Front of the engine block right behind the fan and where the Rad hoses connect.
Your Thermo in in the front of the engine located near the Water Pump! You will have to remove the Belts to access it... There are only (2) bolts holding it in, It should be an 8mm or 10mm Bolt. Please make sure that you have new seals when you replace the thermo, don't re-use the old one's they may began to leak!
Hope this help!
VADER!
