Question about Disney DTD1363-CAR 13" TV/DVD
Access to inside
What is the easiest way to remove the cover of the tcv or just the back?
The platic "lug nut" covers have to be removed to access three screws on each wheel. They are hard to get off without breaking them. If you look carfully you well see that is a tab on two sides of each "nut". They have to be compressed to release. After breaking two, I found that a narrow xacto blade can be pushed into the tab slot on one side. A put pressure on the blade so that the tip forces the tab toward center of the nut. A slight twist should pop on side free. The other side will come free easier. There are five on each side. Only the front and the two in rear have screw behind them. Once you remove the "nuts", and the wheel, the other screws are obvious. Two under each wheel. Two at the top of the cover and two on the video input board.
Posted on Dec 16, 2007
Thank you very much for the tip. Very Helpful!
Posted on Dec 24, 2007
What's TCV ?
Hello
Type in your question as it is now, in Google search box and search. It says that CTV = Total Contract Value of a transaction as measured over the term of agreement.
montclairadvisors.com/blog/2010/03/got-for-saas-and-cloud
Feb 02, 2012 | 2000 Toyota Mark
How do i remove cover of tail light change bulb
You don't, you replace it from inside boot (trunk)
Feb 22, 2011 | 2007 Ford Focus (3 Door) Hatchback
How to install a rear brake light bulb on a 2004 Isuzu Rodeo
The easiest way is to open back trunk open any coverings or carpet pull it back to gain access to the bulb socket once you see the socket twist it counter clock wise and remove remove the bulb and replace with new one once installed have someone step on your brake pedal to confirm working then put upholstery back and you =have completed changing your brake light bulb.
Dec 27, 2010 | 2004 Isuzu Rodeo
My Norelco 5845xl willnot turn on or charge.
The shaver probably needs a new battery pack. You will find replacements at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace, first remove the back cover by removing the two screws. Then remove the two plastic clips that are in the wat of fully accessing the batteries. You can then access the batteries and circuit board inside. For easiest installation, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Nov 13, 2010 | Norelco Reflex Shaver 5845XL
I want to remove the right front fender and would like to know where all the nuts and bolts etc. that need to be removed are and the easiest way of going about it?
I just did this.
Remove the fender liner
Remove the mud guard
There are several 6mm flange bolts with 10mm heads.
3 along the inside of the hood
1 behind the top of the door accessible with the door open
2 on the bottom of the door behind the mud guard
2 behind the bumper cover, the headlight is attached to one of these.
There is a screw holding the end of the bumper to the fender. Remove it and pull the cover away from the fender. There is a large plastic clip inserted into the fender next to the two bolts that holds the bumper cover but should release when you pull the cover.
The headlight has two dowel pins that insert into the fender, removing the headlight may be better but you have to remove the bumper to get to some of the headlight assembly bolts. There are 4 bolts holding on the bumper that are accessible through the turn signal holes. The bumper will "fall" about an inch and sit on some collar bolts so it can be lifted off without one side falling (a neat feature). The turn signal is held by one Phillips screw accessible through a special hole on the inboard side of the bumper with your longest Phillips screwdriver.
Jun 03, 2010 | 1997 Honda Accord
WHERE IS THE FUEL PUMP
On my 01 Bonneville SE you can access the fuel pump from inside the trunk after removing the trunk carpeting. THere are 5 10mm bolts holding an aluminum cover on. It was still sealled pretty well after the bolts were removed and I had to carefully pry the cover off in a couple different spots to break the seal.
Here is a picture after the carpet is removed. I removed the spare though I'm not really sure why. (I did already remove the 5 bolts in this picture). ITs on the passenger side closer to the back seat. I actually found it easier removing the bolts from inside the car reaching through the armrest in the back seat.
Here is another picture after the cover had been removed. I do not believe it is necessary to remove the tank for our application.b11db2d.jpg
Autozone's website does have a pretty good step by step direction. Registration is free. Easiest way to find the directions is to search for the part you're replacing, in this case the fuel pump, and then click on the repair guide on the left side of the screen.
Jan 11, 2010 | 2001 Pontiac Bonneville
I managed to crack the LCD on my hp dv7 laptop. What is the easiest way to get the screen out to replace it?
Typically there are two screws on each hinge that is mounted inside the back of the laptop. You'll have to get the top indicator panel off to get to the connector(s) coming from the LCD. The usual process is unclip the wiring harneses and then remove the screws, and the screen and hinges come out. Replacement is the reverse.
Some laptops you have to remove the entire top of the laptop (keyboard/touchpad first, then the cover assembly. Others you can just pop the rear button cover (usually where the LED indicators and power button are located) and access the LCD connectors there. Best way is to go to HP and find the service manual information which will tell you how to remove that specific piece of hardware.
Jan 01, 2010 | HP Pavilion DV7-1020US Laptop
I have a lexus ls400 and the fuel gauge stop working... at first the niddle would go full and stay there. then on other days it would read empty.
The sending unit located in the gas tank must be replaced on most of these cars you can gain access to it by removing the back seat revealing an access cover allowing you to get to the sending unit remove retaining screws or locking ring and replace. You probably should be grounded and have a Haynse repair manual handy to walk you through this job it's not the easiest job but not to hard either unless the gas tank must be dropped down to access the sending unit if that's the case have a shop do the job that job is pretty tough.
Oct 27, 2009 | 1994 Lexus LS 400
Need location of fuel pump on 2002 grand am
Remove the back seat, there should be a cover to remove allowing easy access to the pump.
May 15, 2009 | 2002 Pontiac Grand Am
Front screen
Hi, much easier to access the front screens (there are 2 sandwiched together) by removing the top back cover, be prepared for lots of screws and when you get down to the last 2-3 screws get some help, on the inside of the back cover is a large mirror, some are made of mylar, do NOT clean or even touch a mylar mirror, the others are made of real glass and the back will be much heavier than you think (and very expensive if you break it)once the back is removed you should have access to the bug, good luck, video-tek
Feb 03, 2009 | RCA P52926 52" Rear Projection Television
Disney DTD1363-CAR 13" TV/DVD Logo
75 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Demonic-2011
Demonic-2011
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
