Question about Samsung RS2630SH Side by Side Refrigerator
Inside fan area freezing up (no defrost?)
When I disassemble the fresh food side - the evaporator is frozen solid with ice. After manually defrosting it - it will work for a while (a week to a month or so) until it freezes up again. I looked for a defrost motor/timer but I couldn't find one - got the shop manual and it looks as if the defrost timer (circuit) is on a motherboard. Now my freezer has started to do the same thing - up and down temps (according to the readout on the door) When the fresh food side went out (dual cooling units) the temp read what it was set at (but the inside was much warmer) and when I unplugged the unit for a half hour and then plugged it back in, the readout changed to the actual temp, not the incorrect readout. Any ideas?? I'm tired of losing food and doing a manual defrost each time. This Samsung is hard to find parts and service for - Samsung was no help when I call - they told me to look in the phonebook when I asked them for local factory authorized service" - but no one in the Cleveland, Ohio area works on these (except, maybe BestBuy where I bought it)
  • kprzewodek Dec 22, 2007
    I had the same problem. Refrigerator evaporator freezes up. The obvious reason is that it's not defrosting but why? $300 and one month later after a hack of a service guy was certain without checking anything it was the thermal fuse and heating element, I am once again having the exact same problem. Now I buy a new refrigerator and it wont be a Samsung and it wont have dual evaporators. This one gets delegated to the garage and hopefully, over time, I can find out what the real problem is without wasting my money on these so called professional technicians.
  • 1HotZ28 Feb 11, 2008
    It looks as though the only solution is to put it out in the garage and just use it for beer/soda and other thing that don't HAVE to be refrigerated, and once a month, just unplug the fridge, open both doors, and let it defrost for a couple of days and then you are good to go for maybe another month. If we could only find a trucker that would be willing to pick up all the Samsung fridges like ours and drop them off at their corporate (in the U.S.) headquarters, in the parking lot - blocking in their cars. Let them struggle with their trash ! ! For me it's - ABSOLUTELY NO SAMSUNG ANYTHING ! ! ! ! ! If it has a Samsung tag on it - FORGET IT ! ! ! Pass it on to anyone who might be thinking of throwing away their hard-earned money ! ! WARN THEM ! ! !
What does it cost to do this? I have had the problems on this post and others and am so tired of dealing with Best Buy/samsung and the most ignorant/non-troubleshooting repair guys that I'm thinking about giving the thing away and buying a new one as another person above mentioned.
Posted on Feb 11, 2008
  • 75 Answers
Hi there this is a common fault you need to replace the evaporator cover with the new modified one which has a large heat sink around the fan to stop iceing up also you will need to replace the thermal fuse and the defrost sensor.
hope this is of some help
Posted on Dec 13, 2007
Does my fridge have a defrost timer? The first time the fridge quit working we had a repair person come figure out. He found the circulation fan was frozen in the back panel inside the fridge. He turned...
This is a very common problem with Samsung refrigerators especially the type that has two evaporators. The evaporator that is inside the fresh food section and will usally give people the most problems. The drain below the evaporator in the fresh food section will begin to freeze over or become blocked by gunk inside the drain line. When this happens it causes the fresh food section to retain water because with the drain blocked the moisture and defrost condensate water now have nowhere to go. Once that drain is blocked the freezing over of the evaporator will begin to happen more often slowing down defrost which again make problems worse. Clean the drain, make sure the refrigerator is level and confirm the model number of your refrigerator. Your model has no defrost timer and defrost are determined by the motherboard. There is a way to force defrost with your model from the motherboard but until the drain is cleaned out defrost will not help much because the water has no where to go but to freeze over the evaporator and fan area of the fresh food section evaporator. Is your model the?=>RF267AERS I am here if you have questions, Sea Breeze
RF267AERS Parts
Oct 21, 2013 | Samsung RF267AERS French Door Refrigerator
Samsung "Cool-n-cool" fridge freezer defrosting food
Is it "defrosting" the food or unable to keep it frozen? Probably unable to keep frozen. Many possible problems. 1. Defrost element bad and evaporator coil is iced over, or 2. Failed evaporator fan inside freezer, or 3. Low freon causing iced up evaporator coil....Do you see any ice build up on the back wall of freezer? Do you hear the freezer fan running or not? Take a look and get back to me.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Oct 12, 2013 | Refrigerators
I have a GE GTS 221C fridge/freezer. The fridge is working fine. All of a sudden, the freezer is not freezing. Just cold, but not enough to keep food frozen. The fan on the freezer is working.
remove the rear cover inside the freezer if it has a lot of frost on it,then the evaporator coil is frozen up and you cant blow cold air over or thru a solid block of ice,defrost it,then check the defrost heating element,defrost thermostat and timer or defrost circuitry for no power or defective components,you can use a hand held hair dryer to defrost it quicker
Jan 08, 2011 | GE Freezers
The refrigerator side is only getting down to 50 degrees. the freezer is down to 0 degree. unit is about 2 yrs. old.
There is likely a problem with the defrost circuit or fan (but could be a low freon charge or other problem). The freezer compartment has the cooling coil with defrost heater and a fan that pulls cold air from the freezer into the fresh food compartment, based on the setting of the thermostat in the fresh food compartment. Before you dig into that, you should vacuum the condensor coil to remove dirt and dust that always collects on it. It that solves it - you're done. Otherwise, continue.
