Question about Sylvania LC370SL8 37 in. LCD Television
Remote control Our TV suddenly will not respond to remote control. We have tried it's own remote, a general universal remote as well as the remote for out digital cable box. In fact, we can not seem to even find the remote sensor on the TV. Any suggestions?
  • angelh Dec 12, 2007
    the model number for this TV is 6419CtC...
I thought I was having the same problem with our tv remote, then rechecked the batteries (which I had changed about a week ago, thinking they were the problem). Sure enough, one battery was facing the wrong way. I switched it around and all is working as it should. Hope your problem just needs a simple fix like this.
Posted on Mar 24, 2008
    Sergeant:
  • 280 Answers
The IR detector has failed. it is inside the tv and it is not a do it yourself job.
Posted on Feb 21, 2008
Total Control Universal Remote. URC 4140. What is the 4 digit code to operate the above TV
Search Results
    [PDF]Total Control URC-4140 - Universal Remote Control Codes
    www.remotecodelist.com/remotes/URC_4140_B00_and_B01.pdf
    UNIVERSAL. Remote control. URC - 4140 ... Your TOTAL CONTROL can operate four devices: a Television, ... The TV, VCR/DVD, SAT and AUX keys select the device.... 4. Enter your four-digit code using the number keys. The red light will blink twice.... To set up your other devices, follow the same instructions above, only.
    Codes and links for a number of universal remote controls, including Sony, RCA, ... GE Remote Codes, General instructions for GE Universal 3 and 4 digit remote controls. ... This manual may work for a number of Philips-Magnavox remotes. ... Total Control URC-4140, PDF Instruction Manual (remote also known as Crest .
Jan 13, 2016 | Sanyo 42 in. LCD TV
Samsung tv has never responded to the remote control
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Please rate if Helpful.
Good Luck !!
PAIRING
and RESET buttons:
Within 3 feet of TV
  1. TV off
Feb 15, 2014 | Samsung TV Remote Control
LT-24DG42J
013/ 054/ 055/ 060/ 065/ 067/ 089 These are the three digit codes to Jvc brand TVs. As there is no remote control with you, the first thing to know is, to which code do your TV respond. Some TVs will respond to three digit codes, some others will only respond to four or five digit codes. If your TV do respond to three digit codes, a universal remote control, which have the above said codes in its code list will work. If you wish to get three, four & five digit code list to some popular remote controls, check the links given above. You can choose the proper remote control to your TV. But before buying a new remote control, make sure about the number of digits of codes that TV must have.
Feb 23, 2013 | JVC Televison & Video
Programming tv
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
These are the general proceedings to synchronize a universal remote control to a device. If you wish to get more details, check this link. It has setup proceedings and setup codes list to may brands of universal remote controls .
Jan 14, 2013 | Innovage Jumbo Remote Control
Setting code remote control tv polytron plm32b72
Find codes for each device and brand.
Press and hold the TV, VCR1, VCR2•LD,SAT•CABLE, or AUDIO button you want to set up.
Enter the three digit code from the TV, VCR, Laserdisc Player, Satellite Receiver, Cable Box, or Audio code list.
Release the device key.
With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat 2-4 using another code.
To get code list and more, try these sites. [1], [2]
Dec 28, 2012 | Universal Remote Control
How to install the codes for a sony kdl32l5000
Are you trying to synchronize this Sony TV with any universal remote control? if so, general setup codes for Sony brand TVs are: 0128 0013 0002 0071 0380. General setup procedure is:
Direct Code Entry
If you wish to get more details, please visit this link.
Dec 27, 2012 | Nippon Rcn506 Universal Remote
My sansung remote quite working, replacement universal remote was programed to the tv but the tv will still not respond. What's next?
You likely don't need a new remote. Certainly not a Universal.
Try this:
  1. TV off
  4. Turn on TV
Good Luck !!
Jun 18, 2011 | Samsung TV Remote Control
Can't get PX-RC1 to work with my older JVC
sometimes the universal remote controls cannot recognice old codes try this general process for remote contrl 15-2142
SEARCHING FOR YOUR CODE
If your device does not respond to the remote after
trying all codes listed for your brand, or if your
brand is not listed, try searching for your code. For
example, to search for a code for your TV:
1. Press TV once.
2. Press and hold P until the red LED blinks
twice, then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power.
The remote sends IR codes from its library to
the selected device, starting with the most
popular code first.
5. If the TV responds, go to step 6. If the TV
does not respond, press CH+. The remote will
try the next code. Continue until the TV
responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED
blinks twice.
7. To search for other device codes, repeat steps
1 to 6, substituting the appropriate device
key.
Mar 05, 2009 | Radio Shack 15-2142 Remote Control
I need help please! I need to re-program my RCA universal remote control. I have the 6 different codes. I just need instructions.Please!
You may need more information about your tv and the remote such as the model number, but generally, this is the procedure:
  1. Find codes for each device
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes, proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
If that does not work, please reply with the model number.
Jan 05, 2009 | RCA Universal Remote Control
Sylvania LC370SL8 37 in. LCD Television Logo
109 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
