Question about Vacuums
Belt i cannot find how to change the belt on my dyson dc4
  • 8 more comments
  • Anonymous Dec 18, 2007
    how to change the belt to my eureka optima?
  • Anonymous Dec 25, 2007
    help i dont know how to change the belt in my vacumn
  • Anonymous Jan 09, 2008
    cant change belt
  • Anonymous Feb 11, 2008
    Belt Replacement Instructions
  • Anonymous Feb 15, 2008
    how do I change the belt on the eureka altima upright vacuum
  • colamanfun Jun 05, 2008
    how to change drive belt
  • jeffbrammer Aug 09, 2008
    i cannot find how to change belt
  • itsgeorge_ho Aug 19, 2008
    how do I change the belt?
  • triplettb Jan 02, 2009
    I cant find a way to access the drive shafe that turns the belt.My belt has slipped off from that shaft.
  • Anonymous Mar 12, 2014
    How change belt
Remove sole plate and beater bar.
Remove control knob by prising between yellow plastic side of knob and casing using wide bladed screwdriver.
There three torx headed screws holding the clotch assembly in place. Two are visible but the third is accessed via a circular access holein the main casing.
When these three screws are removed the clutch assembly can be pulled out. the thinner belt driven by the motor needs easing over the motor shaft.
There are two screws holding the end plate onto the clutch assembly. remove these, twist the end plate and remove. note where the fibre clutch plate and the metal plate fit and replace this belt.
On opposite end prise off spring washer and this assembly comes off the reveal the belt.
Refitting is the reverse.
Have a look on you tube and type in replacing clutch on Dyson DC4 as there is a 10 minute vidio that is quite good!!
Hope this helps!!!!!
Posted on Oct 06, 2008
Have the vacuum cleaner standing upright. Look at the cover where carpet height control is. Six inches to the right and left of the knob are little black screws. take them off and the cover should remove easily. your busted belt will be resting on the right hand side.
Posted on Oct 04, 2008
    Filmmaker:
    Uploaded 5 video answers.
  • 152 Answers
Ok if u flip the vacuum upside down u should c a cover over the beater bar,there r a few screws holding on cover take them out the cover should come off.then u should c where the belt is
Posted on Mar 02, 2008
2 Suggested Answers
  • 14 Answers
SOURCE: Dyson DC4 Brush will not spin - have checked belt
The bearings on your brush have gone bad. Buy a new roller brush and replace the belt as well, even if the old one seems o.k. Most people don't realize that roller brushes have bearings in the ends that allow them to turn quickly and smoothly. If you get hair wrapped around the roller brush, this will kill the bearings.
Posted on Sep 11, 2009
I just want to give you my opinion on my new ball dysom. I had the old upright model for many years and was very very satisfied. However the new ball is not as great. It is very difficult to turn i
Hi
If you think you are talking to Dyson, you aren't. This is a self help website, where people like you ask questions, and people like me (a person the same as you) answer them.
I have a Dyson DC4, it has wheels and I love it. If you find your Dyson Ball is difficult to turn, you are using it wrong. It must be moving as you turn in the same way a car steering wheel is easy to turn when rolling and hard sitting on the drive with the engine off.
Mar 14, 2017 | Vacuums
Dc4 has low suction
HI, it's Jim from Crucial Vacuum!
Low suction from your Dyson DC07 can be directly related to basic vacuum upkeep and maintenance. Here's some simple things you can do for your vacuum to help ensure optimal performance and to keep your vacuum running for a long time with great suction.
After every use, make sure to empty your Dyson's dust cup. Allowing for fine dust and debris to rest in your unit's dust cup for a long period may cause your unit to become clogged.
Wash and clean your unit's filter screen weekly. To do so, empty your filter screen outdoors to take off any excess debris and then clean under running water until the water comes out clean. Allow the filter screen to fully dry before inserting it back into the unit. This may take up to several hours. Be sure to allow it to FULLY dry.
Foam and cloth filters should also be washed and dried weekly, by following the same steps from cleaning the filter screen. Do not use any soap, dishwasher, dryer or washing machine to do so. Allow your filters to air dry for 24 hours before re-installing them in your Dyson.
Last, make sure to clear your brush roll of any hair strands or debris monthly and to replace at least every year. When examining your brush roll take note of the condition of the bristles. Are they loose? If so this would be a good time to change your brush roll.
While checking the brush roll you might as well examine your Dyson's belt. With use the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. So if your belt feels loose as well replace that.
All of the previous general maintenance tips will help improve your vacuums suction and overall performance.
You can purchase your replacement parts for your Dyson DC07 direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=DC07&order=relevance&dir=desc&limit=all
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Dec 29, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do you change the bel on Dyson DC14 Animal? WE can't seem to get access to the belt
Belt maintenance DC14 animal. Dyson would not recommend that the belt on your particular machine is replaced by anyone other than a suitably trained electrician or Dyson Service Engineer.
It is not expensive to get it done locally. If you want to know who can do it, call the free Dyson helpline on 0800 954 0154 which is open from 7am to 10pm 7 days a week or email askdyson@dyson.co.uk
When you have found someone local,you can call, ask them the cost, then make your decision.
If you already have a spare belt and feel confident to change it on your DC14, I suggest you Google for the following.
'Dyson DC14 animal change belt', where you should find it, as I did for my DC07Allergy. I found the solution AND changed my belt on about half an hour.This is not a recommendation for you to change it yourself. You do it at your own risk.
Jul 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Changing the belt on a dyson dc17
Here is a link to the belt you need and the manual which has instructions on how to change the belt:
Dyson DC17 Belt and Manual
Dec 24, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Change fanbelt
Here is a link to the belt you need and a manual you can view which shows you how to change a Dyson DC07 Belt.
Dyson DC07 Belt and Manual
Dec 04, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do you change a belt on a dyson 07
You will need a spicial belt tool to change the bet on this unit. you can find it on ebey under "dyson spicial bet tool" do not try to use your hands. The belt is very tight and you can hurt your fingers if you get them stuck. let me know if this helps.
Oct 12, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do i change the belts
you will need to get the special belt tool. they have them on ebey for about $15. enter in "dyson belt tool" into the search engine. don't use your hands as the belt is very tight.
Sep 27, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC4 Brush will not spin - have checked belt - this is ok
Sep 09, 2009 | Vacuums
Vacuums Logo
1,131 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
