my hoover vacuum runs for about 10-15 minutes then the saftey feature shuts it off(overheat?). i have taking it apart a cleaned it with no results, added new bag also. after an hour it cools down and works again. do i just need a new vacuum?
Comments:
Sep 16, 2009
- theres suction and it pickup dirt cause i checked the bag. is it worth the repair fix or just but a new vacuum?
Do you have suction through the tools? Does it look like it picks up when it runs? The machine could be clogged and that would cause the problem, but unfortunately the sensor that shuts the machine off could be bad if the machine isnt clogged. Its not easy to get to it, I'd take it to a repair shop.
Comments:
Sep 16, 2009
- when it comes to hoover, i wouldn't recommend it. try and find a riccar, model vibcl.2 is about 300$ but it'll last a lot longer than any new hoover. (in fact any vac under 300 is pretty much disposable)
I was cleaning the 2 washable filters on my windtunnel u6430-900 and forgot how the multi...
(More)
I was cleaning the 2 washable filters on my windtunnel u6430-900 and forgot how the multi layered/multicolored final filter goes back in. The manual just says replace in reverse order. One side is white, the other side is turquoise. Someone please tell me which color is against the bodyof th emachine/which color is visible through the slats in th efilter cover. Thank for your prompt reply!
I replaced the belts and brush of my Hoover U6430-900 WindTunnel Bagged Upright Vacuum. Brush turns...
(More)
I replaced the belts and brush of my Hoover U6430-900 WindTunnel Bagged Upright Vacuum. Brush turns just fine until I reattach the bottom plate.
Hoover Windtunnel u6430 900 - Self propelled functionality no longer working. What can I do about...
(More)
Hoover Windtunnel u6430 900 - Self propelled functionality no longer working. What can I do about this?
