Question about Jenn-Air 30 in. CCE3401 Electric Cooktop
Electric element does not turn off except after several tries.
We have to keep turning the control knob off and on before the left rear electric element will stop heating.
  • RedRunner Dec 30, 2007
    The left rear burner does not turn off at all anymore. It used to turn off after several tries. Now we have to turn off at the breaker. Jenn-Air DVCCE3450.
    Novelist:
  • 161 Answers
The contacts in the control switch have fused. Replace the switch. You can probably do this yourself. Part should run about $25.
Posted on Jul 01, 2008
Broken knob
Turn off the power to the appliance. Squirt WD40 liberally all round the knob, trying to get it in behind it. Wiggle the knob and press it down and up if possible to let the WD40 oil work in to the dirty or stuck joints. Leave for a few hours and wiggle it again to see if its loosened up.
Dec 15, 2013 | KitchenAid 30 in. KECC506R Electric...
Short on Jenn Air electric stovetop
Dear Genie,
Well, you are right in your surmising!
That water has shorted out perhaps as many as several items.
One way to solve this problem would be to wait until the water dries up, could take days or a couple of weeks.
Another way would be to take a hair blow dryer and dry the parts by blowing them for a while, perhaps 10 to 20 minutes, but to see if that fixed it, you would need to turn it on, which could cause a short!
No good.
Best idea is to take it all apart and see if there is visible damage, and to take and electric meter and test it all.
God bless your efforts.
Jul 10, 2017 | Jenn-Air Cooktops
The left top element is not working, the control knob lights up but doesn't heat. Is it the element or the switch? Mod#JED8430BDB Ser#1414040011A Schott Ceran
It could be either. The only way to properly check is by dismantling the cooktop and checking the circuit with a volt meter or test lamps.
Feb 11, 2011 | Jenn-Air JED8430 Electric Cooktop
Kitchenaid KECC502 Electric Cooktop: LED light at the left rear knob is always on but the left rear burner single or dual does not work. I tried to turn knob on and off but nothing enable burner.
I wish I had the exact answer, because I have the same exact problem!!! You posted this about a month ago, which is when my unit started having LED "on" problems. Just in the past week, the top left power on LED will not go off, and nothing I can do gets the dual large burner to come on. Any thoughts??? Reply to: mchunko@csonka.com
Mar 25, 2010 | KitchenAid 32 in. KECC502 Electric Cooktop
My Viking VECU105 electric cooktop has one burner which will not regulate the temperature. It can be turned on and off with the control knob, but after that, there is no temperature control. Any ideas on...
It will need either a dual infinite or infinite switch, If the burner has an inner an outer element then it requires the dual.
Firstly turn power off at breaker.
The unit needs to be removed from the cut out and the cover removed from below the swtichs. the knob taken off and the secureing screws removed, then take note of the layout of the wiring and the poistion of the switch, then swap the wires, reassemble test and then re-install
Feb 18, 2009 | Viking 31 in. VECU105 Electric Cooktop
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Electric stove
if it is a DOUBLE element burner you might of turned on the second element. double elements the reverse direction turns on.
if single you have a short or a bad switch
Apr 09, 2008 | Cooktops
Maytag, precision control 500 [canada]
the infamous "custom control kit" its an electronic board that only control that one precision temp burner all other elements ar regular switches, if thats the one where the sound os coming form replace the control. .nothing else to do
Dec 26, 2007 | Maytag MEC5430BDS Electric Cooktop
Jenn-Air 30 in. CCE3401 Electric Cooktop Logo
112 people viewed this question
Top Jenn-Air Cooktops Experts
Marvin
Marvin
Paul Carew
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
