Programs quit when importing to or exporting from ext. hard drive
I can drag and drop anything I like into my 1TB LaCie Hard drive and it works fine but no matter what program I'm in, via drop down menus, if I try and import something from or try and export something to it, it will totally quit that program. It will even quit mail if I try to save an attachment from an email to this hard drive.  This applies also to iTunes, Garage Band etc etc. Has only just started happening in the last couple of weeks and this problem doesn't happen when I try and save to any of my internal drives or my other 500GB La Cie External Drive.
Mac Dual 450 Mhz Power PC G4  Tiger 10.4.10
  • 3,587 Answers
LaCie's drives are more for data storage and backup, than as a 'logical' drive accessible through applications. You may wish to consider that, during your use of the item.
Posted on Mar 09, 2008
I have a Lacie 1TB Big Disk Extreme. It has recently developed a loud regular whirring noise, that goes on and off every few seconds. What should I do? Thanks! Adrian
The irregular clicking or chunking sound usually indicates that your hard drive is suffering from physical damage. immediately backup your data, your hard disk will die soon.
This problem can be caused by the following:
  • Head Crash
  • Bad Sectors
  • Mechanical Faults
If your hard disk is under warranty then you contact your manufacturer.
Hard disk drive occasionally produces a whirring sound when it searches for a file which is heavily fragmented. This is caused by the spinning platters as the read-write heads zoom back and forth to access the sectors where the data is stored. It is important to distinguish the whirling sound from the clicking sound. This whirring sound can be reduced by periodically defragmenting your hard drive. Defragmenting reorganizes the scattered data on the hard drive to make files and programs run faster. It relocates the commonly accessed files to the beginning of the hard disk where data can load at a faster rate.
Apr 08, 2011 | LaCie Big Disk External USB 2.0 1TB Hard...
Lacie 1tb only showing n 30g room
Hey there,
A hard drive, especially a new one, might need to be formatted before use to show the proper amount of data available for use. Sometimes a hard drive might malfunction and not show the proper amount of free space. formatting should also solve this problem, Before you go and format your hard drive understand that by formatting it you will lose all data that is stored on it, so if you have anything important, take it off first.
here is a detailed guide to reformatting your hard drive based on your operating system
Hope this helps!!
Mar 16, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
1tb LaCie drive turns itself off and on randomly
It probably is about to "die" -- copy all the files from it to your computer, before it does completely quit.
Then, exercise the warranty to get a replacement.
Or, open the enclosure, remove the disk-drive, buy a new, compatible disk-drive, install into the enclosure, to "revive" your external storage device.
Oct 29, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Is Model Lacie 301442U compatible with Mac Pro 10.4.11
According to this website it is compatible with a mac. Hope this helps.
Jun 02, 2010 | Computers & Internet
I can't add and remove datas from my Lacie Hard Drive 1To
Try to just drag and drop your files, this will usually create a copy, but only when dragging to another drive. If you drag and drop to the same drive it will MOVE the files.
Apr 03, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie 1 tb external hard drive won't work
ya .. put it for replacement and u get a new one for free .. just dont tell them u dropped it
Jan 10, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie 1tb ext hd. drive does not show in disk
Your external drive has 2 parts, the hard drive, which is just a normal hard drive you would find in any computer, and the usb bridge, which connects the hard drive interface (either ide or usb) to the usb or firewire or esata or whatever. Sounds like one of these are bad. Does the computer see the bridge? it should show up as a mass storage device in device manager and the safely remove usb devices dialog. If not, then get a new enclosure for the drive. These range from 25-100 dollars. If the bridge does show up, take apart the enclosure and pull the drive out and try hooking it up as a second drive in your computer. If it works there, then you need a new enclosure. If not, then you need a new drive.
Dec 07, 2009 | LaCie Computers & Internet
FW Lacie Porsche FW ext. HD 250GB light on case blinks and
conect your harddisk to computer whch has windows xp.
Then go to start emnu then type in run 'cmd"
then you can see command propmt.
Then go to your external drive letter like f:
then type 'chkdsk /r"
then pres "y'
then it fix error on hardisk.
Aslo you can format it .
Just take backup of data which you need then right clik on drive licon and format it.then it works fine.
Jun 23, 2009 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
Lacie 1TB External USB Drive tells me to format when I plug it in
I finally found a solution. I used GetDataBack, it was easy to get, I used the usual torrent sites to get it, and it recovers your files from your hard drive if you have problems with it (i.e. can't access it, etc.). I think my problem was caused by pulling out the usb cord without Safely Removing the hardware,
Sep 25, 2008 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
