Brother HL-4040CN Laser Printer Logo
Posted on Sep 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Brother HL-4040CN successfully installed but shows offline
Installed Brother HL-4040CN successfully on my network. But it shows offline and I don't know what to do to get it online.
Anonymous
Level 3:
President:
  • Master 2,049 Answers
  • Posted on Sep 17, 2009
Anonymous
Master
Level 3:
President:
Answers
2049
Questions
0
Helped
1489771
Points
8420
I assume it's turned on and connected to the router.
Sometimes with DHCP, the IP address on the printer will change. I end up going into the router table to see what IP addresses are assigned where. Invariably I'll find my network printer has changed. Find the printer and write it down.
In Windows, Go into Printers> choose the Brother and right click to check Properties. Look for Ports and change the IP address as needed. It will come back online.
Keep getting IS034 Install Network Driver 3 error when installing software
I had this problem when tried to install network driver to Brother HL-L2340D (exactly InstallNetworkDriver - 3, not InstallNetworkDriver - 1). Tried it several timers, when print spooler service was running. But still got the same error.
Finally, i forgot about install wizard and installed driver manually (for my Win2008R2x64, it was DeviceManager >> Install old device >> Manual choice from list >> Show all devices >> Install from disc >> target to unzipped wizard content folder (...install/driver/gdi/32_64) >> select wanted printer model in appeared list >> continue install it.
After that, you can install this printer with standart applets of control panel (Printers > Install printer), it successfully finds printer in network and add it to list.
So, i still don`t know the reason, but have the solution.
My Brother HL 4040cn showes a Jam MP Tray. There are no papers jambed but it will not reset.
Hi James,
Remove the paper from the MP tray.
Remove any jammed paper from in and around the MP tray.
Fan the paper stack, and then put it back in the MP tray.
When loading paper in the MP tray, make sure that the paper stays under the maximum paper height guides (1) on both sides of the tray.
Press Black (Mono) Start or Color (Colour) Start to resume printing.
Still having Problem Then follow Us For
Brother Printer Support
Network not finding the printer
Hi
Here are possible solutions to your problem. Are you trying to install new printer on the network or it is already installed but not detected.
1.Check the printer or the computer is if turn on.
2.Check the printer cable if connected.
3.Make sure you are properly configure the printer using their network ID or the computer is being shared or not.
My brother 4040CN printer is on a offline mode how do i set it to online mode?
Hello, Open the start menu and click on the "printers and faxes" icon. This will open a window with the list of printers currently set up on your computers.
2. Double click on the icon of the printer you want to change to online. A pop-up window detailing all current print job will open.
3. Go to printer in the menu bar of the pop-up window and unchecked "use printer offline". This action will change the printer from offline to online mode.
Thanks
2helpful
Brother 4040CN
This message will appear if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one
2helpful
Maintnance 4 brother hl-4040cn
to get out of maintenance use the up or down arrows until it says 99 then press ok.
make sure none of the buttons on the machine are stuck down, that could have caused this
1helpful
3answers
Brother HL-4040CN Fuser Cover
Click this link below;
http://www.uninetimaging.com/newsletter/Brother_HL_4040_TN_115_Reman_eng.pdf
Brother HL-4040CN Laser Printer does not feed the paper and stops. I open the paper drawer and the paper will be just above the drawer and I will push back down and close the drawer. Sometimes it will...
i have brother 4040cn printer but its not working any more its showing me no paper load paper in multi purpose tary.
so fi any one there for help me please help me .
thank you
2helpful
2answers
Difference between Brother HL-4040CN and HL-4050CDN printer
The D stands for duplex printing (both sides of paper)
Norman Weimar
Norman Weimar
k24674
