Question about Brother PC-6000 Pacesetter
How do i oil this machine , please
Hi
I have never oil my machine and it's making this noise how do i go by oiling it, I do not know where to start, i have a Brother PC 6000 Pacesetter.need help.
You should not use WD40 on your machine. Use machine oil, you can p/u singer sewing machine oil really inexpensively. Also if you write Brother via the website they will email you a diagram of where to oil, I've found them very helpufl.
Posted on Dec 25, 2007
Baby lock quilt & craft model BL2300K. I received this from mother in law, no manual. Does any one know where the oil locations are so I can oil. Starting to make noise needs oil, thank you, robert
As a computerized machine, it is probable that there is very little (if any) oiling required. You can check with your local Baby Lock dealer's technician for oiling instructions and a manual for your machine. (Oiling incorrectly could permanently damage the machine.)
I was unable to locate a manual for your machine, but did find this web site:
Baby Lock Manuals
Dec 22, 2016 | Baby Lock Sewing Machines
My Juki Exceed HZL F400 works ok but the bobbin makes a loud spinning noise. I changed needles, cleaned but no change. I think oil, but no mention of oiling the machine in the manual, help please.
You are correct. There is no mention of oil in the manual. Just make sure that you thoroughly clean as instructed. You might try changing the bobbin to see if that makes a difference. The current bobbin could be bent or damaged. If the noise continues, take it for service. Something could be out of alignment.
Oct 28, 2016 | Juki Sewing Machines
Why is my sewing machine making a rattling noise
What is the make & model of your machine?
If it is a mechanical machine, it could benefit from a thorough cleaning and oiling. When a mechanical machine is not oiled regularly, it will start making a lot of strange sounds.
Oct 24, 2016 | Sewing Machines
My Juki HZL F300 bobbin case is making a terrible noise. It sounds like the bobbin is going to spin right out of it. This noise is SO loud! Do I need to oil anything? It is not even a year old.
Try installing a brand new needle. Sometimes a bent or dull needle will cause lots of racket.
You should consult your owner's manual for maintenance--cleaning and oiling instructions. Most sewing machines do require oil--some more frequently than others. Most machines also need frequent oiling in the bobbin/hook area. Be sure to use only good quality sewing machine oil for your machine--NO 3-in-1, WD-40, cooking oil, or old brown stinky oil.
If it continues to make the noise, you should probably have it serviced. Since it is less than a year old, it might still be covered under warranty, so don't delay.
May 31, 2016 | Juki Sewing Machines
My machine is mAking a very nasty noise when sewing. I've oiled it already n continues any advice?
I suspect that the noise may be the needle hitting the bobbin carrier body
Take it to a service center for inspection and adjustment
if it is out of warranty then any sewing machine repair shop can check it out for you
Oct 15, 2015 | Sewing Machines
Where do you add oil to the simplicity embroidery machine?
In the instruction manual it should show you where you need to put the oil. What sort of noise is it making as there may be a different problem such as stuff caught in the bobbin race
May 16, 2014 | Simplicity Quilter's Classic SW240...
Too much noise
Noise? have you oiled it lately?
Feb 28, 2013 | Juki DDL-8700
My Kenmore 12493 is making a loud squeaking noise. I have oiled the machine as per the manuals instructions...I can not figure out where the squeaking is coming from.
Hi
If you are good with machines you need to take off the bottom cover and oil all of the drive. The motor may all so need to be oiled.
Good luck
Dec 31, 2010 | Kenmore 15208 Mechanical Sewing Machine
Singer sewiing machine clicking
Remove the needle , tighten the needle set screw so the clamp doesn't rattle and run the machine.This will give you a better idea of where the noise originates.
Remove the top cover and put a drop of sewing machine oil(not 3 in 1 oil) on anyplace that moves and rubs. Run the machine again and see if you still have the noise. Replace the top cover.
Open the side cover(left side) put a drop of oil on any thing that moves or rubs(Shafts or joints). Run the machine again.
Remove the bottom cover and repeat the above processes.
If you still have the problem and it is bothering either you or the machine then it needs to be seen by a technician.
sewman7
Jul 10, 2008 | Yamata FY2600
Sewing Machines Logo
259 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
