Question about iiyama Vision Master Pro 510 22" CRT Monitor
Refresh rates and resolutions
With my ATI Radeon GeCube 9550, I can pump up my 15" CRT monitor refresh rate up to 200 hz @ 1024x768 resolution while with the same monitor that I have, my new nvidia GeForce 8600 GT sonic+ can only come up with 60 hz @ 1024x768 or 85 hz @ 800x600.
  • Isaac E Jun 15, 2012
    what monitor supports that? Im interested in getting a 200hz refresh rate.
    what monitor supports that high refresh rate? Model name/number? Im trying to find a 200hz refresh rate monitor.
  • 4 Answers
What's the question? There's no real need to go above 85Hz, I think in nvindia you have to go to an advance menu and you can force an output, google it.
Posted on Jan 11, 2011
Tell me what is samsung syncmaster 794 default setting
The maximum resolution supported is 1280 x 1024 pixels at 65 Hz refresh rate, while the recommended resolution stands at 1024 x 768 pixels at 85 Hz. However, the maximum usable resolution is 1152 x 864 pixels at 75 Hz. Maximum usable resolution signifies the maximum resolution supported by a monitor at a refresh rate of 75 Hz or better. Though 85 Hz is an ideal refresh rate, 75 Hz is the lower limit. Any refresh rate, lower than 75 Hz, will give a flickered output and can cause some serious eye damage after prolonged usage...i hope this helps.
Aug 29, 2011 | Samsung 793DF 17" CRT Monitor
After installing the ASUS EAH5450 my computer turns on and runs fine on my desktop monitor. However, I've hooked up a HDMI cable to my Sharp Aquos and the tv says it's receiving an incompatible...
The easiest thing to try is change the screen resolution before connecting via HDMI. The process is a little different depending on what operating system you're using.
For Windows Vista/Windows 7: 1. Right click on your desktop and select "Screen Resolution" 2. Slide the bar to change the resolution to either 1024x768 or 1280x1024. 3. Click apply.
For Windows XP: 1. Right click on your desktop and select "Properties" 2. Click on the tab to the far right that says "Settings" 3. Under Screen Resolution, slide the bar to change the resolution to either 1024x768 or 1280x1024. 4. Click apply.
Either of these resolutions should at least give you picture when you reconnect with HDMI. Once you get a picture, repeat these steps and gradually move the slider higher to get a better resolution picture. If you receive the incompatible signal message again, just wait 15 seconds and the previous setting will be restored.
If this doesn't work, you may also have to adjust the screen refresh rate. From the same window that has the screen resolution adjustment bar, click the link or button that says "Advanced." The second tab, "Monitor," has a drop-down menu to adjust the screen refresh rate. Depending on your HDTV, the most common setting for this could be 60 Hz, 70 Hz, or 120 Hz. If none of those values work for you, you should check the manual that came with your TV to check what the proper resolution and refresh rate should be for your computer connection.
Jun 10, 2011 | ASUS EAH5450 SILENTDI1GD2 graphics adapter...
Unable to get 1024 x 768 resolution on philips 105e
Hello, that resolution should be available but only at a refresh rate of 60hz as per the specs pasted below. Can you see this resolution setting on your graphics card? If not then perhaps you need to check you have the latest driver for your graphics card and just make sure that your graphics card does support that setting anyway.
Diagonal Size 15" Viewable Size 14" Dot Pitch / Pixel Pitch 0.28 mm Max Resolution 1024 x 768 / 60 Hz Max Sync Rate (V x H) 120 Hz x 54 kHz Video Bandwidth 65 MHz Factory Preset Resolution Modes 1024 x 768 / 60 Hz
800 x 600 / 85 Hz
640 x 400 / 70 Hz
640 x 480 / 75 Hz
640 x 480 / 60 Hz
800 x 600 / 75 Hz
Dec 26, 2010 | Philips SoHo 105E 15" CRT Monitor
I have just connected my old (beloved) SyncMaster 1100MB to my new computer with Windows 7. I can only get a refresh rate of max 60 Hz to the monitor. It gives too much flicker. How can I get a higher...
