Question about Maytag Washing Machines
I am in need of a lint screen for my maytag 4000 series stackable dryer
But am not in town to get model number off of the machine. is this a standard item that can be ordered & if so what is the part #.
    Top Expert:
  • Maytag Master
  • 10,321 Answers
Amazon
Posted on Oct 10, 2019
SOURCE:
  • 65 Answers
SOURCE: Remove front of dryer to clean lint from interior
open door remove eight screws, four on plastic guides and same location on hinges. wiggle door and it will remove . now grab narrow ends of front panel and pull toward you. wwhen panel gets to 45 degrees pull off tabs at bottom.
Posted on Feb 16, 2008
  • 161 Answers
SOURCE: Replacing dryer belt on Maytag
i would take off the cover, it might be reg or star type screws and look at this page
http://www.partselect.com/ModelFrames.aspx?ModelID=64957&ModelNum=DG410&mfgModelNum=&ManufactureID=1&Selected=36056&Position=6&mfg=Maytag&Type=&Mark=6
Posted on Jul 10, 2008
SOURCE: how to remove lint tray receiver: maytag dryer model#pye2300ayw
Unplug first with a straight blade screwdriver, pry up on the top of the dryer where the front wall of the dryer and the top meet. there are 2 screws 1 on each side inside the dryer where the sides and front meet, remove them and unhook the wires from the door switch. the whole front will now pull out and up, now open the door remove the 2 screws at the bottom of the door opening and the whole lint tray will pull out. sounds like a lot but only takes about 5 minutes.
Posted on Dec 04, 2008
aborcass
  • 2651 Answers
SOURCE: STACKABLE WASHER/DRYER DISASSEMBLY
FLSE72GCS6 this model number is showin as a complete laundry center, not 2 seperate peices. in which casse there is no seperating them
Posted on Dec 09, 2008
SolutionGuy
  • 331 Answers
SOURCE: How do I remove the lint housing of Maytag Neptune dryer
Hi Kate,
Gaining access to the lint housing sounds more difficult than it is. As a matter of fact, I could get to it and have it back together in the time it takes me to type out the instructions!
Tools needed;
1.) Phillips screwdriver
2.) 5/16" nut driver or socket
UNPLUG THE DRYER FIRST!!! Or risk a funky new hair-do...
Open the door and remove the four screws at the hinges then remove the door. Opposite the hinges, you'll see 4 more screws, remove these too. Now grasp the front panel on both sides near the top and pull it toward you. Lean it out to about a 45 degree angle and lift it off the clips that are holding it (at the bottom).
Now you'll see the lint trap housing. Look around the housing, you'll probably see a yellow wire near the 5 o'clock position, remove it. Now, on either side, you'll see four 5/16" screws... Don't remove the top ones, just remove the three below the top ones. You can now pull the entire panel off of the frame for cleaning.
Rebuild in the reverse order (and don't forget to re-connect that yellow wire!)
There ya go! Please don't forget to rate this as "FixYa", OK
SG
Posted on Apr 11, 2009
Is the maytag Neptune 4000 a gas dryer or electric? Can you help
well the answer is they make em both ways it depends on the exact part number , for example the model number Maytag MDE4000AYW is in that series 4000 and its an electric model for sure as im sitting here right now looking at one that had a sock get into some place it should not and has caused a lot of problems , so im deciding if its a fixer or a parts beast
Oct 13, 2016 | Maytag Dryers
Csn you remove trap where lint filter goes
How To Clean Your Dryer's Lint Trap, Screen And Vent ...
greenlivingideas.com/2014/08/14/clean-dryers-lint-trap-duct-screen/
Aug 14, 2014 - Cleaning your dryer's lint trap, screen and vent is a great way to keep it using energy efficiently. ... (Of course, if you can hang your clothes to dry, you'll not have to go ... Now use the vacuum to remove any lint from the lint trap.
Stackable Dryer-Lint Screen-Where is it? - YouTube
? 3:09
https://www.youtube.com/watch?v=-qu0OF9V2vA
Dec 27, 2011 - Uploaded by OcRefrigeration & H.v.a.c.
This Video Shows Where a " Lint Screen " is in a Stackable Washer Dryer and How to Remove it. Clean it ...
How to Clean a Dryer Lint Screen ' Cleaning Guides
www.howtocleanstuff.net > Cleaning Guides
Jan 11, 2016 | LG DLE5001W Dryer
Maytag 4000 dryer doesn't remove lint from clothes
Type Maytag 4000 dryer lint problem into YouTube and see if the video comes up, thanks!
Jun 24, 2015 | Maytag Dryers
MAYTAG STACKABLE WASHER FILLS BUT NOTHING ELSE
In order for us to provide you accurate information and supply you with the correct manufactures part numbers , we will need the complete model number, serial number and batch or series numbers (if applicable) found on a business card size metal/foil plate. If you are having difficulty locating this identification label, follow this link which will take you to our Website where we have pictures of common locations where your model number ID label can be found. Here is the link: http://www.affordableappliance.com/Tips/modelnumbers.htm Once you have the updated information, please reply to this email. Eric Campion
Nov 05, 2013 | Maytag Stackable Washer Dryer
Where do I find the lint trap in the dryer on the stackable washer/dryer?
Most likely at www.PartsSelect.com
You will need your model number handy. You can order it on line with a credit card.
Please rate this solution if helpful. Thanks
Sep 01, 2009 | Kenmore Washing Machines
Dryer is warm but not hot
Is the model number listed here or can you find the complete model number? May need cycling thermostat or gas valve solenoids. Let me know if I can help, Sea Breeze
Mar 22, 2009 | Maytag MDG16PD Gas Commercial Dryer
My stakable maytag washer leaves lint marks on the
new washer have what is called a washer drain protector, in other words it's a lint catcher for washers and your model has no such part. Do you use powder or liquid detergent? It seems to me that what you see is residue from too much detergent if you use powder. I've heard others with this complaint and to no avail can figure out the cause of this, at least from a view point of a simple wash.
Mar 16, 2009 | Maytag LSE7806A Top Load Stacked...
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Maytag neptune dryer wont restart mde 3000 aya
Your dryer needs a new motor. It should cost about $200-250 including labor. Call a local repairman - not a national company. Give him the model number and ask him to bring the motor with him.
Mar 31, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Washing Machines Logo
43 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
