Question about Philips CDR600 CD Recorder
Not reading blank cdr audio disks to record onto..
Pleas ecan you help as my philips cdr 600 used to record blanl audio cdr but now it will not..the player always says insert disk after the disk is already in....what should i do ? do i need the players laser need realigning ?if so how do i do that ? please inform asap as iam going crazy !!!!
thanks
  • 2 more comments
  • Mark53 Apr 12, 2008
    I have the same problem. It will use the JVC cd-r in the red cases but not the newer JVC yellow cases, which I think are the only ones I can buy. Has anyone found a solution to the problem?
    Mark S
  • cucu_5000 Jul 23, 2008
    my philips cdr 600 audio recorder keep display error ( wrong disc, event insert the new blank disc.) what should i do now.
    thanks
  • studioman Sep 08, 2008
    I have a Phillips CDR 600 and it keeps saying 'no disc' no matter what disc I insert. I have had a professional look at it and he says it's not so much the laser, but the motor that drives the lens, as when you start it up, it makes a whirring noise and spins for a few seconds then stops. Has anyone any ideas how I could fix this?
    r
  • tonygartland Mar 19, 2009
    I have a similar problem with my machine, BUT I do remember that Philipps were a pain for disk compatibility. I had an older model and it would only use TDK disks. Worked perfectly with them!!! TG
  • 112 Answers
Will it read audio cd's? Sounds like you need a new laser unless you have access to a philips COMPair system to diagnose / realign it.
Posted on Jan 15, 2008
Every blank cd I try to record on gives me a "no
You're trying to record on a data disc, not the required CDR-AUDIO or -MUSIC disk it needs to record. Register and download the manual for free at retrevo.com http://www.retrevo.com/support/Philips-CDR560-CD-Players-manual/id/23137ag310/t/2/
Feb 16, 2011 | Philips CDR560 CD Player
PHILIPS CDR 870 FLASHING "OPCFAIL" AND WON'T RECORD
I HAVE A PHILIPS CDR 870 "OPC FAIL" PROBLEM. I HAVE RECORDED ONTO CD-RW, AND NOT YET FINALISED THE DISK AFTER RECORDING, IN ORDER THAT I CAN GO BACK LATER TO ADD FURTHER RECORDINGS. AFTER SWITCHING THE MACHINE BACK ON OPC THEN OPC FAIL FOLLOWS, EVEN WITH NEW DISKS CD-R AND CD-RW. MGHT THE MACHINE ITSELF REQUIE CLEANING OR IS THIS A FAULT? I AM USING MAXCELL DISKS, BOTH TYPES. THANKS. JEREMY. GATESHEAD.
Mar 19, 2010 | Philips CDR870 CD Recorder
My cd recorder wont read blank cds help me please
Do as it asks, insert blank CD-Audio or CD-Music media.
Discs for recording
For recording, make sure to use special audio discs only.
These discs are marked with “Digital Audio” and the logos shown below.
There are two different types of audio discs for the use on this CD recorder:
– CD-Audio Recordable (CDR) discs
These discs can be recorded on once and
play in all standard CD players and CD
recorders, when they are finalized.
– CD-Audio ReWritable (CDRW) discs
These discs can be recorded on, erased and
re-recorded many times and play in CDRW
compatible CD players and CD recorders,
– All Philips CD players and CD recorders
with the sticker shown here are CDRW
compatible.
To ensure proper working of the set we recommend the use of Philips audio CDR and audio CDRW discs only.
Note: Do not use a computer CDR or CDRW as recording will not work!
Go here and download the manual. You'll need it.
http://www.p4c.philips.com/files/c/cdr602_00s/cdr602_00s_dfu_eng.pdf
Mar 04, 2010 | Philips CDR602 CD Recorder
When i put a balank cdr the recorer says wrong
Listen to it. Go out and buy "CD-R for AUDIO" or "CD-Music" blank CD's and it will cooperate. Home CD recorders are designed to reject data CD-R media for recording.
Jan 22, 2010 | Philips CDR775 2-Disc CD Recorder
Wont record on blank pc disks!
I had the same problem and found that I was using the wrong type of CDs. If you look on the CD you have to use the CD that says Compact disc digital audio Recordable or Compact disc digital audio Rewrittable. After I used the Digital ones I could record on it. I then tried the CD on the PC and it worked. You can look on the top of the unit and see the information if you still have it. Hope this helps you.
Feb 23, 2009 | Pioneer PD-RW839 4-Disc CD Recorder
My CD Recorder is not reading my blank discs. What can be the pro
hi not sure if this helps but some disc ,s ive used on my 500s won,t work either so i changed the type of disc and it seems to do the trick i think some disc,s just aren,t good enough ie cheap ones .
Jan 13, 2009 | Philips CDR600 CD Recorder
Recording trouble
Hi again,
I understand. Must be a glitch somewhere. Anyways, I already posted possible solutions here your original posting/problem. They were:
1. Power on the Philips FW-R7, leave the left tray empty and closed. Open the tray and put in a recorded CD (not a CDR but a regular CD from your music collection), close the right tray. Wait a couple of seconds as the FW-R7 reads the CD. Now open the tray, remove the music CD and insert your CDR. The FW-R7 should read the CDR without the error message and record to the CDR from any source. Let me know if this works for you;
2. laser cleaning or realignment (would need a service center);
3. try using lower then 40X blank CDs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 18, 2008 | Philips FW-R7 CD Shelf System
Won't record
I've just spoken to a friend who also has one of these older Philips recorders & he has the same problem.
As per my previous post, he fixed his problem by locating old stocks of blanks. New audio discs seem to have been manufactured & optimised for fast writing speeds (up to 32x speed) & this is causing the problem (you can't write at x1 or x2 speed to these new speedy discs).
Trying a few different brands of discs to try out is a whole lot cheaper than a repair. I suggest when you find a brand that works, you stock up on these discs as it seems they will become ever rarer.
Dec 11, 2007 | Philips CDR785 3-Disc CD Recorder
Open Questions:
Philips CDR600 CD Recorder Logo
626 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
