Question about Sony CDP-CX225 CD Player
Discs falling out
My Sony CDP CX-225 200 Disc Jukebox is dropping discs inside, it seems to fail to line up properly when putting a disc back in the carousel.
Any suggestions?
Si, al mio que es el mismo modelo le sucede lo mismo... la solución es tirarlo a la mierda o como hice yo solo lo uso de depósito de cd's, ajaja
Posted on May 08, 2008
CD discs fell into the SONY CD changer. They're rattling around inside. What to do?
Use common sense in removing them- You may have to open the unit up to see where they are. I can not see where they are located in your unit but usually opening the unit up will allow you to extract the discs without damage from the extraneous regions.
Dec 12, 2012 | Sony CDP-CE375 5-Disc CD Changer
Having a problem with a sony cdp-ce275 5 discs are being checked and lifted but after goes through cycle it reads 'no disc'
These units have optical sensors in them and the pickup assembly may have gone out of alignment. The Spindle platter can sneek down and put the CD out of range of the focus. I worked on a lot of these in a refurbishing business. They are usually not fixed at service shops due top the high cost to repair such and item.
Dec 10, 2012 | Sony CDP-CE275 5-Disc CD Changer
How do you burn discs that will play on a CDP-CX 355?
Anything that creates finalized standard audio cd's will do (filenames= xxx.cda). On a PC that would usually mean copying the files from original CD's rather than 'ripping them, then 'burning' the project to a disc.
Jul 22, 2010 | Sony CDP-CE315 5-Disc CD Changer
ALL SEEMS FINE BUT WON'T PLAY DISCS. FLASHING BLUE LIGHT INSIDE.I GET "LOADING ERROR" ON SCREEN, AFTER A COUPLE MINUTES. SONY CDP-CX400
I would suggest taking a can of compressed air to the disk tray to ensure the laser is clear of all possible debris
Mar 30, 2010 | Sony CDP-CX400 400-Disc CD Changer
Sony cdp cx 355 displaying table error
What worked for me was taking the cover off and carefully threading a belt back onto a wheel. There are two motors at the back of the unit, one (I believe) that grabs the discs and moves them in & out of the player, and a second one that rotates the table (i.e., the round slotted thing that holds all the discs). The belt had simply slipped off the wheel that drives the latter. I did remove the back panel as well, to access it better, and inadvertently disconnected a sensor plug, which led to a second round of troubleshooting, but - in the end - I got it working!
Feb 03, 2010 | Sony CDP-CX300 CD Player
Sony CDP CX 235 200 cd changer-cd's dropping off
Hi there.
I reckon that they are not being put back correctly by the loading mechanism! This is a common problem with these units. It is highly unlikely that they are actually falling off the carousel.
Open the unit, and watch it as it loads and replaces the cd's from the carousel. You will probably find that instead of grabbing the disc off of the spindle and putting it back, it might be grabbing before the cd is even in its grip. This then simply bumps the cd out of the way, and it will fall inside of the unit.
The good news is that it can be fixed with a bit of very gentle bending and persuading. But be very carefull when doing this!
Good Luck!
Jan 22, 2009 | Sony CDP-CX235 200-Disc CD Changer
Sony cdp-c545 won't open
Without turning the unit upside down, look at the bottom of the player. You should see a small round hole toward the front of the unit, with a white plastic part inside with a slot. Take a screwdriver and turn this gear manually with the power off. You should be able to unload the discs by rotating this gear. Be careful not to tilt the unit, as the discs will fall out of the tray, and you'll have to open it to retrieve them.
Once you have the discs out, put in only one disc and see if the unit plays. If you get a disc error, you probably need to clean the lens on the laser. Open the unit, use a cotton swab that has been pre-wetted with glass cleaner to wipe the lens on the laser. Do this gently, don't press down hard on the lens. Use the other end of the swab to dry the lens. Try loading a disc with the top cover off and see if it spins. If it doesn't spin, try turning it by hand. If you can't turn it by hand, the gears have gotten out of alignment.
In this case, use your screwdriver again, noting which way the gear on the bottom of the unit spins when the drawer is going into the unit. Then turn the gear until it "pops" past one or two teeth, and then you should see the laser assembly rise up and meet the clamp assembly on the top of the tray. These are the most common problems with the 5 disc players that Sony made. Many times I could fix them in 30 seconds or less using this procedure.
Dec 04, 2008 | Sony CDP-C545 CD Player
Player reads no disc
try to clean the lens use coton and water. do not use cleaning disc.
Sep 17, 2007 | Sony MegaStorage CDP-CX355 300-Disc CD...
"no disc" message
Maybe you chould try to clean laser lenses manualy, not with disc???
Aug 16, 2007 | Sony CDP XE270 CD Player
Sony CDP-CX225 CD Player Logo
322 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
