Question about Philips Magnavox 51MP392H Rear Projection Television
Projection tv problems
Hi, I have a magnavox rear projection tv and I am having problems with it. It is only about 2 years old. I have shadows around the images. I did a manual convergence, but that didn't get rid of the curve in the picture. There is one at the top and bottm of the screen. How can I fix this? Is this something that I would be able to do? I am electronically inclined.
  • jjdkjdk Dec 13, 2007
    Premtech,
    Thanks for the information. Will it hurt the unit to continue to watch it until we can afford to have it fixed, or should we shut it down until then?
Thanks, premtech. We will leav it off until we get it fixed. Hopefully that will be soon.
Posted on Dec 13, 2007
  • 934 Answers
Jj,
The convergence amps have most likely failed. This is the number one leading cause for the symptom your describing and the most common failure on that unit.
Your Tv take two STK392-120 Sanyo Ics for convergence amps, located at Ic7404 and Ic7405 on the board and mounted to a rather large aluminum heat sink. In addition you will most likely have to replace R3159 and R3160 (6.8 ohm 1w) resistors and test the remaining low ohm resistors for change in value.
I would strongly recommend that you not do this repair yourself in this particular unit it is rather complicated by having to remove the boards to gain access. Notwithstanding that you could damage some of the smt components just taking the board out, you need some diligence in labeling outputs to crts from ssb board and on both ends of the connectors - otherwise re-assembling it could cost you a greater failure somewhere else. In a nutshell, replacing convergence amps in this unit is "extremely difficult" compared to say a Samsung which is a walk in the park! And the real downside is a little mistake can really cost you... Besides, a shop would really earn their money on this one..
Bill
Posted on Dec 12, 2007
  • William Rayburn
    William Rayburn Dec 13, 2007
    It's better not to run it - the Ic that's failed is most likely shorted and placing some serious stress on the yoke return resistors. It doesn't matter too much that another resistor or two might fail because that would merely drop the video - but if it doesn't open it could short the windings in one of the yokes and that starts getting expensive...
    Sorry!
    Bill
I have aquires a Magnavox rear projection tv. The picture is sharp but is in shades of red and pink. Obviously the green and blue are not working correctly. Any Ideas besides kicking it to the curb?
The tv have a problems known as a convergence pictures problems,the tv convergence board it is dead,that why tv colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?This tv can be repair,by fixing the convergence board,by replacing 2 STK convergence ICS and some or all of it resistors too.Will fix convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors,to save this tv.
Jul 27, 2011 | Philips Magnavox 51MP392H Rear Projection...
I have a Magnavox 51mp392h/17,that now has double vision (text is double,all images) there is also green, off red colors on the picture. Please help me the tv is 6 years old. should i throw it away or get...
No.Should cost u like $300-350 for parts and labors.Get it fixed any local tv shops can fixed this problems,very common problems for DLP CRTS tubs design projection tvs Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture colors lines R,G,B mis alignments,have pictures colors shadow or 3D pictures look alike.The tv convergence board must have it parts replace like 2 STK convergence ICS and some or all of it resistors to fixed the convergence board to solved convergence pictures problems.
Jul 22, 2011 | Philips Magnavox 51MP392H Rear Projection...
51 Hitachi rear projection 6 years old, can't get it to focus, Has sound. Can only get the picture to come in abpout 80%. Around the perimeter, sports scores and subtitels are not readable. Used the fucus...
Flash Focus magic button no longer work.The tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures problems.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv convergence picture problems.The shop,will cost $300-350 for parts and labors.
Oct 13, 2010 | Hitachi 51F500 51" Rear Projection...
Picture has red and blue shadow images
thats a fairly easy fix. You need the DPTV305-DPTV345 convergence repair kit available at the following link.
http://servicemanuals.vstore.ca/
The kit contains the parts and the CD with instructions
Sep 29, 2009 | Philips Magnavox 51MP392H Rear Projection...
Blue shadows on my philips projection tv
You have possibly contaminated fluid in your blue picture tube if it has a hazy look.Blacks and whites look bluish and whites have a blue bloom to them.The other problem could be bad convergence amps.This would be double image around letters on the screen.
Jan 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture is distorded.it shows a shadow of the image in different
Hi,It sounds like the convergence is out on your tv if it has been moved recently this can cause this problem but it really needs a technician to examine it.
SUPER8
Jan 02, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture shadow on rear projection Sony big screen TV
You have 2 distinct problems that should be addressed separately. Please repost the Samsung problem. I will address the Sony problem here.
If the "shadow" makes the picture seem somewhat of a 3D one, the problem is with the convergence circuit. This could be as simple as bad connections on the pins of the convergence ICs or defective ICs. If you can solder and would like to attempt the repair, update this and I'll provide more details and instructions.
Dan
Sep 25, 2008 | Samsung HCM4216W 42" Rear Projection...
Maganvox TV with red-shadow to picture
Hi Emily,
Your TV has bad convergence amplifiers. They are large integrated circuits that are mounted on large metal heat sinks. They have a part number on them, but might be covered up by a bracket. The part number should start with STK. They are replaced as pairs. You will have to find someone with the skills necessary to replace them.
Best Regards,
MyTvGuy
Feb 10, 2008 | Philips Magnavox 51MP392H Rear Projection...
51" Magnavox projection TV
same with mine. Two things that they have to install and they need the whole tv there to fix it and run it for a week. Cost 500.00!!!
Aug 20, 2007 | Philips Magnavox 51MP392H Rear Projection...
MAGNAVOX BIG SCREEN TV
Hi, I am having the same exact issue with mine. Although, it is only about 2 yrs old. We are still trying to find out what is wrong with it.
Aug 01, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
53 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