When the defrost heater fails, the area that the coil is in turns into a solid block of frost and ice. It becomes impossible for air to be drawn across the cold coil, cooled and blown into the fresh food compartment. The result is a rising temperature in the fresh food compartment - and eventually in the freezer section, too. Since the fresh food compartment contains the thermostat and the temperature never gets low enough to satisfy it - the compressor runs non-stop. That is, until the defrost timer kicks in to shut it off for 20 minutes or so.
The first thing to do is to manually defrost the freezer by accessing the cooling coil after emptying the contents of the freezer. This can be a pain in the neck to remove racks, shelves, ice maker, etc. to get to the back wall of the freezer, behind which the coil is protected. If you expose the cooling coil and it is encased in frost and ice it is a problem with the defrost circuit. If it is not - the fan is suspect. If the fan spins, check for a blocked path between the fan and the fresh food compartment.
If it is a defrost circuit problem, you'll need to check voltages and continuity on the defrost terminator & timer and defrost heating element, fans, etc. after completely thawing the ice & frost. This job isn't a good first time DIY job due to the danger of freezing skin, etc. due to possible exposure to freon in the system and the tight spaces you'll be working in with live voltages. You might want to call a pro after you've defrosted or put up another fixya request if you decide to dig in on your own and need specific help with procedures, locating parts, wiring diagrams, etc.
I hope this was a good starting point to help you decide whether to go forward or not on your own. Good luck!
Aug 09, 2010 | KitchenAid (KSRD22FKST) Side by Side...
The freezer fills with water and overflows about once a week.The food is partially frozen and the ice is clear and wet. The fridge is cold and no problems but the freezer doesn't fully freeze and water...
your evaporator coil in the rear area behind the freezer back panel is frozen over with ice and the coil can no longer deliver cold air due to ice blocking the air flow from the evaporator fan,remove this rear panel,defrost it with a hair dryer,check the defrost heating coil for continuity,they go bad regularly,if not the heater coil under the evaporator coil,it may be the defrost timer in the refrigerator section of the unit that powers the defrost coil that needs replacement
Jul 25, 2010 | GE 22.3 Cu. Ft. Bottom-Mount Refrigerator...
Amana side by side model DRS2362A. Recently the freezer is not staying cold enough to keep ice cream frozen. Tried cleaning out underneath (grill area) but this hasn't helped. Other foods seem to be...
If you see frost behind the back wall or begin to notice the fresh food compartment getting warmer then you might have a defrost problem. The defrost system is a heater and termination thermostat inside the evaporator and A timer. The termination thermostat shuts down the heater when it gets to be warm enough for the frost to melt. It is important for the thermostat to kill the heater because the defrost mode is 21 minutes long.
If that heater was to stay on for 21 minutes the ice box would be severely damaged. The Timer might be hung in the run mode and not jumping into defrost every 8 or 10 hour as it should. The heater element might have gone bad or the termination thermostat might be swollen and failed. That is some ideas to check. Service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 16, 2010 | Amana Refrigerators
I left my freezer door open by accident on a beko cda540w fridge freezer freezer defrosted now when i turn the fridge back on it does not seem to freeze and the fridge stays warm i can here the fridge...
you may need to manually defrost the evaporator coil. If condensation built up from the door being left open, it may have frozen the coil solid. At that point even the evaporator defrost bar won't be able to remove the ice. Remove the cover, if it is frozen solid, unplug the unit and use a hair dryer to defrost the ice.
Nov 13, 2009 | Refrigerators
Refrig not cooling
Either the fan that blows cold air from the freezer compartment to the fresh food compartment is burned out or the door/flap that seperates the compartments is stuck or the linkage connecting it to the fresh food temperature dial is stuck or broken.
The evaporator coils are in the freezer compartment and air is blown from the freezer compartment to cool the fresh food compartment. For some reason, air is not moving to fresh food compartment.
If the fan is running, it could be something as simple as Ice blocking to door between the freezer and fresh food compartment. I know modern refrigerators are self-defrosting, but that's only the evaporator coils, which are defrosted by a timer and a heater.
Ice can form on passageways inside the refrigerator, like the exit of the ice maker and in this case, on the door and 'tunnel' between the freezer and fresh food compartment. It's free, and doesn't take a lot of time, so try completely defrosting the unit before doing anything else.
BE SURE to keep the doors open, as odors can form as particles of food are allowed to defrost that may have been frozen in an ice pack for months or even years. Clean the interior of the refrigerator while you have everything out and reset the controls to normal settings.
If this doesn't help, there may be a mechanical problem with the air transfer control flap/door that will need to be fixed.
Hope this helps.
Jun 10, 2009 | Refrigerators
Whirlpool Refrigerator fresh food section cool but not cold (freezer ok).
The most likely problem is in the defrost system. Behind the freezer panel there is not only an evaporator fan, but also the evaporator itself, and a defrost heater, termination bi-metal, and drain pan (or trough). You will likely find ice build-up in the evap coil. This could be caused by the defrost timer, the heater, or the termination bi-metal.
Have a service tech look at the unit.
May 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
GE fridge: Freezer working but fresh food side not cold
The problem is the refrigeration evaporator, located in the freezer section is blocked with frost and ice and not air can pass through it. Four different failed parts can cause this problem. The defrost timer, the defrost heater safety thermostat, the defrost heater, or the evaporator fan motor. Unless you are very good with a volt-ohm meter, it wiil be difficult to distinguish which one of these parts has failed. A qualifed refrigeration service tech or a good appliance service tech with a refrigeration certification can find this quickly.
Jan 13, 2009 | GE 22.0 Cu. Ft. Side-by-Side Refrigerator...
Samsung RS2630SH Side by Side Refrigerator Logo
356 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
