Question about Sony Dvcam DSR-PDX10 DV Digital Camcorder
Microphone How do I disconnect the internal microphone and connect an external microphone. It is only the internal mic that works.
For microphones with a 3.5 mm miniplug you can use a plug-in at the front of the camera. There is a little plastic cover over the hole under the word "MIC". I would call this an emergency solution because for most recording purposes you would want a microphone with XLR connectors.
This camcorder comes with an external shotgun condenser mic and XLR adaptor. If you have the operating instructions that come with the camera, you can turn to page 29 where there is a description of how to install the supplied external microphone.
When you slip the hot shoe plug of the XLR adaptor into the intelligent accessory shoe, the internal microphone is by-passed. In case you do not have the operating instructions you can download them from the Sony manual site.
http://esupport.sony.com/perl/select-system.pl
Put briefly, Attach the XLR adaptor to the accessory shoe on the top front of the camcorder and tighten the screw of the adaptor. Connect the hot shoe plug of the SLR adaptor to the intelligent accessory shoe of the camcorder, located behind the adaptor screw. When you push the hot shoe plug into place you should hear a click. Sometimes you have to use a little strength to get it correctly seated.
I hope this helps.
Posted on Jan 29, 2008
How to disable Dell latitude E5500 built in mic so you can connect an external mic?
Just plugging in the external mike into the jack should AUTOMATICALLY disconnect the internal mike.
May 27, 2014 | Audio Players & Recorders
External microphone not working
Software like Audacity (free) will usually have settings allowing you to switch settings . Your mic is likely coming through the "line in" option. That may also apply to settings you can get to by clicking the mic icon in the lowest part of your display.
Mar 02, 2018 | Trust Computers & Internet
External microphone thinkpad t41
Control Panel, Sounds, look at Recording devices (depends on the OS you are using, you didn't mention, Vista, XP, 7,8?), Mic. Your Headphones jack, when in use, will cause the internal sound to disable, depending on OS the mic setup is a bit different but you should find it in sounds, recording devices.
Nov 12, 2012 | IBM ThinkPad T41 2373 Notebook
How do I connect an external microphone to my Toshiba Salellite Laptop computer?
Right click over speaker icon (next to your clock right bottom corner), click recording devices. Clic on your external mic, clic on properties, at bottom on the new window select "use this device (enable)"
Aug 20, 2012 | Toshiba (P000257700) Microphone
Hello there, my mic won't work.
The external microphone input is most likely dirty and causing the internal microphone connection to be disconnected. The mic socket is at the front edge next to the headphone socket. try cleanig with a vacuum cleaner first to clear any dust and fluff. Then use a cotton bud and cleanig fluid e.g. WD40 or contact cleaner, or CD cleaning fluid.
May 26, 2011 | Nintendo DS Lite Console
My acer aspire 4720z mic is not working but the output audio is ok
Try plugging in an external microphone. If it works, then your internal microphone has failed. If the external microphone also doesn't work, then try reloading the Realtek Audio Driver. There is also the possibility if you have previously used an external microphone, that the jack's connections have become unreliable such that the system thinks that an external microphone is still connected after it has been unplugged. With this situation, plugging an external microphone back in will obviously work.
Mar 18, 2011 | Acer Aspire 4720 Notebook
Regarding the canon hv20 camcorder. When using an external canon MIC a) How do you know the mic is working and you are not picking up sound on the internal MIC b)On connecting the external MIC an icon...
If you put the camcorder in manual mode, there is a microphone sensor that will move when sound is picked up by the external microphone. In manual you can keep everything else automatic. The off for the mic means that the built in mic is turned off when an external mic is attached.
Sep 16, 2008 | Canon HV20 HDV Digital Camcorder
Microphone
the external mic must be unplugged for it to work and you need to reconfigure the internal mic if it doesn't work... there should be an option for this under start>settings>control panel> audio> microphone
Jun 16, 2008 | Dell Inspiron 6400 Notebook
Missing Audio
sound changes to external mic. when any ex. mic. is inserted the internal mic. comes out of order then you don't and can't have two sounds same time that mean you only get the ex. mic sound regards please don't forget to rate thx
May 02, 2007 | Canon MV630i Mini DV Digital Camcorder
Built in Mic?
well, to find out if your computer has a mic open up the audio mixer (double click the speaker in the right hand side of you screen), if you do not see your microphone, go to Options>Properties, and select "microphone", then go to options, advanced controls, under microphone, if you see a "advanced" button, click it (if you dont see it, there is no internal mic), if you see Mic2 Select, you probably have a internal mic. Another way to find out if you have a internal mic is to go to the sound recorder, and see if you can record your self, However if your going to be using skype, i recommend you get an external mic
Jul 04, 2006 | Sony VAIO Notebook
Sony Dvcam DSR-PDX10 DV Digital Camcorder Logo
423 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
