Coffee Grinders
Problem for Coffee Grinders
Generic problem for all Coffee Grinders
Cuisinart DBM-8 coffee grinder
By Punkvic on Dec 12, 2007
All of the sudden only half the amount of coffee is being ground at the same setting. I've tried emptying and refilling the hopper without success. Any suggestions?
The grinder was registered on-line 09/16/07.
Thanks.
Gene
Best Solution
posted on Dec 31, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Have you tried checking the output chute at the bottom to see if it is clogged up? I was having low flow issues, which is how I found this post, and went and cleaned it out completely. I was amazed, and a bit disgusted, at how much powder was stuck in there. The top screws off nice and easy. then just use the brush down the chute there and at the front behind where the bin is. I also ran popping corn through it and got out even more. Then I threw all the attachments into the dishwasher, top rack like the manual says.
Hope that helps you.
Popular Solutions for Coffee Grinders
Questions and Unsolved Problems for Coffee Grinders
Answer
the button was pushed in on my Krups GVX1, how can I take this grinder apart, to reset the button?
Answer
blade turns very slowly and will not grind coffee beans. Wife, God love her, may have ground nuts... (More)
Answer
The grind does not change although I turn the grind ring. It is always teh same grind.Thanks
Answer
it doesn't always grind the coffee-it just seems to stop and spin
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Coffee Grinders:
Top Coffee Grinder Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Coffee Grinder Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
