Question about Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe
My water Tank is leaking. The spring at the bottom of the tank is failing. I need a replacement tank. Where can I find one? I also need cleaner........
  • Saeco Expert
  • 223 Answers
Saeco replacement water tanks and cleaning supplies
Posted on Dec 12, 2007
Our 7 year old Saeco Magic Delux has started to leak water when we fill the tank. It runs out of the bottom of the tank and down the side. Happens about 20% of the time. Is it worth having a 7 year old one...
If I understand well the problem is only with tanks valve which means the spring have become more soft and stays a litle open so you have water leak. It maybe because some scale or dirt keep it open some time.
In order to decide if it wise to fix it or not the answer is simple if you have a good coffee result in cup which means that the grinder grinds good, presure pump work good and boiler heat up ok then you will only need to complete descale the machine and replace only small cheap parts and you will have a very good machine again for some more years. Remember a brand new machine will do the same espresso like yours.
Remeber to vote for this answer.
Feb 25, 2010 | Saeco Magic De Luxe Espresso Machine
Water leaking under the tank
If the water is coming from under the cold water tank on the back of the machine it probably the o-ring seal in the grey machine recepticle which is visable when you remove the tank for filling. This seals the tank to the machine body and over time can leak (mine has!!). You can get them from Gaggia UK in Halifax
Dec 24, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco magic comfort is leaking water from under the water tank
I think you have to replace the gasket in the waterinlet.
Spare part number: 145842900
Aug 17, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic leaks water between water tank and machine.
You have to replace the gasket in the machine where the water tank goes in to the machine.
Jun 26, 2008 | Saeco Vienna De Luxe Espresso Machine
Water leaking out from water container
You either have a small crack on the water tank and/or the connection from the bottom of the tank reservoir to the machine is not sealing properly. ( i.e similar to putting the tank on top of a flat surface, the tank will leak as the seal connections gets pushed up and water begins to flow out)- it is that component that I am refering to. If you can inspect it to pin point the problem - if the latter is the case (valve), could try purchasing a new o-ring, piston, and valve. Suggest contact
. Saeco USA Inc. at 800-933-7876 (toll-free), ask for customer support and they will give more detail or contact SAECO via e-mail at :
Jun 20, 2008 | Saeco Magic De Luxe Espresso Machine
Water tank stay's on
2 things. Water tank has a magnet in it (little rectangle black plastic piece on the backside). Thats gone bad. need a new water tank.
2nd is you need a water tank gasket.
Gasket is easy to fix, flathead screwdriver.
May 13, 2008 | Saeco Magic De Luxe Espresso Machine
Central unit light on a Magic delux is on Saeco
My water tank light stay's on ( can't make espresso) plus water seem's to be leaking out into tray area, also can you tell me where the filter is, and how to get to it? Helpppppppppppp!
Apr 28, 2008 | Saeco Magic De Luxe Espresso Machine
Water leaking into machine
This happens when the boiler develops a leak, usually due to scale buildup. Order a new boiler and o-rings and replace.
Sep 29, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
227 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
