I have a Frigidaire washer that I need to install the v-belt. The old belt broke so I wasn't able to see how it threaded abound the, I believe, three pulleys. Also, what about the belt tension once installed, does this need to be considered?
  • 1,531 Answers
The belt goes around the the motor pulley then tension arm and then around the transmission pulley once you start to put it on the transmission pulley you can push it clockwise and this will help put the belt in possition
Posted on Sep 16, 2009
SOURCE:
I need a schematic for installing a cub cadet LT1050 drive belt. The old belt broke and I'm just not sure how to replace it. It appears you need to remove the clutch for the mower blade firat.
To replace a transmission drive belt on a Cub Cadet LT1045 or LT 1050 you need to remove the deck, preferably put the front wheels up on blocks or stands, unplug the PTO power (directly under the engine, which can be a pain ), use an impact wrench (you need the speed of the impact wrench because the engine will turn) and a 5/8" socket and reverse the bolt out of the PTO.
The PTO may be sized on there so you may want to tap it with a hammer and a block of wood carefully to release it. AT this point remove the 4 engine mount bolts from underneath (1/2" I believe). You will need to remove the left steering nut and arm to have access to the 4th bolt. Do not remove or replace engine mount bolts with impact wrench or bolts may break. Loosen old belt from tensioner pulley. Place pry bar under engine to slightly lift engine and move aft to expose belt from pulley and remove from pulley. Remove old belt from engine pulley first, transmission pulley last. Remember how belt goes around pulleys before doing so, draw a map if needed.
You'll need to put the belt on the transmission pulley first then thread the belt up to the engine pulley. Carefully push engine back into place and exhaust pipes into forward muffler will take some patience. Bolt engine back on being careful not to over tighten bolts. Place steering arm and nut back in place. Thread your belt back through the pulleys and tensioner (make sure your spring is strong enough to tension the belt or buy a new one).
The PTO is "keyed" on the shaft. Replace bolt and washer. Put your deck back on and you're ready to mow again. Give yourself an hour for this one.
Aug 16, 2014 | Cub Cadet Garden
The tub does not turn in the rinse/spin cycle but the motor is running.
Hello Jwwood,
Your Frigidaire GLTF2940F washer is not moving when it is washing clothes. This is because the belt is broke you can locate the belt on RepairClinic.com. Before you order the belt you need to findout the length as there are many different lengths and styles. In order to get to the belt you need to remove the back of the unit. If it is broke as I beleive measure and post back to this thread or go to the following link find the proper size and order. LInk - http://www.repairclinic.com/Frigidaire-Washing-Machine-Belt-Parts
Thank you for choosing FixYa.com
Mar 06, 2011 | Frigidaire GLTF2940F Front Load Washer
I have a Frigidaire GLTF1670A washer. When the washer goes into the spin cycle, I have noticed a progressively louder belt slipping sound. The washer is 7 years old. Do I need to replace the belt, or is...
Disconnect the washer from the electrical supply then remove the screws shown holding the rear access panel to the washer’s rear panel and lift the access panel off.
Cushion the bottom of the cabinet opening as shown to avoid hurting yourself with the sharp edge.
Plug the washer in then start a loaded spin cycle to check for belt slippage and the motor operation itself.
Replace the belt if loose or slipping. Remove the belt by turning the tub drive pulley and rolling the belt off the pulley.
Install the new belt in reverse order by wrapping it around the motor pulley and on one side of the tub drive pulley then turn the pulley to the other side in such a way that the belt wraps completely around the pulley. Secure the rear access panel back into position to complete the procedure.
Note: This advice is intended solely for the asker dolanbox as per live chat discussion.
Aug 30, 2010 | Frigidaire GLTF1670A Front Load Washer
Frigidaire FER211AS2 dryer drum belt
the washer has to be tipped forward. can access from bottom (and back).
Jun 03, 2009 | Frigidaire FER211A Electric Dryer
Belt on Frigidaire front loader
bingo they run crooked sometimes,,and sometimes there just defective,,if you have the back of already ,,just slip it over motor pully,,,than the tub pully hold wiht 1 hand and turn the big pull with the other...onthejob
Feb 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Belt broke on whirlpool automatic washer. model #LFA5700. How do you install new belt? Do you have to lower the motor to get belt back on track?
usually belt pack will have a diagram explaing how to install belt you must love that old washer last belt drive washer from whirlpool was made in 1986..motor doesn't have to lowered but geearcase does but not all the way down have to remove all braces gearcase bolt with spacer is removed all the way other 2 are loosened enough to get the 95405 belt through the various twist and turns necessary
Jul 31, 2008 | Washing Machines
Front Load not spinning
The back of washer has a access panel with screws that you can remove,once removed you can check if tghe belt broke or not.
May 23, 2008 | Frigidaire ATF6000ES Front Load Washer
Does not spin out all the water
Sorry RickAZ, I have just joined the fixya family. I'm trying to get old unsolved problems off the list, so I'm just posting a fix. Congratulations on your replacement washer.
Jan 03, 2008 | Amana ALW480DA Top Load Washer
Need to know how to replace belt on kenmore front loading washer
Please first check if belt is broken? If not How old is the unit?
Jan 01, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
