Question about Procom QL300TYLA Heater
Pilot light on heater
We have had the heater for three years and this is first problem. Before, the pilot lit on first click and never went out. Now, it takes several clicks (sometimes I even manually light it). Then when the heat comes on and cycles off, the pilot light will remain on for a while then just go off. How can I keep the pilot light lit (and a bonus would be to make it easier to light)?
Thanks,
Tom Thornell
  • reallymaddog Dec 12, 2007
    I hope someone can help.
    Thanks,
    Tom Thornell
  • reflexdoc Nov 14, 2008
    trouble locating a thermocoupleing because there are metic nut that goes to the gas valve on line they are 50.00 dollars for a assembly which is a bracket porclian lighter and thermocouping hardware store U.S.thermocouping is about 5.00 dollar
  • 625 Answers
Check the millivolt generator is working. this is the copper colored tube in the flame path. for spark perhaps the gap is too wide. the flame sensor electrically keeps the pilot valve open.
Posted on Dec 14, 2007
Rheem 22V50F1 pilot won't stay lit. Changed thermo couple & it lit, ran then went out. Let it sit overnight & it lit, ran then went out. What next? p.s. The unit is 5 years old. Thanks
If pilot lights and flame is robust and clear blue, and pilot goes out later, then some suspects can be excluded: air in gas line, low gas pressure, thermocouple is overtightened (finger-tight + 1/4 turn), thermocouple not positioned correctly in the flame, dirty pilot tube.
If flame is yellowish and small: then clean pilot tube and combustion parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Remaining suspects can include: air in gas line, low gas pressure, bad gas control valve, tight house so household vent fans pull air down water heater vent that blows out pilot, hot attic with inadequate ventilation, water dripping down vent.
Open following links to read troubleshoot resources.
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 16, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Lit pilot light, turned heater on.run for about 1 hour and pilot light went out.
I wrote a tip on water heater lighting issues. Click on the link below to see if it can help you troubleshoot your problem.
Douglas
http://www.fixya.com/support/r4785355-trouble_shooting_common_gas_water_heater
Oct 02, 2010 | Reliance Water Heaters
The pilot light will not stay lit. A new
Try cleaning the orfice for the pilot light. You will have to dis-assemble the fuel lines from the thermostat to the burner to get at it. The orfice has an extremly small hole in it, do not make it any larger, just clean it out.
Mar 14, 2010 | Drills
I have a Martin ventless gas log fireplace heater and can't get the pilot light to light. In the past, I've had problems keeping it lit, so I've kept pilot lit all year. The other day I successfully used...
You should the value there should be a pilot ajustment screw
some times it is hidden under another screw but should be close to where the pilot light line hooks to the gas value
Dec 12, 2009 | Desa International Unvented Gas Space...
PILOT LIGHT WILL NOT STAY LIT THE TANK HAS BEEN ON FOR THREE YEars with no problems
most of the promblems with gas heaters not staying lit are the theromer cuppling by the pilot is either dirty, built up. or it gone bad and cant be read by the flame.
Aug 30, 2009 | Water Heaters
My 1.5 yr old gas water heater has a pilot light problem
YOUR WATER HEATER HAS WHAT IS CALLED A STANDING PILOT-STAYS LIT ALWAYS WHEN THE PILOT GOES OUT YOU LOOSE EVERYTHING. YOU HAVE TO REPLACE THE THERMOCOUPLE WHICH KEEP THE PILOT LIT. ONCE THE PILOT IS LIT THE THERMOCOUPLE SENDS IN MILLIVOLTS TO THE BURNER TO SAY ITS READY FOR BURNING
IF YOU ARE NOT FAMILURE WITH THIS REPLACEMENT PLEASE FIND SOME ONE WHO CAN. IT IS NOT HARD TO DO ASK A NABOR OR FRIENDS SOME HAS TO KNOW HOW. SERVICE COMPANYS ARE OUT FOR THE MONEY FOR A 10 MINUTE JOB
Aug 10, 2009 | Water Heaters
GWN10T pilot blows itself out
You must clean the pilot regularly to ensure it burns properly. Use a small can of air for cleaning computers and blow air through the pilot to remove dust and small particles that accumulate in the pilot barrel. Use several burst being that it is 2 years old and has not been blown out. THe manual references cleaning the pilot in the maintenance section.
Mar 29, 2009 | Desa International GWN10T Wall Mounted...
Pilot light won't stay lit on convection heater.
replace the therocouple. next year do not turn the pilot off
Nov 24, 2008 | Clairion Convection Heater - HC-1500
Pilot will nost stay lit!
you could be right it could be a dirty pilot remove the pilot assembly and clean it has an orifice inside where the gas has to pass through its about the size of the point of a pin so its possible that its clogged, if this doesnt work the thermocuple might be bad
Jan 01, 2008 | Cozy (W352E) Heater
Procom QL300TYLA Heater Logo
315 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
