Gateway MX 6440 laptop
I checking a gateway MX 6440 laptop for a friend. It will not power up. I have checked the adapter with a volt meter and it works. I removed the hard drive and tested it in another computer and it works. The battery is new but doesn't seem to charge.
I'm taking a wild guess and saying the motherboard is dead. Does anyone else have any ideas.
The computer was one month out of warranty. When it died it was powered on and then apparently shut down and that was all she wrote.
  • tanambogo Feb 06, 2008
    Thanks for response. After checking further I doubted it was the motherboard or processor. Since the battery would not charge and the adapter worked I guessed that there was something wrong with the connection point with the laptop. Not wanting to get in over my head I advised my buddy to take it into a shop. I was correct and there was a lose connection. I don't recall if it was merely a soldering job but he was able to get it fixed for under 100.00.
    Scholar:
  • 119 Answers
You may be right about the mboard but also try changing the processor or taking out the processor and try powering on withou the processor. If its the mboard then it could have been because of a power surge and thus the mboards needs to be replaced. let me know how you go. thanks
regards
Posted on Feb 06, 2008
Trouble shooting power
Hi Get yourself a good digital volt meter and check the power supply adapter of the Laptop. Must be a little more than what Laptop uses. Check the connections If loose replace with new connector. If you have ability to solder connections. Disassemble and resolder on power board. Hope that helps.
Dec 21, 2013 | Gateway Computers & Internet
When i plug the power cord in to my gateway mx-6440 the power charge light just flashes, when i turn the laptop on the it pulses on and off like its getting a charge but its not, when it boots up fully the...
From the symptoms you mentioned you have a bad battery. Only way to fix that is to get a new battery. You can find some on ebay or other auction sites.
Jun 11, 2011 | Gateway MX6440 Notebook
Power adapter is good, but Gatway MX6025 will not power on. It does power on briefly with battery installed. I've tested the ac adapter with a multimeter and it appears to be good. Green light on,...
Try to check with another adapter if possible.
The connector of the laptop might be damaged. so the battery is not charging and also not staring laptop on AC power. Check the ac connector of laptop.
Jun 08, 2011 | Gateway MX6025 Notebook
Gateway mx3414 wont start, battery red lifgt flashes
Check the voltage to the power box with a volt meter. If it reads the exact current needed as labeled on the power control box you need to replace the battery instead. A dead cell is the most common problem causing this for your computer
Jul 17, 2010 | Gateway MX3414 Notebook
Gateway mx 8734 will not charge. power cord is good. battery is good
it will most likely be the port where u plug in the adapter ive had that problem alot, so to check to see it it is plug it in move it a little and hold it to see if it charges , and try it in a few different spots
Feb 19, 2010 | Gateway MX8734 Notebook
Netgear will not connect to the internet on my laptop
Check the power adapter to the Netgear router with a multi-meter. The voltage should be slightly higher than the voltage that is printed on the label on the power adapter.
Feb 11, 2010 | Gateway 450ROG Notebook
Gateway m460 wont power up and battery wont charge!
From the information you provided it sounds like a bad DC jack, first check your power adapter with a volt meter if you have one accessible. If your power adapter is outputting the proper voltage, then within a 95% certainty its your dc jack. You can look at this website here for more info on dc jack repair, if you dont have the proper tools to fix it.
May 15, 2009 | Gateway M460 Notebook
Gateway MX6440 will not power on
If you are not getting any power indication lights on the front of the laptop with the AC adapter plugged in, then you most likely have a faulty DC jack.  Luckily, that sort of issue can be fixed, and it is not TOO expensive.  Our company typically does DC jack repairs for about $100.
Mar 30, 2009 | Gateway MX6440 Notebook
I'm trying to fix a gateway MFATXNIN NMZ 500SE
Check the adapter with a multi-meter to see if there is voltage at the plug that connects into the laptop. The oltage reading should be slightly higher than the voltage that is printed on the label on the adapter.
Try to borrow an adapter (same as yours) and connect it to your laptop. Also try removing the battery and power up the laptop without the battery but with the adapter connected (could be a battery problem).
Mar 29, 2009 | Gateway NMZ-500SE Notebook
Computers & Internet Logo
484 people viewed this question
David Payne
David Payne
