Question about Microsoft Xbox 360 Console
Steve cannot get IPAddress
    President:
  • 4,402 Answers
Im assuming you have this hooked up to a router?
and router is set for dhcp?
and still not giving address then i would reset router.
Posted on Dec 12, 2007
How do i find my modems ip adress
In order to find out the modem ip address
1)Connect your modem directly to the computer using an ethernet cable
2)If you are using windows XP >Go->Start>Run>type CMD>click ok>You will get Command prompt/(black window) type inside the command prompt>ipconfig and hit enter-/under Ethenet adapter local area connections, you will find your ipaddress,ipv4address and the default gateway will be your modem ipaddress
3)If you are using windows Vista >Go to start>type under start search>CMD> cmd.exe will be listed on the top>right click the cmd icon using your mouse>select run as administration>you will get the command prompt>type inside the command prompt>ipconfig and hit enter-/under Ethenet adapter local area connections, you will find your ipaddress,ipv4address and the default gateway will be your modem ipaddress
If you look at the bottom of the modem you will find the ipaddress of the modem
Nov 02, 2010 | Computers & Internet
Tip
How to check ipaddress of your windows computer?
1Click on Start in the bottom left hand corner of your screen-->Click on Run-->Type "cmd" or "Command" in the Run box-->Click on OK or press the Enter key on your keyboard-->Type "ipconfig/all"-->your ipaddress, default gateway and etc will be displayed..
on Jun 11, 2010 | Computers & Internet
I cannot connect to the internet with the wireless connect, it is showing that the wireless is connected and the signal is excellent, but when I try to get on the internet I get a message saying the page...
I got your issue , If you need to check the ipaddress on the wired computer which is online. You need to check the ipaddress on the wired
So please follow these steps.
1. Click on start--> go to RUN --> in Run you type in "cmd" and click ok
(If you do not find RUN in the start search box type RUN and hit enter)
2.You will get a black screen(command prompt) , there type in "ipconfig" and hit enter
3.Please make a note of the ipaddress (or it says ip V4 ipaddress) , it will be like 192.168.2.2 /192.168.0.2 /192.168.1.5
Now move to your wireless computer
1. Click on start --> go to control panel
2. Go to network and sharing center (or network and internet connection in xp , then network connection)
3. In the left side click on manage network connection in vista
change adapter settings in win 7
4. If you find the wireless network connection, right click on it and go to properties
5. select Internet protocl TCP/IP(ver:4 in vista & Win 7) and click on properties
6. change it to use the following IP address
7. Then type ipaddress :192.168.2.50 (provided IPaddress in the wired comp is 192.168.2.x, if its diff change it accordingly)
subnetmask :255.255.255.0
Default gateway :192.168.2.1
8. Change to Use the following DNS server address
Preferred DNS :4.2.2.1 & alternate :4.2.2.2
Im sure this will work
Thanks & Regards,
Prema
Oct 11, 2010 | Computers & Internet
Can not get a network connections.
Check if your network settings is configured properly.
Try to see if you have configured a working IPAddress and check your workgroup if you are in a network.
Go to MSDOS prompt
Use ipconfig /all - check your ipaddress
Type ping www.yahoo.com - check if its receives the reply data's 100%
Thanks. Cheers!
Apr 20, 2010 | Sony VAIO VGN-CS110E/W NoteBook
Forgot my password for router or ip addressed
by default leave the username blanck and password is admin, for the ipaddress go to command prompt type in ipconfig then hit enter, the gateway is the ipaddress
Oct 20, 2009 | Linksys Wireless-G WRT54G Router
Using linksys wet11 to connect to internet through linksys wireless router, working before, suddenly, not working, trying to setup again using static IP, not working, using DHCP, not working, run...
it's because you need to change the ipaddress in you linksys
make sure the ipaddress from you modem it's not 192.168.1.1
if you have the same ipaddress on the modem try changin the ipaddress on the linksys to 192.168.1.1
Oct 15, 2009 | Linksys 802.11b Wireless Ethernet Bridge:...
I have the HERMO packard bell model. I can hardly access internet and the sound is not heard. Please hhelp
For internet
Resolution:
First check ipaddress
Click Start -run- type cmd hit enter for XP or Start -search-type cmd hit enter in Vista. On the DOS black screen after the blinking cursor type ipconfig hit enter check the ipaddress if are getting ipaddress other than (169........) it is proper ipaddress for e.g 147.14.48.478
Ping the default gateway e.g ping 147.11.445.478 if you are able to get packets send 4 received 4 loss zero is with Internet explorer or operating system.
If unable to ping or getting 169..... ipaddress . you are having static ip address
On the black screen at the blinking cursor type ipconfig /release hit enter
then type ipconfig /renew hit enter .check ip address
Ping default gateway then ping www.google.com if you are able to get packets send 4 received 4 loss 0. Try connect to internet using internet explorer or other browser. if still unable to connect then issue with firewall or antivirus or IE corruption .
Create new administrative account in XP and do MSconfig .Restart the system and logon to new account and try connecting to internet.
If issue persist might have to repair IE or operating system as it is software issue or virus issue.
You can connect a different computer if you have one and check internet.
If unable to get any ipaddress or still getting static ip address ,reset modem or check ethernet cable ,do a hard reset on the internet modem.Shutdown and restart computer and check ipaddress then try connecting to internet.
NO sound : Check the sound driver .Try reinstalling sound drivers
Aug 24, 2009 | Computers & Internet
Can't connect to the internet after running Rescue and Recovery
It seems you have a static ip address. Check the ipaddress by clicking - start -run - type cmd hit enter. on the black screen - type ipconfig and enter. If the ipaddress shows ipaddress e.g 169.10.14.12 . its is static ipadress. Do ipconfig /release then ipconfig /renew.If u are getting new ipaddress. Ping www.google.com and check if you are able to ping. You should be able to connect to internet. If not then reset the Internet router if you have one or shut down the computer.Disconnect internet cable .If u have modem,turn it off.Wait for 10 second. Connect internet cable.Restart the system and check. If issue persist contact ISP. Good luck.
Aug 19, 2009 | Lenovo Thinkpad T60 Notebook
Static IP address, primary DNSand Second DNS
hi
the router ipaddress or default gateway will be 192.168.0.1 and you can use any ipaddress from 192.168.0.2 to any... for your devices like computer and primary dns address will be 4.2.2.2 and the second dns will be 4.2.2.3
gud luck
thanx and regards
sukhvinder
Aug 18, 2009 | D-Link DIR-300 Wireless Router
I`m trying to add another computer to my router d-link wbr 2310 with no luck.What can I do? Thank You
check the ipaddress by going to
run>>cmd>>type ipconfig
get the ip address
>>now type the ipaddress on the address bar
you will get the default gateway page
>>now unblock the port from the unblocking port options
May 11, 2009 | Cisco Universal Access Server AS2511-RJ...
Microsoft Xbox 360 Console Logo
22 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
