if the fire has output to svideo {yellow phono} some TV have svideo in if it has scart go to the local £1 shop and get a svideo to scart plug thing you plug svideo and audio into
£1 is all you need and the svideo output from the fire
i assume it will allow svideo to a TV
i hate these new things so non bzckward....and lazzzy
I believe without dock it only has svideo or VGA out so your TV will need to have svideo in or VGA in. An alternative would be to use a streaming device such as chromecast.
The Lifestyle 38 has no HDMI output. It all depends on what inputs your TV has, which cable set up would be the best for you. Assuming that your TV has an SVideo input, you indeed can use the SVideo output of the Bose system, to get the DVD picture on your TV. However you will need to connect the audio output of the TV to the TV input of the LS 38 to get the TV sound to play over your LS 38. In case you don't have an SVideo connection on your TV, you can use the composite output of the Bose system and connect it to the video input of your TV (yellow in and outputs)
Hello, your effective way is to use an svideo out from you graphics card to your video in for TV. the resolution is not that great but you can use it to view movies.
The easiest way to hook up any laptop to a tv is with either an HDMI cord, or an Svideo cord. It looks like your laptop supports Svideo, but make sure your TV supports it as well. The connection should look similar to this:
If your TV does have the port, go to a nearby electronics store, and buy an Svideo cord. An employee there should be able to help you find one for a fairly decent price. If your TV doesn't have an Svideo slot, you should be able to get an Svideo to AV converter cord along with your Svideo cord. You can connect the Svideo to your laptop and the Svideo slot in the converter, then plug the AV cords into your TV. Hope this helps!
your TV has composit video in but your DVD/VCR only has Component video and Svideo outputs ..those are not compatable with your tv .. if you look more closely you might find an SVideo input on your tv .. its flat and not as easy to see as the normal jacks .. if your tv does have SVideo then all you need is an SVideo cable (plus the two sound cables) ... i could check on what you have if you give the TV model number .. othwise you have to have something to convert your SVideo to composit video .. there is a cable that does that .. you can check with radio shack .. if they do have such a cable then one end would plug into the svideo of the dvd/vcr . the other end would plug into the yellow jack on your tv .. hook up sound and it should work ok ..
here is such a cable on the internet .. http://www.cablestogo.com/product.asp?cat_id=2012&sku=27964#tab=review
or google "svideo to composite" to see lots of options
You cannot,the best thing that you can do is to use the computers video card HDMI output to the HDMI input on TV. The USB is there for things like firmware updates and if your lucky,u may be able to plug in flash drive and view media through it. If your video card has SVIDEO you might be able to use that as well, but HDMI is the way to go if your serious about it, and an HDMI ready video card upgrade for your computer shouldnt cost more than $100,in fact 49 bux at STAPLES right now for a PCIex card.
usually a tv that doesn't "see" video on the S-video will not even "switch" to it. It just goes to the next Svideo, RCA etc..
Make sure your cable is not damaged. (on both ends) Does the svideo source and svideo cable work with another tv or video device?
31GT740 Manual
From the Manual: " WHO•INPUT In TV mode, press WHO•INPUT to toggle through the available Video Input
channels (VID/SVID and the current channel). In SAT mode, press to select available channel lists.
Using the WHO•INPUT Button
Use the WHO•INPUT button to toggle through the available input sources (VID and the current
channel) and view the content from the component you have connected to the TV.
1. Press TV to place the remote in TV mode. Make sure that the content from the component is
turned ON.
2. Press WHO•INPUT to tune to the available input source and view the component.
3. Press WHO•INPUT again to tune back to the channel you were previously watching. "
James Mac
You should have a svideo plug on the back of the laptop, and if you have a svideo input on the tv you run a cable bewteen the 2 and you can watch it on the tv.
