Question about Mitsubishi VS-60603 60" Rear Projection Television
Mitsubishi vs-60603 signal board and deflection board needed
  • 2 more comments
  • Dustin Shaw Feb 23, 2008
    I need one too... I know I keep writing on all of these, but I would really like to replace the main board so that I can continue using this TV.
  • mashauer Nov 23, 2008
    Have 1998 VS60603. Signal board got fried from tube coolant dripping on it. Looking for signal board part# 930B27014. Is there any hope?
  • suzsul Dec 22, 2008
    I'm fuming. Two weeks ago my Mitsu #vs-50607 prof. fried out from liquid dropping to the board below. Yesterday my #vs-60603 powered down-most likely same problem. These units are prone to this (defective??). Mitsu doesn't make the replacement part. Sounds like a class action suit should be filed!
  • jobweazel Feb 13, 2009
    Green light turns on, but the screen stays black. Found some clear fluid on the green board that is on the right side when you open it up from the front. Any ideas, part numbers, or phone numbers of people that can help would be great.
Need a main control board for a mitsubishi vs60603 3-1999
Posted on Feb 23, 2008
VZ5 Chassis mitsubishi VS-60603 With excessive brightness
If experiencing excessive brightness in the VZ5 chassis mitsubishi's it usually can be traced back to a leaky transistor on one of the CRT PC boards. Check Q6R1 on Red PCB, Q6B1on the Blue PCB and Q6G1 on the Green PCB one of these transistors will most likely be leaky
on Feb 23, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi vs-60603 lamp replacement
the VS 60603 has picture tubes three of them called CRTs you can get replacements at the following link.
Aug 17, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Mits VS-60603
the light bulb has gone out....
Jul 18, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Power lost
yes there are 3 fuses all located on the main board which is the board on the right where the power cord is entering the set one fuse is near the cord the other ones are in the center of the board.
May 27, 2008 | Mitsubishi VS-60603 60" Rear Projection...
No picture mitsu 60603
its about 3/4 of the way up that board on the left hand side its the vertical output ic mounted to a aluminum heat sink
Apr 27, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi WS-55807 parts in a VS-60603?
I own a Mitsubishi WS-55807 55 in. for parts if you are interested. Please contact me back if interested. 727-773-8208 Nicole
Sep 29, 2007 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi VS-60603 60 in pink spot
I have seen this before, and I can only describe it as a flaking of the phosphorus coating in one of the picture tubes. If you can, remove the back such that you can take a flashlight and look down into the 3 picture tubes. If you see any flaking or dark spots in the phosphor, there will be a spot on the screen missing that color. Unfortunately, this is not repairable, as all 3 tubes would need to be replaced (like replacing all 4 car tires when one is completely bald) and that would cost more than a new TV.
Jun 06, 2007 | Mitsubishi VS-60603 60" Rear Projection...
Technical manual for Mitsubishi VS-60603
Yes there is! Go to and its available on a paper typre or instant download type for about $24.00. You can get parts nat Good Luck
Aug 29, 2006 | Mitsubishi VS-60603 60" Rear Projection...
Televison & Video Logo
246 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
