Question about Coleman 805D712T
Need switch for colman a/c unit
I have been looking for a switch for a colman a/c unit. It is for a camper and it is old and the manufacture said the switch is no longer made and they have no subsitute. the switch part number is 6250a3311. I know the switch has 5 conecting points on back. The color of the wires are 1 blue, 1 black, 1 red, and 2 orange. Here are the modle numbers the switch will fit on 6248, 6250, 6258, and 6259. the switch turns the fan on high or low and also turns the a/c unit on max or normal. If you have any sugestions of a difrent kind of switch that will work and how to wire it that would be a big help to me. One more thing it is just a a/c unit no heat. thank
  • 833 Answers
Jason, if you are willing to to a little wire tracing, you can do this! We're going to create a new switch function. Chances are that two of the wires are probably for the fan motor (high and low). I'm not sure about max and normal. This uses a two position switch. Figure out which wires go where...then...get a '3 way' switch from the hardware store (they contain a common and two 'poles') along with a plastic box to contain them, a double switch cover and some 'heavy duty zip cord'. This is lamp cord but a heavier grade called number 16 or number 14 (14 preferred). Extend each of the wires and tape the connections. Now, threading the wires into the power box, hook the two fan wires that come to the switch to the new switch. Now, the common terminals and the power supply wire (probably the black) should be hooked together. It should all work...ugly but functional. If you need an on/off switch, you can make that a three gang box and include a standard on/off switch. If you can figure out the max/normal function, you can either switch it on or off or either/or...depending on the switch function. Hope this helps.
Posted on Dec 12, 2007
I have a 1971 Alaskan pop up camper not over cab. I just purchesed it and non of the lights or anything work were would I locate the fuse box or junction box. It's on a 76 Cheyenne 1ton with a 454....
Finding information on something that old is difficult but what you would have to do is look for a kick panel or false wall panel being held on by some wood screws. For the unit you have, most likely along the floor. Most I have seen with more modern campers would be near a sink, fridge or bed. If yours has a take that turns into a bed, try checking for a panel under the cushions or along the footboards under that area. Use a good LED flashlight for best visibility. A hint about access panels, if the screw head is an unusual style or square button look, most likely it wasn't meant to be accessible where screws with the typical #2 Phillips or cross-tip are there for general access at any time. Alaskan Campers
This link may also get you in contact with a manufacturer rep to give you specific details for your unit.
Feb 16, 2018 | RVs
I need owners manual for 1995 coleman popup camper.I is a colman seneca.I bought it used and there was no manual with it.
If your looking for Coleman owner manuals or brochures call Beckley's! We have the last copies of these brochures straight from the factory. Limited quantities available so call 800-598-4048!
Pop Up Owners Manuals
  1. 1974 - 2011 Coleman Folding Trailer Owners Manual
Nov 01, 2014 | Sport & Outdoor - Others
My colman roof air in my camper the fan went out i need a motor # 6757b3119 i need one can some one help me please
Any RV service or dealer should be able to get you one, or contact : ( http://www.rvcomfort.com/rvp/ ) and they have a location finder for nearest service center.
Jul 25, 2011 | Heating & Cooling
I installed a new colman mack thermostat in my camper witch has a colman ac unit now ac unit runs 5 min then shuts off for 3 min then starts again and keeps doing this . so I by past thermostat and it will...
if it is a programmable thermostat you can unhook thermostat and when it comes on select 3 instead of 1. As it sounds as though it is short cycling this happens in older houses with drafts. Hope this helps Tim
Sep 07, 2010 | Coleman Mach III Air Conditioner
Fan runs but no cool air. I don't think compressor is kicking in. Thermostat is working because when I adjust temp to be below or equal to air temp, AC unit turns on. When air temp drops as trailer cools...
Have you cleaned the unit? The condenser coil? The filter? The evapartor coil? Sounds like an airflow problem. You need to clean these areas. You can clean the condensor coil with water hose and a coil brush you can get at the hardware store. Clean the evaparator with the same brush. YOU can use a hairbrush if you don't have anything else. But make sure you go up and down on the fins on the coils not sideways. You might check your blower fan for dirt also. Good luck I hope I helped you. Could also be low on charge but first try cleaning.
Jun 28, 2010 | Heating & Cooling
Colman evcon ''B'' relay connection on new programmable t/stat
Hello The B wire now goes to the O termnal on new thermostat.
Apr 03, 2010 | Coleman Heating & Cooling
I need a pilot light for a colman camper furnace model 9201 older one
Check your local RV dealer who is a coleman supplier, they should stock or be able to get in the necessary part plus no shipping
Oct 01, 2009 | Sport & Outdoor - Others
I bought an older camper with a colman roof unit ac. My question is do I need to put small filters under the intake grates inside the camper below the ac cover. There is nothing in there. (bought it this...
its good to put them in, as it will keep dust from building up on the coils, thus reducing cooling.just buy some filter material at any hardware store, coarse, like a sponge, not fine paper stuff.
Jul 30, 2009 | Dometic Rooftop RV Air Conditioner
Coleman 805D712T Logo
217 people viewed this question
Top Coleman Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Kolbrun...
Ross Keen
Are you a Coleman Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
