Question about Epson Stylus CX3200 All-In-One InkJet Printer
Epson Cx3200 paper jam
There is no paper in the printer but I still get a paper jam error
  • 2 more comments
  • Anonymous Sep 09, 2008
    PAPER JAM FIXED THAT, NOW PRINTER ERROR SHOWING
  • kageglantz Oct 06, 2008
    There was a very small piece of paper, but I've now removed that. The paper jam message stays on, and seems to block the reset button as well as the menu from appearing (so I can't get to the Load/Eject part of the menu).
    Thanks -- kager@get2net.dk
  • Anonymous Mar 29, 2014
    I took out paper but the error stays
  • Anonymous Mar 30, 2014
    paper won't feed
  • Epson Master
  • 691 Answers
Then there is something stuck in the paper feed path which is holding up the sensor flag making it think there is paper in it.
Or maybe the sensor flag has been broken off by yanking paper out the wrong way when it gets stuck.
Get your vacuum cleaner and stick the hose down the paper feed path and see if it suck out a push pin, piece of paper paper, fur ball, eraser, coin, toe nail, false eye lash etc (all of which I have removed from machines with "paper jams")
Posted on Feb 17, 2008
Error button says there is a Paper Jam. Tried color copy button to no avail. can`t see a paprer Jam.
usually paper jam is at the back of the printer for more info check the manual of your printer
Jun 05, 2010 | Epson Stylus CX3200 All-In-One InkJet...
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
I have an epson CX3200 about 4 years old. If I do
get a bright flashlight and look for tiny bit of paper, hair or other object.
If you see nothing to remove, try blasting the paper path with compressed air.
Feb 04, 2010 | Epson Stylus CX3200 All-In-One InkJet...
My CX3200 printer shows an error message that there is a jam but there is no jam. I press the green color button and the error message is still there. I put a piece of paper in the paper holder and it went...
Hi
There are various sensors based on the printer and it maybe that one of these has failed. Try using a can or air to clean around the paper feeding area and see if that helps, if not then it maybe time for a new printer as the CX3200 has been superseaded many times now.
Thanks
Taz
Oct 24, 2009 | Epson Office Equipment & Supplies
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX3200 ( loud noise like paper is jammed) error message comes up.
By pulling the paper out backwards your sister may have caused a gear to jump. You could try pulling a piece of paper out in the other direction and maybe the gear will jump back into place. Otherwise you will probably have to have the printer serviced.
May 09, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Paper Jam
because of your paper sensor is not working or jam
Feb 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
ERROR SAYS PAPER JAM
Its already a hardware issue. go to support.epson.com and look for a service center
Feb 01, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson CX3200 printer error
i just fixed the problem .. you have to reset the protection counter FIRST .. then do the reset using the triangle and colour buttons.. this it the link for the SSC utiliity to reset the counter www.ssclg.com/epsone.shtml .. my printer works fine again
Oct 18, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX3200 All-In-One InkJet Printer Logo
496 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
