have an convection oven then they both work in bake mode but they alternate between the two.
Dec 17, 2008 | Maytag MGR5751AD Gas Kitchen Range
Oven top element does not come on when baking
the top element is for broil only. if you have convection mode try that
Nov 25, 2008 | Hotpoint RB757 Electric Kitchen Range
can you hear the convection fan motor turn on? if not that would be your problem.
Apr 10, 2008 | KitchenAid KGST307 Gas Kitchen Range
Oven Burner turns off during preheat
Mike, I think your problem is in the ignitor itself. Turn the gas off and see how many amps it's drawing during the bake mode. It needs between 3.2 and 3.6 amps to keep that valve open. Then ohm out the temperature probe, appox 1132ohms at room temp. You can see if your electronic control will go into a quick test by pressing and holding the cancel and broil buttons together for 3 seconds. First kill the power to the range and power back up before entering. When quick test appears you can check the bake relay by pressing bake. The relay should activate and 1 should be displayed. Same thing for convection bake except the fan should run too. back.
Feb 24, 2007 | Jenn-Air JGS8850BDS Stainless steel Gas...
Oven wont work at all.
Convection oven and Bake will not heat past 200degrees. Broiler works fine and the range works fine.This is for the Model # MGR5875QDW, Gas Precision Touch Control 800, can you help. Thanks Kasz3
Dec 24, 2006 | Maytag MGR5875QD CleanDesign Gas Kitchen...
Kitchen Ranges Logo
75 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Barrett Palumbo
Barrett Palumbo
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
