Question about Samsung HCM4215W 42" Rear Projection Television
How to adjust the green convergence?
When adjusting the convergence manually the green is way out of line and
i can not adjust. Can it be done easily or do i need some help?
    Novelist:
    Champion:
  • 232 Answers
Hi, If the green crosshatch lines are bent or curved then you have an IC failure, Green is the reference so it can`t be adjusted with your remote, the correct procedure is to move the red and blue on top of the green to make the crosshatch white, As I said if the green horizontal or vertical lines are not perfectly straight then it needs repair not adjustment, BMW Rider
Posted on Dec 12, 2007
GREEN CRT OUT OF FOCUS
The individual lens have a lug nut that when loosened allows the lens to be turned-----cover red and blue lens and call up the convergence grid---from the rear adjust that lens until the green lines are in good focus(can also do the red in and the blue if needed)
You will get no more advantage as the manual focus controls on the splitter block have very limited range.
when done carefully tighten the wing nuts on the lens back tight.
Dec 05, 2012 | Mitsubishi WS-65807 65" Rear Projection...
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    It has tripple vision and looks like a bow tie.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
    To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
    To process and save the adjustment made, follow the steps below;
    1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
    2. Enter the menu on your TV. Use the remote control and bring up the menu.
    3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
    4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
    5. Press "Enter." A crosshair pattern will appear on your screen.
    6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
    7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
    8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
    9. Repeat these steps for all colors.
    Take care
    Jul 06, 2010 | Televison & Video
    How do you set convergence
    What is your Make and Model number?
    Mar 18, 2010 | Televison & Video
    Hitachi 43FDX01B green is out of whack
    The green is not adjustable in the customer menu because it is considered the 'master' color. It is adjustable in the technician mode however but if it is curved it won't even adjust properly that way either. The problem is the convergence ampifier responsible for green convergence has failed. The convergence output IC's need to be replaced.
    May 27, 2009 | Hitachi 43FDX01B TV
    Convergence is off - Blue and Red are fine Green will not line up
    On most units, the Green is constant and the Red and Blue are adjustable. Here are 2 links on how to manually adjust the convergence. There is a menu option using the remote control. Once there, you will find step by step procedure on how to adjust the convergence. Hope this helps answer your question. All the best!
    Greg
    http://www.fixyourowntv.com/menumitsubishi.php
    http://www.ehow.com/how_2034880_perform-convergence--tv.html
    May 23, 2009 | Mitsubishi WS-65809 65" Rear Projection...
    Toshiba 41h81 green convergence problem
    Below are two of the most common problems encountered with projection TV sets.
    Problem #1 - CONVERGENCE PROBLEM
    Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
    Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
    Common Symptoms include....
    • Screen looks 3D
    • Colors don't line up
    • One or more colors can't be adjusted when using the convergence menu.
    • Screen is bowed or warped.
    • TV shuts off after powering on - TV may also make a chirping noise.
    Here are some photos of convergence problems.
    Here is a quick test....
    Using your original remote go-to the settings menu then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    You should be able to move RED and BLUE in all directions - up, down, left, and right.
    If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
    Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
    93a1209.pngCONVERGENCE SOLUTION
    You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
    This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
    Apr 07, 2009 | Toshiba 42H81 42" Rear Projection...
    AKAI PT55
    The green convergence can only be adjusted through the service menu
    Feb 10, 2008 | Samsung HCN4226W 42" Rear Projection...
    Samsung HCM4215W 42" Rear Projection Television Logo
    97 people viewed this question
    Jerry Greenberg
    Jerry Greenberg
