Question about Maytag MMC5000 Microwave Oven
Turntable will not spin
When the microwave is started the turn table does not spin nor the interior light comes on. After a while once the microwave warms up the light comes on and turn table begans to spin.
Every thing works except micro will not heat.g.e above stove micro.
Posted on Dec 23, 2007
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
Any repair on a microwave is not recommended! It runs on very high voltages.You run the risk of shock. Also by law they must be checkout for radiation leakage. A special calibrated meter is use. In most cases,it will cost more to repair then to buy a new one.
Posted on Dec 19, 2007
  • Maytag Master
  • 9,098 Answers
This is usually a probem with a door switch or door switch mount or a problem on the control board. We repair these control panel assemblies for $39.95 nationwide.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 17, 2007
  • William Miller
    William Miller Dec 17, 2007
    One more thing: In many brands, there is also a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
Why does my microwave turntable turn when I open the door?
We recommend you have the microwave evaluated by an authorized service center.
Authorized service centers can be located in the below link.
www.panasonic.com/repair
May 01, 2014 | Panasonic NN-H965WF - Microwave Oven...
Turntable does not spin, no heat
HV fuse has failed. Possibly caused by door switches or Diode Pack failure. Do not attempt a repair unless you are competent to do so. Extremely hazardous voltages inside!
Feb 27, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Turn table in microwave wont turn
Repairs are expensive. New microwaves are cheap. But you don't have to spend a dime on either. If your microwave turntable stopped spinning, here's an easy way to try and fix it. And all you need is some warm, soapy water and your own two hands. You don't have to be an appliance expert to troubleshoot a seemingly broken microwave turntable. You might find that all your little Zappy needs is a checkup and a good, thorough cleaning. If you follow these steps and find that your microwave still isn't turning, it probably means the motor has spun it's last spin. Then it's time to retire old Zappy. Unplug the microwave. Safety first, kids. Remove the glass tray and the circular turntable guide. Wash them both in warm, soapy water to get rid of anything stuck. Pay special attention to the rollers on your turntable guide, making sure they're able to spin freely. Clean the internal cavity. Make sure to check your microwave's center cavity to make sure it's free of movement-hindering (and gross) leftover food. Check that the drive bushing is working. Make sure that the drive bushing, the plastic mechanism in the bottom of the microwave's interior that the glass tray turns on, isn't worn out or split in two. If it is, you'll need to have it replaced. Put it back together. Put the turntable guide back into the circular groove. Place the glass tray turntable over the turntable guide and onto the drive bushing. Adjust until the drive bushing should fits perfectly into the grooves of the glass tray. Test it out. Zap a mug of water for a short bit to see if you fixed the problem. Do not run the microwave without anything in it.
Aug 05, 2012 | Microwave Ovens
The motor will not work. The interior light comes on, but the turntable does not go around. The cook time counts down, but no cooking occurs.
the turn table motor could have failed, but the counting down will be the monitor switch or a micro switch located behind control panel
Feb 24, 2011 | Amana ACO1860 Microwave Oven
Microwave turntable works intermittenly - also no light
if you have on the key pad turn table on/off it may be the pad itself / I would ck the connections on the prosser . as the get film (correded ) you can use a spray cleanner for this . and it may correct the problem . flickering light may be the element and it may fail . (soon ) ****
Jan 09, 2010 | Samsung MW1030WA Microwave Oven
Dacor dcm24s.light, fan, and control panel work but turntable and heat do not
Most likely the bottom door switch. Dacor units are built by Sharp and that switch is a very common problem. You'd either need to check the switch with an ohm meter or remove the cover of the switch to see if it's burned inside.
Oct 20, 2008 | Sharp R-930AK Convection/Microwave Oven
MW 8115 SS Turntable doesn't turn
You probably have a stick door switch or broken door switch mount.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
Aug 20, 2008 | Emerson MW8108P Microwave Oven
Microwave Buzzing, Still Heats, but Turntable And Fan Not Working
This is not safe. If the fan is not running, the magnetron will quickly overheat and be destroyed. We answered this in more depth in the other place you asked it.
Feb 24, 2007 | GE JVM1441 Microwave Oven
Maytag MMC5000 Microwave Oven Logo
73 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
