ASUS Eee PC 1000H Laptop Logo
Posted on Sep 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Left alt key not functioning in pagemaker
In pagemaker and ctrl+left alt + del is not showing the task manager
tnx
George Etukudo
Level 2:
  • Expert 336 Answers
  • Posted on Sep 16, 2009
George Etukudo
Expert
Level 2:
Answers
336
Questions
0
Helped
114898
Points
752
If you cannot access your Task Manager when Pressing the Ctrl+Alt+Del, this means you have a virus on your system which has disabled the task manager. If you have a good antivirus like Norton, Kaspersky or McAfee try scanning to detect the virus.
OR
Format your system, but before doing that makesure you backup your data before doing that.
Regards
1helpful
Power Point shows a dialog box that I can't close only when connected to projector
Try closing it with the task manager. Click CTRL+ALT+DEL then select the Application tab and see if it is listed as running. Click it to highlight it then select End Process.
You have to Press and Hold the CTRL+ALT+DEL keys. Do not turn them loose until after you hit the DEL (Delete) Key.
On starting up my d800 dell,all i see is a blank page with only the mouse cursor,i have use ait,ctr,del, to enter task manager,i cant find explorer.exe in the processes, It all started after i install...
Click Ctrl+Alt+Delto get to Task Manager. Hold the Ctrl key, plus Hold the Alt Key then hitthe Del key while holding them.Once the task manager opens Clcik the Processes tab then click the Image NameColumn heading on the left to get them in alphabetical order. Scroll downand look for explorer.exe. If you see it click it to highlight it thenclick End Process.
Next, click the FILE tab at the very top left of the window and select New Task(RUN). When the Create New Task window opens type explorer.exe and pressok. Your start menu, task bar and desktop icons will start appearing andpopulating. if not that means a virus has hidden your files and folders.
I did something and now i dont have a start menu
Don't have a an icon
Please give more details as to what is happening and when it happens?
If you are saying your computer boots up but there are No Icons on the desktop, then a virus or infection has hidden them or changed some settings.
Click the Ctrl/Alt/Del keys to start the Task Manager. Press and Hold the Ctrl and Alt keys then hit the Del key. When the task manager opens up click the Processes tab. Under the processes tab click the columnar heading Image Name to sort the items running in alphabetical order. Look to see if you see explorer.exe running under the image name. If you do click it one time to highlight it then click the END PROCESS button at the bottom right of the Task Manager Window.
Next click FILE at the very top left corner of the Task Manager Window and select New Task (Run..). When the Create New Task window pops up type in: explorer.exe and press OK. Your desktop icons and start menu should start populating.
Blank screen
A white blank screen? That sounds like the virus changed your display settings. Click Ctrl+Alt+Del to get to the task manager. Press and hold the Ctrl key plus the Alt Key then hit the Del key. When the task manager opens up Click File at the upper left corner of the window then select New Task RUN. When the create New Task Window opens type: explorer.exe and hit OK. See if it starts populating your desktop icons and shows the start menu and task bar. If so, the virus changed your settings.
To change your display background click Start/Control Panel and look for Display or Appearance and Personalization. When it opens select the Desktop tab and change the desktop background. Hopefully the white will go away.
You may have to get into Safe Mode to do the above if the virus disabled the Task Manager.
2answers
Had a virus got rid off it but now screen is white and cannot do anything with it
Lost start button and icons
Are you saying there are no icons on yourdesktop and the start menu is missing? If so try this: Click Ctrl+Alt+Del to get the task manager to come up. Press andHold each key (Ctrl+Alt) until you hit the Del key, then you can release them.
When the task manager opens up click the Processes tab. You can click theImage Name column to get them in alphabetical order. Look forexplore.exe, if you see it listed click it once to highlight it then click theEnd Process button at the bottom right portion of the task manager window.
Next click File at the very top portion of the task manager window on the leftand select the option New Task (Run). When the Create New Task window openstype: explorer.exe and press OK. Your items will start populating andappearing on the desktop.
Task Manager Disabled
Try using Ctrl+Shift+Escape This should open the task manager directly. If it does not check that C:\windows\system32\taskmgr.exe exists.
2answers
Task manager disabled
PRESS
CTRL+ALT AND BY HOLDING THESE KEYS PRESS DEL
2answers
Ctrl+ALT+Del does not launch Task Manager on my MobilePro 900, why?
The Ctrl-alt-del short cut to the Task Manager is not on the MobilePro 900. To bring up Task Manager on the MobilePro 900, hold the "Alt" key and then tap the task bar with the stylus simultaneously. A menu with "Task Manager" and "Properties" will be displayed, select Task Manager.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
