Question about Velodyne Audio Players & Recorders
  • 124 Answers
It can be fixed very easy.
Any good quality audio repair shop should have the part and can take care of it in short order.
Posted on Jan 05, 2009
Monster Inspiration headphones right side
The auxiliary input sometimes can come loose inside Look for the screws and you can pick up electronic repair kits at any surplus store It's cheaper than radio shack a place like harbour freight Once inside you should be able to see any broken connection or loose wire Just solder any loose wires or use crazy glue to connect loose plastic
Apr 24, 2014 | Audio Players & Recorders
How do i connect ms 10 sub to yamaha RX-V1065 amp, I am using 2 monster cables.
The ms 10 is an active sub, so all you should do is connect the Subwoofer output on the rear of your amp to the LFE input on the sub with a simple audio cable.
Nov 27, 2011 | Mission MS10 Subwoofer
I need the wiring colour codes for 2002 santa fe car stereo
Basically the wiring of the large harness corresponds to the pins like this.
Starting in the upper right hand corner and working down the right side from A12 down to A1.
1=Left rear output-red
2=Left rear output-blue
3=Right rear output-black
4=Right rear output-yellow
6=Left front input-black
7=Left front input-yellow
8=Left rear input-orange
9=Left rear input-green
10=Amp 'ON'-blue&orange
12=Amp sensor-black&orange
Back up to upper left hand corner on the large plug
13=Right front tweeter output-red
14=Right front tweeter output-blue
15=Left front tweet output-red
16=Left front tweeter output-blue
18=Right front input-red
19=Right front input-white
20=Right rear input-blue
21=Right rear input-red
23=Right front sub (+) output-yellow
24=Right front sub (-) output-black
The small harness is the same above with the upper right position being pin 1 going down to pin 4 then back up to the top for pin 5 down to pin 8.
1=Memory Power-Lrg White
2=Amp Ground- Lrg Black
3=Left front sub (+)output-yellow
4=Left front sub (-) output-black
5=Left front mid (+) output-white
6=Left front mid (-) output-brown
7=Right front mid (-)output-brown
8=Right front mid (+) output-white
Hope this will help you.
Thank you
Jan 04, 2011 | 2002 Hyundai Santa Fe
I got a teac ag-v8060 audio/video surround receiver and I'm tryin to hook up some surrounsound speakers along with a jbl g cinema sub can you describe where the wires go in the back of receiver? The sub...
On the back of the receiver, there could be "pre out-subwoofer". If your subwoofer has the same type cable input, that would indicate it is a powered(amplified) sub. Connect those two. If subwoofer only has red/black speaker inputs, it is a passive sub, which means spkr signal runs thru it and then to your main left and right spkrs.. Run your receiver main or front spkr left (red/black) and right (red/black) to those corresponding sub inputs, and then sub spkr outputs to each of your main left/right spkrs..
For surround, on the back of the receiver, there should be spkr outputs (red/black) noted as "rear".
Just make sure red to red, and black to black.
Hope this is helpful.
Apr 28, 2010 | Teac AG-V8060 Receiver
DSW PRO 600 not getting signal from receiver. Why?
You don't name the electronics, which can be the source of the problem. See #3.
1. If you suspect the cable why don't you just swap in another RCA cable? BTW: there's no such thing as a "subwoofer" cable. Monster makes their money on those beliefs. Cables don't wear out but they can go bad if one or more conductors fails. Oxides devolp at either end which can inhibit conductivity. Remove each end and reinsert it with a twisting motion.
2. Maybe. You need to ensure the sub is defined. Run speaker level check. If no sound at the sub, prove the LFE/sub channel has output by running the RCA cable to a recorder or your TV (low volume). If there's no signal, duh, no speaker will work with it.
3. Mmm, not if it's exhibiting the same problem as the old one and the Polk 450. Have you looked at the setting of the Standby/Auto/On Switch? And the Power Mode LED's? Red is bad.
Mar 31, 2010 | Polk Audio DSW PRO 600 Subwoofer Speaker
I am trying to connect an akai dvd player to directv, please help
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
Jan 31, 2009 | Akai DVD-3850S DVD Player
Static Noise from guitar amp.
I take it you have made sure that both the cable to the distortion box from the guitar and the cable to the amp are both good. From the description you give, it sounds like there is no signal getting to the pedal. If the cable is good, then the next likely suspect would be the input jack on the fuzz box. Try wiggling it a little with the guitar cable in place to see if it is loose. Some input jacks are unbelievably cheap and flimsy. A crackling sound (static like) is almost always a bad connection. If it was the output jack, I would think that the guitar signal would come through a least a little bit, but you might want to try wiggling that one, too, if the input jack isn't the culprit.
Another possibility to check is the battery, but this doesn't seem as likely. Some effects units devour batteries, especially units that use 9V batteries. I have a multi effect pedal that kills a 9V in about an hour.
Jan 22, 2009 | Epiphone Les Paul Studio Electric Guitar
Got power..but no sound
Your sub may have gone into protective shutdown to prevent failure as a result of "thurderous (sic) performance".
Mar 18, 2017 | Sunfire True Sub MK II Subwoofer
Computer to Denon via Monster Headphone cable to V.Aux (Front) RCA inputs
Are you using a stereo-mini to RCA cable that has a red and a white RCA plug? What I mean is, you should have the one cable coming out of the headphone jack on the computer, and two (left and right) cables going to the receiver. The only other thing I can suggest is making sure the cables are tight. Maybe try another input on the receiver. There really shouldn't be any feedback unless there is some underlying problem.
Jan 08, 2008 | Denon AVR-3806 Receiver
155 people viewed this question
Top Velodyne Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Vito Vacirca Jr.
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