Right click your desktop and select "properties". On the last tab (where you set the resolution) click the "advanced" button. On the new property sheet go to the monitor tab and uncheck the box that say something like "hide modes that this monitor does not support". Click OK then. Now you should have everything up to 200 Hz.
Hope this helps. If you need any more assistance, don't hesitate to come back to me. Else, if the problem is solved, please do ACCEPT this solution. Best Wishes. Thanks for using FixYa.
Nov 05, 2010 | Samsung SyncMaster 1100MB 21" CRT Monitor
I havE A VEIWSONIC Va520 when I turn it on , it brings up a screen saying out of range H-30-62 KHZ V-50-75 Hz what does this mean?
1. maybe the problem is with windows, because the refresh rate is set to an acceptable value
2. your lcd screen runs at higher hz than 60
3. you are running a resolution higher than 1024x768 15" LCD's generally can only support 1024x768 whereas larger panels support higher resolutions.
Possible solutions
1. The LCD you buy is shipped with a plastic cover over the screen which shows maximum resolution and recommended refresh rate. When you first turn on your computer press F8 to access safe mode, after you enter safe mode, configured the required setting on your lcd monitor. when you are done, reboot or restart your computer, hopefully your computer should be fine.
2. attempt to access the bios setup utility by pressing del or f2 of your keyboard after you see the initial display of your pc, if you can see it, the problem is with windows because the refresh rate is set to an acceptable value. Set it to its required settings by entering safe mode as posted on no.1
Dec 02, 2009 | ViewSonic VA520 15" Flat Panel LCD Monitor
Too much screen flickering @ 1024x768 (60hz)
setup your monitor driver supplied with the monitor, you will get more options. Thanks
Oct 29, 2009 | Computers & Internet
Monitor displaying out of range message
Hello and Welcome to FixYa!
This usually happens when you select a resolution or a refresh rate that is beyond the monitor range. For example if your monitor supports a max. resolution of 1024x768 then if you give it a signal of 1600x1200 it will display out of range.
Solution of this problem is to reduce the resolution or refresh rate frequency.
Changing screen resolution in Windows XP: First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear as shown in fig 1.1 below, click on the settings tab at the top right of the box.
The areas worth noting are:
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Normally the default (in XP) is set to 800x600 which means the display will be 800 pixels wide and 600 pixels high.
How to Change the Screen Refresh Rate of Your Monitor loadTOCNode(2, 'summary');
  1. Click Start, click Control Panel, click Appearance and Themes, and then click Display.
    Alternatively, right-click the desktop, and then click Properties.
  2. Click the Settings tab, and then click Advanced.
  3. Click the Monitor tab, and then click the screen refresh rate that you want to use.
  • The default refresh rate setting is 60 Hertz (HZ); however, your monitor may support a higher setting. Check your manufacturer's documentation for information about the settings that your monitor supports.
  • If you use a higher refresh rate, you can reduce the rate that your screen flickers; however, if you specify a refresh rate that is too high for your monitor, your screen may become unusable and your hardware may be damaged.
  • Changes to the refresh rate affect all users that log on to the computer.
Kindly rate me if i was helpful.
Aug 25, 2009 | Hansol Computers & Internet
Samsung sync master 510 monitor display problem
It may be that the LCD monitor will not display all screen resolutions so you may need to change your resolution to match the desired resolution and refresh rate of the LCD. In your case the computer should be outputting:
1024x768 pixels
60 Hz
You can change these settings by right clicking on the desktop and clicking properties and they're under the settings tab. Change the screen resolution by moving the slider to the recommended setting (1024x768)
under the advanced button click the "monitor" tab - make sure the screen refresh rate is set to 60 hertz (60 hz)
May 21, 2008 | Samsung SyncMaster 510N 15" LCD Monitor
Daewoo computer monitor
You need to get your computer in the correct resolution and refresh rate to make the monitor work. It looks like the correct numbers for your monitor are:
Resolution: 1024x768 pixels
Refresh Rate: 60 hz
You can change these settings in the display tab or display properties (In XP - right click desktop, click properties, under settings tab adjust resolution and then click advanced, the monitor tab, and make sure refresh rate is set to 60 hz)
Mar 29, 2008 | Gateway FPD2275W LCD Monitor
iiyama Vision Master Pro 510 22" CRT Monitor Logo
197 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
