Less then a yr. old double sided wall heater
Pilot is lit, i switch on thermastat and nothing happens
    Sergeant:
  • 288 Answers
First make sure the thermostat is working right. Make sure the wire connections on the valve are good and tight. If all good, culprit is the thermocouple or pilot generator also called a thermopile. Different style and names, all have the same purpose.
Posted on Dec 28, 2007
Pilot light goes out after thermostat kicks off
If it's a direct spark ignition type heater maybe that's how it's designed to.work .When called for heat pilot open allowing gas then ignitor spark and ignite the pilot then gas valve open and allow gas through burner then unit fires off .
Once temp is met pilot valve closes and pilot out .
Feb 19, 2018 | Desa International Heating & Cooling
Installed a new thermastat and nothing. It is a two wire basic system. when I jump it nothing happens. Is the thermal couple bad
well depending if this unit has a pilot ? if so is it lit? and if not yes thermocoupler sends voltage to gas valve to let it know its ok to open
Nov 26, 2010 | Cozy (W352E) Heater
Wall unit is only three years old pilot stays lit but unit wont fire up. even when disconected from thermastat and ttwo wires are put toether
Check for 24 AC volts out of the transformer. One side (typically white and black wire) you will get 110 volts and the other 24 volts all the time Yellow wires or two wires same color).
Jan 19, 2010 | Williams 2509612 Ceramic Mid-Size Heater
My 1.5 yr old gas water heater has a pilot light problem
YOUR WATER HEATER HAS WHAT IS CALLED A STANDING PILOT-STAYS LIT ALWAYS WHEN THE PILOT GOES OUT YOU LOOSE EVERYTHING. YOU HAVE TO REPLACE THE THERMOCOUPLE WHICH KEEP THE PILOT LIT. ONCE THE PILOT IS LIT THE THERMOCOUPLE SENDS IN MILLIVOLTS TO THE BURNER TO SAY ITS READY FOR BURNING
IF YOU ARE NOT FAMILURE WITH THIS REPLACEMENT PLEASE FIND SOME ONE WHO CAN. IT IS NOT HARD TO DO ASK A NABOR OR FRIENDS SOME HAS TO KNOW HOW. SERVICE COMPANYS ARE OUT FOR THE MONEY FOR A 10 MINUTE JOB
Aug 10, 2009 | Water Heaters
We have a 30+ yr old Ultra-Aire wall heater. The pilot light won't stay lit. We are replacing the pilot generator but it isn't working. What can you tell us about the wiring connections
You need to replace the thermocoupling.
Thats the flame sensor, and they cost around 8 bucks.
If the gas valve does not recieve signal from the sensor that there is flame it shuts down all gas flow.
Jan 01, 2009 | Heating & Cooling
Gas wall heater
the thermastat is broke...replace and will work fine!
Nov 09, 2008 | Reddy R70ET Utility Heater
New water heater problems
the switch is broken, or the voltage on the power from the wall is lower than the voltage on the tank and therefore it could only powering one thing
Oct 16, 2008 | Water Heaters
Patio Heater pilot lights won't stay lit
crappy pilot flame (not properly heating the thermocouple), bad thermocouple, thermocouple loose where it screws into the pilot safety valve, bad safety valve magnet.
One or more of those is the problem.
Oh...there is also a saftey switch...in case it tips over. It will also cause the pilot to not stay lit (if the switch or wires that go to i are faulty)
May 30, 2008 | Coleman (5040B750) Patio Heater
Heating & Cooling Logo
373 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
